JoeGiul Samba Member
Joined: December 17, 2006 Posts: 61 Location: Wilmington Delaware
Posted: Sun Feb 10, 2008 1:16 pm Post subject: How tall of a tire for this combo in the quarter? |
Hi all,
What is the best size tire to run the quarter in with this combo:
68 bug, about 2000lbs with me in it
Tranny: 3:88 R&P, stock 1st, 2nd, 1.44 3rd, 1.04 4th, welded in mid mount and engine hangar traction bar
dyno chart:
www.drdracingheads.com/images/1914.JPG
Specs:
69X94mm 9.00 compression
Engle 130 cam, 1.1 rocker
42X37.5 ported heads
Dual 51.5 webers, 40mm vent
1 5/8 header
These numbers were with the belt and muffler on, air fuel ratio WOT 12.7.
Joe _________________ 68 Cal Look Bug
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Sun Feb 10, 2008 1:48 pm Post subject: |
why 51.5mm IDA's on a small engine with 42mm intakes?
Anyway,is this going to see any street time? if it is,run a 205 65. If not,run a 205 60 _________________ die schwarzen Schafe #666 |
Posted: Sun Feb 10, 2008 8:32 pm Post subject: |
Thanks for the tire size help, I will run this car on the street a little but just for fun, I'd be willing to sacrifice some street drivability if the tire size will improve the time.
It is way over carbed...but those are the only set of carbs I have and I don't want to get rid of them or have them lay around the garage and collect dust. Instead of buying another set of carbs I'm saving my money and slowly collecting the parts for my dream motor...so far I have the push rod tubes and a gasket set
I also need to buy a good set of wheels and tires, I think I'm going with centerlines _________________ 68 Cal Look Bug
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76947 Location: Sneaking up behind you
Posted: Sun Feb 10, 2008 8:44 pm Post subject: |
If you have strong tranny, you could try a set of M&H Cheater Slicks.
But they are 26" tall and with a 3.875 r/p and a stock 1st, you might not have enough torque to take advantage of them. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Feb 11, 2008 6:14 pm Post subject: |
Glenn,
I like the RPM and speed numbers that are generated when I plug my gear ratios and the 205-60 tire size into the tranny calculator you posted a while ago
that tire is 24.6 inches tall
Does anyone make a slick that is the same height? Would this car/motor combo benefit from a slick? _________________ 68 Cal Look Bug
