phip Samba Member
Joined: July 25, 2007 Posts: 463 Location: Pittsburgh, PA
Posted: Thu Oct 09, 2008 1:12 pm Post subject: |
| Quote: | | Education: 2000 - Present Hopkins High School Minnetonka, MN |
haha chill out, he's in highschool!
PS: I am loving this thread very much! We need more sharing of ideas and materials what works, what doesnt for sound and heat-proofing! |
Stuggi Samba Member
Joined: October 16, 2007 Posts: 1212 Location: Jakobstad, Finland
Posted: Thu Oct 09, 2008 1:16 pm Post subject: |
| theizzardking wrote: | | Stuggi wrote: | | The most dense and effective (thickness vs. insulation-properties wise) insulation you can get your hands on today is polyurethane sheets (sheets made out of the same stuff as expanding foam, only denser). Those sheets, which sadly are stiff, combined with expanding foam as glue, with proper ventilation, is probably the best way to insulate just about anything, and since they don't have to be very thick to do their work (100mm - 150mm is what's needed to insulate a modern house wall here in Finland, and temps are known to drop as low as -30 C in the winter, bearing in mind that those specs are for houses constantly kept at +20C - +25C indoors with as little heat leakage as possible) you should be good with as little as 50-100mm. The only downside is that it's probably one of the most expensive types of insulation available, but it's still not as expensive as some sound-insulation sheets for cars... |
your crazy babel of metric speech has me confused...hahah j/k
i thought about this stuff before , and am thinking of using it in certain areas just seems very hard to work with, and it all come down to "r" value
is the "r" value that much higher than the bubble stuff? do you have photo's with your material being used does anybody? thanks! |
Sadly I've already plastered all the walls in my house that use this, but it's like a sheet made out of extremely rigid packing peanuts, it has almost no flexibility. Here's a pic of a pretty thick sheet, it's the yellow thing in the middle. It cuts easily with a normal saw, like one you would use for 2x4's... _________________
1970 Beetle
1969 Panelvan
Orange VW Fest!
Pulled out of a Lake Fest!
theizzardking Samba Member
makes sense, high school kids...it makes me wonder if i was really that dumb t that age...i think the answer probably is "yes" haha! it's wierd being in your 20's getting ready for your first high school reunion, wow i'm old. haha! any ways back on point,
does any know what the peel and seal is made from? my understanding is it's just sticky back alum. foil. am i wrong? i will totally check it out next trip to hd or lowes! _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
panic_fan Samba Member
Joined: April 21, 2008 Posts: 458 Location: Stockbridge GA
Posted: Thu Oct 09, 2008 1:41 pm Post subject: |
| theizzardking wrote: | makes sense, high school kids...it makes me wonder if i was really that dumb t that age...i think the answer probably is "yes" haha! it's wierd being in your 20's getting ready for your first high school reunion, wow i'm old. haha! any ways back on point,
does any know what the peel and seal is made from? my understanding is it's just sticky back alum. foil. am i wrong? i will totally check it out next trip to hd or lowes! |
I bought some. Here is the MSDS sheet, what its made of etc.
Doesnt look like any inhalation dangers only toxic if you eat it, so dont eat it.
http://www.mfmbp.com/pdf/msds/MSDS-SA.pdf _________________ Rich
Brilliant Blue/Cloud White
1970 Baywindow Bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=291988&highlight=
"Still learnin the way around my VW bay"
BellePlaine Samba Member
Posted: Fri Oct 10, 2008 10:27 am Post subject: |
| Quote: | | does any know what the peel and seal is made from? my understanding is it's just sticky back alum. foil. am i wrong? i will totally check it out next trip to hd or lowes! |
If anybody has luck buying this at a big box store please let us know. I need to find something that is easy to find, not very expensive, and won't piss me off if I want to take it out years from now. And I don't need the toxic fumes either I guess.
Lowes/HD only sells Reflectex via Internet order in all of the stores have way located in my area of the Twin Cities so I guess I'm screwed anyway. I don't know about you guys but the wife is more concerned about the $ I'm spending on the bus when packages mysteriously arrive vs a quick trip to HD. _________________ '75 Riviera |
Posted: Fri Oct 10, 2008 10:56 am Post subject: |
that's weird bot hd and lowes had reflectix here i just picked some yesterday.... any other hardware stores maybe try a different branch, they should have it. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1320 Location: Charleston, SC
Posted: Fri Oct 10, 2008 11:21 am Post subject: |
It may depend on certain regions for each of the stores. I know that I have purchased the Peel and Seal at one Lowe's and visited another Lowe's in a different part of the state and they carried a different name, but same type product. _________________ tangerinemoons.com
My Bus Restoration Blog
http://myvwbus.tangerinemoons.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
jah_B Samba Member
Joined: March 18, 2008 Posts: 1148 Location: Tempe, AZ
Posted: Fri Oct 10, 2008 11:41 am Post subject: |
Wait wait... what?
atomic #13 is aluminum...ok.
from this:[url] http://toolsmet.com/roofing/[/url]
Self-adhering sealing stuff featuring a deliberating atomic number 13 come up. Multiple laminations of specific atomic number 13 enhancer, high-density polymer films and a deep bed of rubberized mineral pitch sealing combine. Easily installed by removing the free bank-notes and urgent the al tissue layer into localise. Cut to primed using pair of scissors or razor stab. Lightweight, stretches to grant because building social movement, won't check or juiceless come out, imperviable to species of cellular cryptogam acotyledon, algae or bacterium. Uses: Dormer and the stoic philosophy roofs, little commercial-grade, take on lease buildings, roving homes, piece mineral pitch roofs, resort metal surfaces. 36" W. x 33-1/2' L. 100 sq. ft. by undulate. Available in atomic number 13, snowy, and grey-haired finishes.
sign me up for free bank-notes. _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
1972 tintop P30 CAMPMOBILE: M/T, 1.7L, dual kadrons, 019 diz. Sunny the S'kool Bus
You gotta know what you don't know. That's the key to wisdom. man.
Posted: Fri Oct 10, 2008 11:52 am Post subject: |
i love people who make something sooo simple sounds soo hard, like getting trained for a job t a video store when i was in college, they made it seem as if it took some genius to check a movie out to someone, JEEZZ-USSS  _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
phip Samba Member
Posted: Fri Oct 10, 2008 1:35 pm Post subject: |
IzzardKing: Were they retail video engineers?
All: Does anyone know of any other good low-cost materials besides Peel & Stick and Reflectix? |
Posted: Fri Oct 10, 2008 2:00 pm Post subject: |
hahah jerk! j/k though.
cheaper than refletix? it'll run you like $ 80 to do the whole bus with like 1.5 layers. i don't know about the peel and seal , i just picked up the reflectix stuff yesterday for 25 or 27 dollars a roll. if that's to expensive.
get a whole bunch of old blankets and pillows and crap stuff them in garbage bags (triple bag it) and chuck that in there. i can't see anything being cheaper than the reflectix stuff though.
i'm poor as well, but i found you can do a whole bus with 3 medium size rolls of the reflextix, if it takes you a week or 2 to get it all so be it i usually just do one roll @ a time. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
phip Samba Member
Posted: Fri Oct 10, 2008 2:06 pm Post subject: |
| No no, not cheaper than, I'm just trying to stir up other good low cost materials like these that have been discussed. |
Tyranicon Samba Member
Joined: September 02, 2008 Posts: 7 Location: Dewey OK
Posted: Mon Oct 13, 2008 12:32 am Post subject: |
Just an alternative idea that might be good for use in those hollow spaces and cavities in the bus...
How about the new DEMILEC (USA) non-toxic spray foam insulations such as SEALECTION® 500? Probably won't be cheap but it supposedly is able to expand and contract with the surface it is adhereing to. The open-celled foam seals out air, reduces extraneous noise and is thermally efficient. Water vapor can still pass through and evaporate so molds and rust don't grow. It's normally used in structures like metal buildings and etc. Oh yeah and it's also supposed to be "green" for those of us who might be environmentally friendly folk.  _________________ 76 Westy
68 Karmmann Ghia Convertible
64 Beetle
64 Sunroof Beetle
"The advantage of a bad memory is that one enjoys several times the same good things for the first time." -Friedrich Nietzsche |
kennypg79 Samba Member
Posted: Mon Oct 13, 2008 1:51 am Post subject: Had to throw in here.... |
I did my insulating job bus last year.
1. Roof flashing tape - aluminium and asphalt (there was a link from a previous poster). All over the body on the inside, in the engine bay, on the roof. The difference was absolutely amazing. you could knock on the roof before you put it on and hear tinny echoes. After it was a dull clunk. great stuff. No issue in the engine bay, no smell after it goes on. I used a heat gun to seal it on each surface.
The bus is quiet enough to have a low conversation at 60mph
2. Actis multifoil (called the nasa bubblewrap stuff) - it has 15 layers, 5 foils and 10 closed cell sheets - like very thin bubblewrap. I have this on the roof, floor etc. but it is yet to go in to the sliding doors (twin sliding).
Have not been cold yet.....
3. Closed cell foam will go into the sliding door cavities, though it will be done when it is warm and dry and sealed up afterwards.
4. I have aftermarket HeX... which i am changing for the original ones after a re-furb. I want excess heat to help warm up after an atlantic surf, only 30degrees C (about 90F) inside will do!
Since this is my first post on theasmba, and i have been an avid fan of everything bay related on the samba for about a year now.... i thought i'd post a link to my resto pics, I am a member of type2ireland:
http://publish.photobox.co.uk/Paul/Manana.html |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1018 Location: S>E>Alabama
Posted: Mon Oct 13, 2008 5:16 am Post subject: Cabin Insulation |
Good looking bus!!Now that you have the bus insulated well it is time to hop up the heating system: Make sure all controls open the heat exchanger; Insulate the heater pipe all the way from the accordian bellows foward witheither prrl and stick or bubble wrap.Some of the ares will be difficult but well worth itAND catch that wave  _________________ 71 Westy, Quintilla 67 912 Porsche 67 SC currently in paint!! |
Posted: Mon Oct 13, 2008 5:55 am Post subject: |
I'm going for 2 different directions.....
1st one is straight out of the Hex through the bulkhead and into the rear of the cab. The seccond is the stock direction, except through a lot of insulation.
I am expecting 200f out of the direct line in. It'll be hawaii in the rear! |
Posted: Mon Jan 05, 2009 9:57 am Post subject: |
Finished my weekend Project. Peel n Stick'd the interior firewall and cargo area. MUCH quieter now, I can still hear the hummm of that classic VW engine, but can now hear my radio and passengers as well.
-Smell went away after about 2 days with the doors opened in the garage.
-Cleaned up & Used small heater to make sure metal was nice and warm to stick too.
1970 Baywindow Bus
chazz79 Samba Member
Frozenbutt Samba Member
Joined: December 14, 2005 Posts: 178 Location: Near Toronto, Ontario
