fatpaulie Samba Member
Joined: November 14, 2007 Posts: 60 Location: westport TN
Posted: Sat Jan 26, 2008 3:54 pm Post subject: changing brake drums |
ok heres the story--- i have a 1973 standard with 4-lug drums on all 4 corners, my question is will drums from diferent years fit? im wanting ti change to a 5 lug pattern. |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Sat Jan 26, 2008 4:16 pm Post subject: |
Does your standard have cable brakes? I know standard beetle brake drums are getting hard to find... _________________ die schwarzen Schafe #666 |
Posted: Sat Jan 26, 2008 4:45 pm Post subject: |
Alan Willis wrote: |
Does your standard have cable brakes? I know standard beetle brake drums are getting hard to find... |
not sure if i understand your question. but if your asking what i think, then no they are hydrolic, with brake fluid going to all 4 drums. |
Alan Willis Banned
Posted: Sat Jan 26, 2008 5:27 pm Post subject: |
Oh,yours is a newer standard beetle. Earlier standards had cable brakes!
I don't have the specs on later model standard beetles,as they're hard to find here in the states,but you could call BFY Obsolete and order a set of redrilled drums. Make sure you tell them that they're for a standard beetle and not a deluxe _________________ die schwarzen Schafe #666 |
Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Sat Jan 26, 2008 5:29 pm Post subject: Re: changing brake drums |
fatpaulie wrote: |
Are you talking five lug early VW pattern?
If so you use 66-67 beetle drums up front. ( five lug balljoint )
and you can use thing drums or early Type three drums in the rear.... Or adapters, but they space you out. _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Sun Jan 27, 2008 9:22 am Post subject: |
The book "Baja Bugs and Buggies" covers the complete conversion from 4 lug to 5 lug with pictures, part numbers and detailed instructions. It also gives options for using Thing rear drums or converting to larger Type III rear drums.
Alan, Your BS is not needed on the technical forums. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
