5 Spoke, Narrowed Beam, Dropped Spindles, Wide 5 Disc Brakes
Goto page Previous  1, 2, 3  Next
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Hotrodvw
Hotrodvw is offline
PostPosted: Tue Mar 04, 2008 8:42 pm    Post subject: Reply with quote
Here's mine before the drop spindles.... CB 2'" beam, CB wide 5 disc brakes, 145's.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost lots of money!
Hose & Fittings
vdub66
vdub66 is offline
PostPosted: Sun Mar 09, 2008 9:50 pm    Post subject: Reply with quote
Hey all,
Thanks for all the suggestions.
Hotrodvw: THAT'S WHAT I'M TALKING ABOUT. Nice looking ride.
I'll post pics when I get mine done.... might take a while though.
Family owned since new '66 Type 1, now with a 1776 w/dual 36 Del'Ortos & freeway flyer.
Hotrodvw
Hotrodvw is offline
PostPosted: Sun Mar 09, 2008 9:57 pm    Post subject: Reply with quote
Post 'em up! Cool
'67 Sunroof
Eric
Hose & Fittings
Neil Davies
Neil Davies is offline
PostPosted: Wed Mar 12, 2008 5:29 am    Post subject: Reply with quote
I've got the CB 2" narrowed beam, dropped spindles and disc brakes for my '51 (although it's all still in boxes!), and will run Flat Four BRMs with that set up. I looked into it a little bit before I bought it - the idea of the 2" narrowed beam is that the extra width of the spindles AND the discs will be taken up by the reduction in width of the beam, leaving the wheels pretty damn close to where they would be with a stock set up. If you want the narrowed look with the spindles and discs then you'll need to narrow the beam some more.
'51 Split Beetle Cal Look project - sold!
'68/'70 Beetle, wife's mild Cal Look 'vert project - on the back burner
'67/'68 Beetle Cal Look daily driver - motor build progressing slowly
'70/'73 Beetle Cal Look caged drag race car - just started!
www.outlawflatfour.com
volksheime
volksheime is offline
PostPosted: Wed Mar 26, 2008 3:54 pm    Post subject: Reply with quote
I want to run the same setup on my 66 sedan - Eagle 5 spokes, CB wide 5 disk w/ CB dropped Spindles and 4" narrowed beam w/ shocks. Going for a cal-look also. I have some 195/60 r15 tires on all 4's right now. I like the ride/ look of wide front tires on the front, right now they stick out about 3/4" on each side do to tire width. anybody running wider tires than 175/55 on the front with this setup? What kind of rubbing issues? Im not afraid to bang on my headlight buckets a little. Ive searched but no one is running this setup except on this thread. I will be running some 205's in back. thanks
Brad the noob Very Happy
sano66
sano66 is offline
PostPosted: Wed Mar 26, 2008 4:32 pm    Post subject: Reply with quote
CB 2 incher, Wide 5 discs, drop spindles on 5 spokes with 145 nankangs. Needs to be narrowed a couple more inches, see how close it is. It rubs the fender lip bad.
slantman
slantman is offline
PostPosted: Thu Mar 27, 2008 4:52 am    Post subject: Reply with quote
I'm looking at going down much the same road on my 65. The question I have is how narrow a beam can I fit without doing any body mods and still running shocks? Will a 4" narrow beam require any body work, as I really only want to do a bolt on job?
flyinglow94
flyinglow94 is offline
PostPosted: Thu Mar 27, 2008 9:22 am    Post subject: Reply with quote
On my 66 3" put me at the inner fenderwell with the shock tower. But the CB dropped spindles and the spacers and adapters kicked it out pushes it out an inch. But the ride is better than just the adjustable beam. I am also running 195/50/15 in front they rub a little when turning up the driveway I will buy some 175/55/15 from tire rack when i get a chance.
The adepter with the spacer with disc breaks.
I made a brake rail (like a fuel rail) to feed the duel circuit master cylinder and also to keep the original look of the single reservoir bottle.
"What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.."
flyinglow94
PostPosted: Thu Mar 27, 2008 2:12 pm    Post subject: Reply with quote
Oh I almost forgot I am running the Eagle Alloys 5 spokes and their offset is a little different than the Rocket 5 spokes. I machined about 7/16 off of the back pedestals witch give it the same offset and measurements as the rocket alloys. I had posted the Rim mods on the first page.
maggiolino basso
maggiolino basso is offline
PostPosted: Thu Mar 27, 2008 10:03 pm    Post subject: Reply with quote
I love the custom machine work. Wish I had garage/machine shop like yours..
"Give a man a fish, feed him for a day, teach a man to weld you feed him for a lifetime"
http://maggiolinobasso.blogspot.com/
maggiolino basso
PostPosted: Thu Mar 27, 2008 10:07 pm    Post subject: Reply with quote
64SunroofVW wrote:
Nice bug maggiolino basso...that's the look I'm going after...are those 145R15 tires you have on there? How is the ride? Any tire rubbing? I just cut out the rusty floor pans on my '64 chassis and am getting anxious to rebuild the steering/suspension/brakes. I just scored a VW king pin reamer on ebay and plan on rebuilding the king pin / link pin / spindles and plan on using the CB drop spindles.
At the time I took that picture I was running 175/55-15 Continental Smart Car tires out the front. The ride was much better than it is now (I am running 135s) I did not have any tire rubbing when I had those installed. Had better handling and traction specially in the rain.. Now I have some Continental Smart Car 145/55-15 tires on order from Tirerack.com when I get them mounted I will post some pics.
Lee.
Samba Animal Controller
Lee. is offline
PostPosted: Fri Mar 28, 2008 9:36 am    Post subject: Reply with quote
maggiolino basso wrote:
Here is a pic of my 66 with CB Performance wide five disc kit w/dropped spindles and 4" narrowed beam. I also had Continental 175/55-15 Smart Car tires in the front in this picture. They are available at Tirerack.com
Same beam except it's link pin, same spindles, same tires, same wheels. Stock drum brakes.
AnimalsInTheAttic
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Aug 09, 2008 5:56 pm    Post subject: Reply with quote
Just an FYI.......part of the point of having a dual circuit m/c is also having a dual circuit resivoir. They have a baffle internally, sepparating the front fluid from the rear. As it is now, if you have a leak in one of the circuits, you still lose all of your brakes. W/ a baffled resivoir, you still retain the fluid for the other circuit.......which means you can still stop. It's a nice piece, but a bad idea at the same time.
'67 Sunroof
Eric
Hose & Fittings
flyinglow94
PostPosted: Sat Aug 09, 2008 6:18 pm    Post subject: Reply with quote
Thanks for the concern. I am very aware of the dual circuit reservoir and its function. And when I locate a 67 reservoir I will probably change it. But I was not going to hack the car for two reservoirs or something that I would need to repair later. But the idea of the rail serves it s purpose and keeps the car body unhacked. My VW's are my toys not daily drivers but I do count on them at a moments notice some times.
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Aug 09, 2008 6:24 pm    Post subject: Reply with quote
But you count on brakes every time. Wink
'67 Sunroof
Eric
Hose & Fittings
Greg Armendariz
Greg Armendariz is offline
PostPosted: Thu Aug 21, 2008 3:02 pm    Post subject: rear wheels Reply with quote
Hey Guys,
I'm building a 56' Oval and I want it slammed low on smoothies. I have a 2" narrowed CB Beam and all 4 Disc brakes. Id like to know what size rear smoothies I should have made through stockton tire and what size tire would be best tucked under the rear fenders to fill it up. I have a new set of 205x60x15" tires that I could run but I'm not sure. I was told that the rear disc brakes will kick out 5/8". I'm also having a trans built and the builder is asking me if I want a short or long axles Shocked
Any help would be appreciated.
Maimas13
Maimas13 is offline
PostPosted: Thu Aug 21, 2008 6:10 pm    Post subject: Reply with quote
actually I was wondering the same thing while reading through this thread. Anyone have knowledge to share?
MAIMAS... read it backwards
(.o\ ! /o.) 62 chopped, dropped, cal looked, oval grafted, 57 styled, ragtop with polk audio sound system, driven daily by an 18 year old
A must read for understanding tires sizes and wheel offsets
Go Bears!!! Mech E
flyinglow94
PostPosted: Fri Aug 22, 2008 11:58 am    Post subject: Reply with quote
My 66 is at the edge of the body with a 3" narrowed beam and shock towers. At 3.5" I would need to start pounding the body for clearance.
Bigg Tim
Bigg Tim is offline
PostPosted: Fri Aug 22, 2008 1:38 pm    Post subject: Reply with quote
Does running the 4 lug to wide 5 lug adaptor cause, or have, any potential issues with safety? I have seen people say don't run adaptors, but if they work and are safe....why not?
flyinglow94
PostPosted: Fri Aug 22, 2008 2:58 pm    Post subject: Reply with quote
I have seen Porsche's run spacers that are 1"+ in the back. I don't think they would be produced for so many years and be a big issue. Insurance and ambulance chasers would have put these company's out of business a long time ago. It does widen the track and when we are trying to fit larger wheel/tire combos it doesn't help.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 3
