miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Fri Feb 07, 2014 3:33 pm Post subject: |
bugninva wrote: |
Other than the infamous Mario G, I have never seen someone purposely twist someone's words as much as wild things does. Amazing! |
Present company excluded, naturally. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Fri Feb 07, 2014 6:10 pm Post subject: |
miniman82 wrote: |
bugninva wrote: |
Present company excluded, naturally. |
Wildthings has a knack for it... it is interesting that in the oil thread he says I don't go by the manual, because I know better. Even for my Briggs and Stratton. But here he says go by the manual because the manual knows best! Hahaha _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Fri Feb 07, 2014 6:31 pm Post subject: |
bugninva wrote: |
miniman82 wrote: |
bugninva wrote: |
Wildthings has a knack for it... it is interesting that in the oil thread he says I don't go by the manual, because I know better. Even for my Briggs and Stratton. But here he says go by the manual because the manual knows best! Hahaha |
Easy fix, just click >> here << _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Feb 07, 2014 10:04 pm Post subject: |
No way, can't get that kind of entertainment just anywhere _________________
VW_MAN_73 Samba Member
Joined: November 18, 2005 Posts: 958 Location: New Port Richey, Fl
Posted: Sat Mar 29, 2014 9:59 pm Post subject: |
Does a transmission on a 73 bus take 7.42 pints of gear oil? Thanks. _________________ 1973 beetle |
Posted: Sat Mar 29, 2014 10:22 pm Post subject: |
VW_MAN_73 wrote: |
Does a transmission on a 73 bus take 7.42 pints of gear oil? Thanks. |
you can check the technical section for owners manuals and such
Posted: Sun Mar 30, 2014 6:39 am Post subject: |
Thank you! _________________ 1973 beetle |
Hnoroian Samba Member
Joined: October 27, 2013 Posts: 535 Location: Bakersfield
Posted: Thu Apr 03, 2014 12:12 am Post subject: |
39 pages of back and forth gl4 and gl5... OMG it never ends! I'm changing my fluid this weekend, 1 because it's getting tougher to shift, 2 I haven't done it and don't know when the PO had done it, and 3 I'm going to use gl5
I believe Glenn and my local acvw mechanic tells me/us... Off to napa tomorrow for some AAA discounts... _________________ Stupid people do stupid things. |
Glenn Mr. 010
Posted: Fri Apr 25, 2014 2:47 am Post subject: |
Last night I was invited to a open house at IMC (a national parts wholesaler). They had a number of parts suppliers including Bosch, Sach, Mahle and Ligui Moly lubricants.
I talked to all of them about the needs of aircooled VW owners and all were responsive to my concerns about maintaining high quality and parts availability. When I talked to the rep from Liqui-Moly about the needs for lubricants he gave me the contact info for the experts back at their German office.
Here's what I asked:
Quote: |
What gear lube should I use for a 74 Beetle transaxle with a ZF LSD differential? I recently had it rebuilt and the builder told me to use Valvoline GL5. I'm going to change it and want to make sure I have no problems with the brass syncros and it need to have the friction modifiers for the ZF limited slip. |
Here's his reply:
Quote: |
Dear Mr. Glenn
thank you very much for contacting us and your interest in our LIQUI MOLY products.
We recommend you to use our LIQUI MOLY HYPOID GEAR OIL GL5 SAE 85W-90 LS for the beetle.
This is a mineral based hypoid gear oil which contents limited slip additives for the differential lock system.
Attached you´ll find the product informations :
We hope we could help you with our informations. Should you have further questions regarding our products we would be very pleased to get contacted from you again.
Mit freundlichen Grüßen / Best regards
i. A. Steffen Niemietz
Anwendungstechniker
application engineer |
Draw your own conclusion. _________________ Glenn
Member #1009
#BlueSquare |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Fri Apr 25, 2014 3:21 am Post subject: |
I had wondered about the LS graded oils, as LS diffs had definitive failures due to the extra additives in early GL5 oils. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Fri Apr 25, 2014 6:29 am Post subject: |
Glen
I'm not familiar with the Liquid Moly oil, but I concur with the suggested dino GL5. However, if you're referring to the ZF which is now running my discs, you don't need a special oil, or any added friction modifiers. Your LSD may be ZF, but your discs & plates are now GT, which are extremely durable. Friction modifiers are needed only to eliminate an irritating chatter, and will often have an affect on synchronizer action. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Glenn Mr. 010
Posted: Fri Apr 25, 2014 6:38 am Post subject: |
gears wrote: |
However, if you're referring to the ZF which is now running my discs, you don't need a special oil, or any added friction modifiers. |
They are your discs, it was rebuilt by Bruce.
It runs much better than before... thanks for providing a great product. _________________ Glenn
Member #1009
#BlueSquare |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri Apr 25, 2014 9:40 pm Post subject: Gear oil |
Using this:
Amsoil 80W-90
AMSOIL 80W-90 Synthetic Gear Lube is a multi-functional product designed to surpass the requirements of equipment and automotive applications calling for an SAE 80W-90 viscosity grade. Formulated with wax-free synthetic base oils and high quality additives, AMSOIL 80W-90 Synthetic Gear Lube resists thermal breakdown. Its naturally high viscosity index and shear stable construction improves film strength and viscosity retention. AMSOIL 80W-90 Synthetic Gear Lube prevents wear, resists heat, and protects gears. It lasts longer in service than conventional gear oils and increases equipment life.
AMSOIL 80W-90 Synthetic Gear Lube provides:
High Load Gear and Bearing Protection
Longer Oil and Equipment Life
Lower Maintenance Costs
Compatibility With Conventional and Synthetic Gear Lubes
Multi-functional for Multiple Applications
APPLICATIONS
AMSOIL 80W-90 Synthetic Gear Lube is recommended for use under various combinations of high-speed, shock loads, low speeds and high torque conditions. It is recommended for use in all light and heavy-duty, automotive, commercial or industrial applications requiring SAE 80W-90 EP gear lube. AMSOIL 80W-90 Synthetic Gear Lube replaces all conventional 80W-90 gear oils and exceeds the lubrication and performance requirements of front and rear differentials, transfer cases, transaxles, manual transmissions, s oil lubricated wheel bearings, and steering gear boxes that require any of the following specifications:
API GL-5 & MT-1
MIL-PRF-2105E
Dana SHAES 234 (Formerly Eaton PS-037) for 250,000 miles
MACK GO-J
Arvin/Meritor 0-76D plus hypoid gear oil specifications from all domestic and foreign manufacturers such as GM, Ford and Daimler Chrysler.
Can also be used rear axles where API Service GL-4 lubricant is recommended.
TYPICAL TECHNICAL PROPERTIES
SAE 80W-90
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
16.0
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
128.1
Viscosity Index (ASTM D-2270)
133
Brookfield Viscosity, cP (150,000 Max) @-26°C
40,482
Flash Point °C (°F) (ASTM D 92)
216 (421)
Pour Point °C (°F) (ASTM D 97)
-42 (-44)
Falex Procedure B (ASTM D-3233) (failure load, lbf.)
2000
Foam Stability (ASTM D-892)
0/0/0
For product service life in differentials, consult your owners manual or the Original Equipment Manufacturer (OEM) to establish the application, NORMAL or SEVERE.
Normal Service
Severe Service
Cars, SUVs, Light Trucks Drain at 100,000 miles of service or according to the owners manual, whichever is longer Drain at 50,000 miles of service or according to the owners manual, whichever is longer
Heavy Duty Class 8 Line Haul Follow the OEM drain interval (miles or hours) for synthetic oil up to 250,000 miles or three years, whichever comes first.
Vocational/Delivery Follow the OEM drain interval (miles or hours) for synthetic oil up to 120,000 miles or three years, whichever comes first.
Heavy Duty Off-Road Follow the OEM drain interval (miles or hours) for synthetic oil up to 100,000 miles or two years, whichever comes first.
For product service life in non-differential applications, consult owners manual or the OEM for either normal or severe synthetic oil service intervals. Where service intervals are unavailable, drain at twice the interval for conventional oil.
Note: AMSOIL does not support extended drain intervals where water contamination occurs. Check and service the gear oil frequently when water contamination is possible.
Gear oils should be changed more frequently when operating vehicles or equipment in dusty or dirty conditions unless the gear system is properly sealed and equipped with membrane type breathers.
AMSOIL 80W-90 SYNTHETIC GEAR LUBE is compatible with synthetic and conventional gear oils, however mixing oils reduces the benefits and nullifies the extended service life recommendations.
AMSOIL 80W-90 SYNTHETIC GEAR LUBE is compatible with most limited slip differentials. If limited slip differential chatter occurs, add AMSOIL Slip-Lock friction modifier additive.
AMSOIL has optimized gear lube performance for specific operating conditions. However, AMSOIL gear lubes are multi-functional and may be used in many different applications. This chart conveys the best AMSOIL recommendation based on product design and operating environment.
HEALTH & SAFETY
This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). An MSDS is available via the Internet at www.amsoil.com or upon request at (715) 392-7101. Keep Out of Reach of Children. Don’t pollute.
For warranty information, visit www.amsoil.com/warranty.aspx. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Sat Apr 26, 2014 1:48 am Post subject: |
I don't think we needed the whole blurb there. The other side of the coin is interesting, a local oil tech guy said the reason a lot of GL-5 oils say not to use them with LSDs is due to certain older types that were very popular which used a copper-containing material in the friction cones or clutches that broke down under the same high additive conditions that mining trucks and tractors love. The same manufacturer produces a synthetic lube that is both GL-5 and compatible with LSDs but I never got a straight answer if this meant it was good for our transaxles. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Sun Apr 27, 2014 9:58 am Post subject: |
Just an update because we all know we like to see them, it's been almost a month since I've changed the oil in the trans with GL-5. As the bug is a semi daily driver it has made a huge improvement in the way it runs, it is smooth, quiet, and shifting is like a hot knife through butter. _________________ Stupid people do stupid things. |
gears Samba Member
Posted: Sun Apr 27, 2014 1:54 pm Post subject: |
One thing I will say about amsoil is their marketing strategy. Make every Joe a "dealer", and the spam flows freely.
If a manufacturer warns you about using their GL5 with brass components, I'd listen. And then move on to a different manufacturer of GL5.
The Porsche GT3 street car uses brass discs in its LSD. What a joke. Those discs become slick almost as quickly as the old 993 carbon street discs.
It's interesting to note that the brass discs seem unaffected by a wide variety of GL5 oils (from the few hundred oily brass discs I've replaced). That is, the material hasn't scuffed, torn away, or even discolored .. the discs have merely become slick. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Sun Apr 27, 2014 3:14 pm Post subject: |
The disks become slick from the layer of copper sulphate/oil that builds up on them. Just because you don't understand a problem, doesn't mean it doesn't exist. Having this level of additives is not a fault, it is done to meet the original requirements of the specification. While it is great they have come up with alternatives that work with LSDs and transaxles, they don't work as well in the original applications GL5 was created for and these guys will seek out the "real deal." _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
gears Samba Member
Posted: Sun Apr 27, 2014 4:10 pm Post subject: |
The "Real Deal" is a GL5 that contains no sulfur. And these discs are going slick with ANY type of oil .. that I understand clearly. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Sun Apr 27, 2014 6:52 pm Post subject: |
No, have a look back. GL5 was originally a lubricant with high levels of additives containing phosphorous and sulphur, and those specs for heavy earthmoving equipment still do. About the time they came out I was working at a mine/processing plant that used H2S in it's processing, so I am well familiar with the black slippery surface you witnessed. There was a constant odour of both the bad egg smell of H2S and ammonia in the air and the copper test strips would change colour over time. The good news (?) is that you can't smell H2S when it gets to lethal levels, so we had to carry gas detectors to tell us when to don our masks. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
gears Samba Member
Posted: Mon Apr 28, 2014 5:51 am Post subject: |
Great input .. but you've misread what I said.
gears wrote: |
... It's interesting to note that the brass discs seem unaffected ... That is, the material hasn't ... even discolored .. the discs have merely become slick. |
'87 Syncro GL 2.5
