michael_motorcycle@hotmai Samba Member
Posted: Fri Feb 21, 2003 6:18 pm Post subject: fuel pump? |
| Looks like my fuel pump is gone,diaphram I guess,looked into a new one wholly expensive,someone suggested just taking off manual and push rod and putting in a low volume electric pump,could someone please give me advice on this,sounds reasonable. |
wgargan Samba Member
Joined: September 21, 2002 Posts: 938 Location: Dreaming of the Rockies
Posted: Fri Feb 21, 2003 7:00 pm Post subject: fuel pump? |
what year. i might have a stock pump for you.
lc |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2528 Location: Edmonton, AB
Posted: Fri Feb 21, 2003 7:49 pm Post subject: fuel pump? |
| Is your engine carb'd or fuel injected? |
Posted: Sat Feb 22, 2003 11:51 am Post subject: fuel pump? |
| To answer both your questions its a dual carb'd 1800 out of a 73westy |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2400 Location: ontario canada
Posted: Sat Feb 22, 2003 2:08 pm Post subject: fuel pump? |
| if you go electric, you will need a pressure regulator. |
Posted: Sat Feb 22, 2003 2:22 pm Post subject: fuel pump? |
| what's your time worth? bus depot has stock fuel pumps for $100. at CIP1, you can get a facet electric pump for $35, but you need a pressure regulator ($26), a pump block off plate ($5), a mounting bracket ($5), plus you need fittings and clamps ($15). total cost in parts to go electric: $86. So you save $14... but, replacing a stock pump is a pretty simple process, taking less than an hour. if installing an electric pump count on wasting the better part of an afternoon, breaking at least one drill bit, spilling gas all over the place after you cut the lines, and needing to buy at least one wrnech, because you can never find all the tools you need, when you need 'em... and then dialling in the system. To me, there is no real advantage. |
Posted: Sat Feb 22, 2003 3:35 pm Post subject: fuel pump? |
sorry dont have one.
lc |
Posted: Sat Feb 22, 2003 5:11 pm Post subject: fuel pump? |
| Thanks I'll go with a new stock pump,sounds like its not worth it for the electric and more hassle. |
