Plugging oil galleys article...
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
gcorrado
gcorrado is offline
PostPosted: Wed Feb 06, 2008 3:22 am    Post subject: Reply with quote
tim240 wrote:
It actually looks as if it is blocking the complete hole
That area between the oil gallery and the thinner part of the plug is what makes the restriction.
yup.
the simple math john was talking about is that we can calculate the effective size of the orifice by computing the cross-sectional area of the gallery, and subtracting the cross-sectional area of the thinner part of the plug. since the oil has to squeeze between the two of them, it's the difference of those two areas that matter. now if we want to make our own single hole that has about the same flow, we just drill a hole in our NPT plug that has that same area as what we calculated. to be on the safe side we could increase it by 30% or so.
tim240
tim240 is offline
PostPosted: Wed Feb 06, 2008 11:09 am    Post subject: Reply with quote
I thought about this route as well. I was also thinking that if the hole in the bearing is restrictive enough and only becomes a problem apon wear maybe the hole in the plug should be close to this size(not being subject to wear).
Jimmy111
Jimmy111 is offline
PostPosted: Wed Feb 06, 2008 11:31 am    Post subject: Reply with quote
Ok what you need is to take a piece of aluminum that will fit with a interferance fit in the hole in the bearing saddle. cut it to about 20mm in length and drill a 3mm hole in the center. use a 10mm drill bit and cut a concave survace where the hole is so it wont push up against the bearing and cut off flow. Push it into the oil gallery. The reason for the concave surface is that the hole in the bearing is about 2mm and it may not line up correctly with the hole that you drilled.
redhot
redhot is offline
PostPosted: Tue Feb 19, 2008 2:33 pm    Post subject: Reply with quote
I was at rimco picking up a case and asked them about said plug. They showed me a block cut in half to expose the oil galleries. That plug does cover the hole but only where the plug steps down. That area between the oil gallery and the thinner part of the plug is what makes the restriction.
If someone could post pictures of such, it would be a great help and of course simply interesting![/i]
tim240
tim240 is offline
PostPosted: Tue Feb 19, 2008 5:19 pm    Post subject: Reply with quote
I'll probably end up down at rimco for something in the next couple of weeks. When I go I'll bring my dig. camera and take a picture of the cut case where the oil gallery is.
neil68
neil68 is offline
PostPosted: Tue Feb 19, 2008 5:50 pm    Post subject: #4 bearing oil supply Reply with quote
I've noticed that the more recent #4 OEM bearings have an even smaller oil hole. Is this perhaps a change designed to compensate for the new aluminum cases that may not have the stepped oil gallery plug, since some are already tapped for pipe plugs?
Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
bugninva
bugninva is offline
PostPosted: Tue Feb 19, 2008 6:36 pm    Post subject: Reply with quote
you guys want me to run to the basement and pull one of those plugs out? can get pictures and measurements...
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
Jimmy111
Jimmy111 is offline
PostPosted: Tue Feb 19, 2008 7:09 pm    Post subject: Reply with quote
I have a drawing with the dimentions of the restrictor on page 11 of the other oil flow topic.
bugninva
bugninva is offline
PostPosted: Tue Feb 19, 2008 8:00 pm    Post subject: Reply with quote
Jimmy, i have posted your drawing below to answer the folks questions about size of the restrictor...hope this is okay.
GEX has. Just sayin
bugninva
bugninva is offline
PostPosted: Tue Feb 19, 2008 8:09 pm    Post subject: Reply with quote
the plug i just removed agrees with Jimmy's drawing.
GEX has. Just sayin
VeeDubya
VeeDubya is offline
PostPosted: Tue Feb 19, 2008 11:59 pm    Post subject: Reply with quote
The restriction is not created by depth of the plug, but rather the orifice created. So ideally we'd want a longer (17mm) plug, threaded 1/16" NPT, necked down to 5.40 mm, to create the desired orifice. Correct?
'65 Beetle
koolkarmakombi
koolkarmakombi is offline
PostPosted: Wed Feb 20, 2008 5:58 pm    Post subject: Reply with quote
Could you post a link to that post? Cant find it...
VeeDubya
VeeDubya is offline
PostPosted: Wed Feb 20, 2008 6:03 pm    Post subject: Reply with quote
look 3 posts up
edit: sorry 4 posts up! Rolling Eyes
'65 Beetle
neil68
neil68 is offline
PostPosted: Wed Feb 20, 2008 6:16 pm    Post subject: #4 bearing Reply with quote
So, if the #4 bearing has a tiny oil hole, doesn't that act as a restrictor?
Neil.
VeeDubya
VeeDubya is offline
PostPosted: Wed Feb 20, 2008 6:38 pm    Post subject: Reply with quote
I'd also like to hear of anyone who just plugged it with a NPT plug. Intereested if they experience the oil issues that have been described.
'65 Beetle
bugninva
bugninva is offline
PostPosted: Wed Feb 20, 2008 6:56 pm    Post subject: Reply with quote
i have done several over the years with no oil problems at high rpms.... very high mileage i don't know....
GEX has. Just sayin
VeeDubya
VeeDubya is offline
PostPosted: Wed Feb 20, 2008 6:58 pm    Post subject: Reply with quote
What has been said sounds logical and feasable, it's just amazing that this is the first time it's been mentioned... or at least the first time I've read it.
'65 Beetle
A.J.Sims
Banned
Location: LowBugget.com 982 N Batavia A4 Orange Ca 92867
A.J.Sims is offline
PostPosted: Wed Feb 20, 2008 7:26 pm    Post subject: Reply with quote
I can show you a easy way with out making any parts and you can use the parts you have! Give me a call at the shop if you still need help.
714-639-4284 ask for A.J Very Happy
Have tech questions? Need real help? Give us a call.
www.Lowbugget.com
982 North Batavia A4, Orange Ca 92867.
68 drag bug 1915cc 10.50's @130mph
66 fastback 2387cc turbo street car
67 baja 2054cc turbo.
MConstable
MConstable is offline
PostPosted: Wed Feb 20, 2008 8:40 pm    Post subject: Reply with quote
C'mon now AJ...shoot us the info...stop teasing Smile
1974 Thing
VeeDubya
VeeDubya is offline
PostPosted: Wed Feb 20, 2008 8:54 pm    Post subject: Reply with quote
No doubt A.J.! Razz
'65 Beetle
Page 2 of 7
