Official Bay Window engine pics thread
Goto page Previous  1, 2, 3 ... 20, 21, 22 ... 25, 26, 27  Next
Desertbusman
Desertbusman is offline
PostPosted: Tue Aug 23, 2011 7:46 am    Post subject: Reply with quote
All of my friends with big performance bugs also use the aftermarket breather boxes and vent the valve covers. I don't really understand why. Piston movement up and down is counteracted by opposing pistons. Seems like tho only air needing bleeding out of the case would be ring blowby and valve guides leaking. Seems like that would mainly be due to a worn out engine or one where the rings wern't broken in yet. Didn't you also run into leak issues at the cylinder bases and also pushrod tubes on another engine? There is hardly any air movement when I remove the filler cap. Evidently very little blowby.
The stock breather/fillers have the road draft tube plus the breather line to the oil bath. On wornout engines you can watch the oily vapors comming out the road draft tube. But I sure like my aftermarket filler. No problems but it has advantages.
The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
aeromech
aeromech is online now
PostPosted: Tue Aug 23, 2011 8:15 am    Post subject: Reply with quote
Yes, I did have problems with a different engine leaking and that turned out to be from poor breather volume as well.
Both of those engine weren't yet broken in so they probably did have excessive ring blow by. I've been down this road before with problems caused by not enough breather volume. It took me quite a while and a lot of work before I figured it out. I'm just trying to help the next guy avoid some self induced oil leaks.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Type 2 1971 (2 ea.) 1978
VW Jetta
VW Passat
poptop tom
poptop tom is offline
PostPosted: Wed Aug 24, 2011 8:27 am    Post subject: Reply with quote
Late to the party getting these pics posted. Better late than never!
Finished this build last October. Three days after installation, we drove it to Florida! I've got about 6,000 miles on the rebuild.
This engine features a Raby 9550 cam. I used his upgraded valvetrain kit, 42x36 valves. Mahle 94 mm P & C's (from Raby), porsche swivel adjusters, 72-74 HE's and tangerine exhaust (from Raby). My German heads were sent to Adrian at HeadflowMasters. He used the hardware purchased from Jake to rebuild the heads.
My C/R is 7.7 - 1. Deck height is .055".
The engine runs like a champ. I have a small oil leak I've yet to detect its origin. Otherwise, my head temps have never gone over 360 degrees. Oil pressure runs around 40 psi when fully warm running 70 ish down the highway. Oil temps range in the 220's, but have seen 235 degrees. Using a type 1 Shadek modified oil pump, and Brad Penn 20w 50 racing oil.
...make good money five dollars a day...
'76 Deluxe Campmobile ((finally on the road))
BusterBrown
BusterBrown is offline
PostPosted: Wed Aug 24, 2011 8:47 am    Post subject: Reply with quote
^^^ Inspiring addition to this thread. Thanks for that! I hope to pull this off someday when my engine needs it. I always say to myself, "Hey, if he can do it, so can I", but I know it's not always as easy as that. Wink
1978 Sage Green Westfalia
1969 Delta Green/Cloud White Transporter
1977 Senegal Red/Atlas White Transporter
Life is short. Can I have some of yours?
poptop tom
PostPosted: Wed Aug 24, 2011 9:15 am    Post subject: Reply with quote
Trsut me, Buster, if I can do it, you most certainly can, too. I did have some help, I will not lie. I run a golf course, and my mechanic was helpful. Especially with the valvetrain geometry work. That's tedious and tough.
Brionp
Brionp is offline
PostPosted: Tue Aug 30, 2011 12:25 am    Post subject: Reply with quote
Probably a brand new GEX motor that had the distributor drive installed 180 out and in the process of trying but NOT fixing the PO buggered up the brass gear so bad it probably never had a chance. After he let it season uncovered in the backyard for a year or so I had the pleasure of adopting it. I did not know 180 out back then, boy do I now. So anyways, last Thanksgiving, since everyone was down to celebrate anyways, myself and the rest of the males in the clan, both replaced the brass gear on a bedsheet on the driveway as per the Haynes, Bently, and Muir. Whichever was easiest. Oh, Tom Wilson was there too. So, now it has half a chance. And thats only a chapter in this manuscript. If it gets me back and forth to the dogpark while I work on the bus it will have served its purpose. Yesterday it ran for about ten or fifteen minutes. Next weekend I'll try to dial it in. I am learning. I think my eyes are open now. The Original one will be much, much, better. I see Rimco in my future. Don't tell the Little Lady. Wouldn't want to scare her. But. I'm not done yet... Especially with this one. Fun Times.
aeromech
PostPosted: Tue Aug 30, 2011 6:10 am    Post subject: Reply with quote
Good to hear Brion. Fine example of a work of art you have there.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
pitbug
pitbug is offline
PostPosted: Tue Aug 30, 2011 8:16 am    Post subject: Reply with quote
Almost ready to roll Very Happy
57' SC "Hoss" 1776cc (his)
62' Ragtop 1776cc (Wife's-"Candy")(hers)
71' Bus 1776cc "Sunshine" (ours, that's what she thinks!)
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Gallery Classifieds Feedback
babysnakes
babysnakes is offline
PostPosted: Tue Aug 30, 2011 11:34 am    Post subject: Reply with quote
Pumpkin powered Sunshine?
'69 SC under resto
'72 deluxe daily
'78 Westy motor transplant in progress
'71 super vert
1st bus, '67 Westy in '83. Thank you '74 Pontiac Ventura.
Luftwagens
420GOAT wrote:
..dont ever ever ever ever EVER, compare any bus forum to a bug forum...
pitbug
pitbug is offline
PostPosted: Tue Aug 30, 2011 11:48 am    Post subject: Reply with quote
Yea, well what can I say, the wife wanted some input, and since it's "ours"....lol the next battle is over the curtains....LOL Laughing
babysnakes
PostPosted: Tue Aug 30, 2011 1:26 pm    Post subject: Reply with quote
I hear ya buddy. Wink
'69 SC under resto
'72 deluxe daily
'71 super vert
Luftwagens
Brionp
Brionp is offline
PostPosted: Tue Aug 30, 2011 3:00 pm    Post subject: Reply with quote
Thanks Gary, I'm ready to kick Mona Lisa to the curb so she can show me if she has any skills. I know now that to make them pretty, is pretty mindless. I can do mindless. All Day, Every Day. From 5am until Midnight. That's Easy. The hard part still lies ahead. I have learned so much on this one, and have so much left to learn that I have trouble falling asleep. I can't shut it off.
Brionp
Brionp is offline
PostPosted: Mon Sep 05, 2011 5:38 pm    Post subject: Reply with quote
Here's a video of the motor. There is still a lot to do. But its getting there.
http://s338.photobucket.com/albums/n436/brionp/?action=view&current=MVI_1227.mp4
aeromech
PostPosted: Mon Sep 05, 2011 5:54 pm    Post subject: Reply with quote
Nice video but the narration was a bit dull. Hahahaha
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Brionp
Brionp is offline
PostPosted: Mon Sep 05, 2011 6:56 pm    Post subject: Reply with quote
Boy, It was a long day. Here's just one more. It sounds better in person, And I'm still working on the idle. But it will have to wait until next weekend.
http://s338.photobucket.com/albums/n436/brionp/?action=view&current=MVI_1247.mp4
pitbug
pitbug is offline
PostPosted: Tue Sep 06, 2011 6:40 am    Post subject: Reply with quote
Got engine in and running "Pumpikin Power!" 1776cc Very Happy
kjbtsi
kjbtsi is offline
PostPosted: Mon Sep 12, 2011 11:00 pm    Post subject: Reply with quote
Not really in the bus but here is my winter project, to get this motor overhauled and back in where she belongs.
WTB: Lotus white deluxe bus OG interior
Swivel seat
"Dammit, every time we have a sweet idea the government has to come and screw it up"-Kyle Broflowski
1966 Bug(my first car)
1966 Bus 13w Deluxe(solid lotus white, my first split)
1972 Bus Deluxe
1969 Bug(the wife's vdub)
1959/1962 Baja
Frieden
Frieden is offline
PostPosted: Tue Sep 13, 2011 8:18 am    Post subject: Reply with quote
VWRICK69 wrote:
BUBBA ARMY!!!!!!
zuggbug Premium Member
zuggbug is offline
PostPosted: Tue Sep 13, 2011 7:36 pm    Post subject: Reply with quote
SOUTHERN INTEGRITY AIRCOOLERS
56 Kombi
72 Dormobile
58 15 window
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Sep 18, 2011 10:00 pm    Post subject: Reply with quote
Some pics from today after some cleaning and painting.
Eric
77 Westy / 74 Super Beetle
My Photography Page. Photo Prints Now Available!
Outside the Bus Table Brackets Available!
Click Here!
View user's profile Send private message Send e-mail Visit poster's website Facebook Twitter Gallery Classifieds Feedback
Page 21 of 27
