notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Wed Feb 13, 2008 1:46 pm Post subject: bead leak on original sprint stars |
I've got a set of original 4 lug sprint stars and two of them have bead leaks. I checked them out in the bath tub yesterday, and both are leaking in the front. One has a space about 3" long where it leaks and the other is on several spots around the front bead. I broke them back down and checked and the tires and rims are both clean. The rims do not have any rust around the bead, but they just will not seal all the way up. Does anyone have suggestions for what type of bead sealer to get? I did some searching on the 'net and have found spray, brush and silicone type of sealers. What's the best? Or should I just run with tubes? One rim is 4.5" and the other is a 5.5". I'm running 185/65R15s.
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17969 Location: Eugene, OR
Posted: Wed Feb 13, 2008 1:55 pm Post subject: |
Tubes! |
bugnbyke Samba Member
Joined: April 13, 2006 Posts: 84 Location: Jacksonville
Posted: Sat Mar 01, 2008 6:33 pm Post subject: |
Try bead glue. worked for me |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Sat Mar 01, 2008 6:49 pm Post subject: |
The black bead sealer works great. It has the brush. _________________ die schwarzen Schafe #666 |
Posted: Sat Mar 01, 2008 8:28 pm Post subject: |
I bought some bead sealer at NAPA last week. I broke the bead on the tires, cleaned both the tire bead and the rim very well, applied the sealer and it's working great. I just wish they had smaller cans. This 32 ounce can is a lifetime supply for me.
zeen wrote: |
FU#3 |
