Auxiliary Battery Help
Matt_Flagstaff
Matt_Flagstaff is offline
PostPosted: Wed Feb 27, 2008 2:06 pm    Post subject: Auxiliary Battery Help Reply with quote
I am getting ready to install an auxiliary battery in my 84 westfalia. Does anyone have suggestions on what type of battery to use? I have heard that the optima batteries work well as long as you cut the posts off the top and lay them sideways. I'm looking for something that will fit underneath my driver seat and still have enough amp hours to run my stereo, lights, etc. I plan on hooking up a solar panel in the near future, which will charge this auxiliary battery. Not sure if there is anything new on the market that I am not aware of. Also...is it worth the money to buy the auxiliary battery hook up from Gowest.com if there is already a relay in my vehicle? Not sure if the factory relays work well or if it's better to replace them. Any help would be great. Thanks. Matt
Current VW's: 1984 Westfalia "Lucy"
Past VW's: 1962 Westy, 1967 bug, 1974 Westy, 1972 Westy, and 1978 Westy
bucko
bucko is offline
PostPosted: Wed Feb 27, 2008 2:36 pm    Post subject: Reply with quote
The search function Matt, the search function shall set you free!
All kidding aside, you're new (based on your posts), and we all welcome you to this great forum. This topic has come up many times, and you will find wiring diagrams to change from a relay to an "equalizer", as well as what deep cycle batteries are recommended, and DOGPILOT has posted about using solar panels with great success. I have just the relay, and my deep cycle battery from INTERSTATE batteries works fine for my application.
Give it a try. click "search", use "dual battery" as the key words, then select Vanagon/Eurovan as the forum to search in.
Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181
tii
tii is offline
PostPosted: Wed Feb 27, 2008 2:54 pm    Post subject: Reply with quote
An approach I used was the basic backup battery configuration using the hellroaring battery islolator. I switched an optima yellow top into place for my main battery (slight mods to battery box to squeeze it in on it's side) and moved the "old" battery over behind the driver's seat.
http://www.hellroaring.com/4wheel.php
I went to a wrecker and took two main cable grommets from two donor vans and ran battery cable down, under, and across, between the two battery boxes.
The advantage of this is that you drive all electrics from the main circuit knowing that if the main battery runs too low to re-start the van, then you can switch the backup into action and start it that way.
PDXWesty
PDXWesty is offline
PostPosted: Wed Feb 27, 2008 4:53 pm    Post subject: Reply with quote
If you already have the relay, you don't really need their kit. I can send you a copy of the instructions they sent me and you can probably figure it out. If you don't want to spend a lot of money on a second battery, a normal group 41 car battery will work. It's just not a true deep cycle battery so it's life will be shorter, but they cost $50 verses $160. I've been successfully using a normal second battery for two years now and it seems to be fine. I even have a third true deep cycle battery hooked up in parallel under the sink.
There's a lot of posts that say the stock relay is junk, but it's worked fine for me for a long time now. I've used those other type battery isolators and they go bad after a while too.
Send me your email and I'll send you the instructions I have.
Good luck!
sc-surfer
sc-surfer is offline
PostPosted: Wed Feb 27, 2008 10:34 pm    Post subject: Reply with quote
Matt...
I have an Optima yellow top. Works fine but fitment is a problem. Take a look at the Odyssey batteries. There is a model that will fit under the drivers seat and still allow use of the existing compartment door and seat rotation. I'm bummed I got the Optima but at the time we didn't know there was an alternative. I'll be getting an Odyssey when (if) it wears out.
Do a search here for the exact model that fits.
Odysseys cost about the same as the Optima and are an A1 quality product. We use them on all of our fire engines, and if Ken our mechanic likes them they are the bomb....he's a picky b$#ch!!!
Just my .02
'89 Syncro Westy
Catalog of Vans at SDM 2010
Westfalia, Syncro & Tristar Reproduction decals here.
* * * Coming Soon: Washable seat covers for westy bench seat...keep the pets off the upholstery! * * *
dpdunrite
dpdunrite is offline
PostPosted: Thu Feb 28, 2008 8:17 pm    Post subject: Reply with quote
I just purchased the odesey 1200c battery from my local oddesy battery supplier and a relay from go westy and will be installing it next weekend. The battery size allows for the relay to be installed right beside the battery with spare room in the driver side storage tray. The directions for installation of the relay and battery after review seems to be relitivly simple.
Check where your local oddesy battery dealer is and you can eliminate about $25.00 shipping .
http://www.odysseysoutheast.com/pc1200-battery.php
DP
"Fritz" 88 vanagon westfalia 2.1 wbx
"Frank" 89 Kawsaki Mule 450cc twin
"Tony" 00 B21 Kubota
"Niles" 85 xj6 Jaguar Sauveriegn
"Al" 07 Cheverolet Silverado Z71 LT crewcab
"Soney" 78 18' Sunrunner runabout
"Kelly" Wife
"Kirby" Black Lab
"Bear" Black cat
wolfej1
wolfej1 is offline
PostPosted: Fri Feb 29, 2008 6:40 am    Post subject: Reply with quote
Here is a write up I did when I did my install on my 82 Westy. Your Westy should already have the relay in the aux compartment.
Also I just used a regular Type 41 battery - works fine for me but I have not charged/discharged it to deathe either. Your results may vary....
Good luck it is pretty easy to add the battery.
http://www.thesamba.com/vw/forum/viewtopic.php?t=259835&highlight=
ranchero
ranchero is offline
PostPosted: Fri Feb 29, 2008 9:14 am    Post subject: Optima Reply with quote
I got my optima to fit on its side with just a minor cut to the edge of the compartment. Swivel and battery door both work as normal.
Pic and explanation here....
http://www.thesamba.com/vw/forum/viewtopic.php?t=218259&highlight=
sc-surfer wrote:
Matt...
Just my .02
'90 Westy Syncro EJ25 (money pit #1)
'96 FZJ80 (cheap by comparison^^)
'13 Golf R. Daily driver.
kevtherev
kevtherev is offline
PostPosted: Fri Feb 29, 2008 10:44 am    Post subject: Reply with quote
Have to agree with PDXWesty
normal starter battery has served me well...weekends and weeks
I use a split charge relay that switches when the engine is running to recharge the aux and the starter
these relays cost pennies and are widely available
Vanagon Nut
Vanagon Nut is offline
PostPosted: Fri Feb 29, 2008 11:10 am    Post subject: Reply with quote
PDXWesty wrote:
..... If you don't want to spend a lot of money on a second battery, a normal group 41 car battery will work. It's just not a true deep cycle battery so it's life will be shorter, but they cost $50 verses $160.
I wish I had gone with a group 41 battery. I spent more on a small battery (same as small GW deep cycle.... I think) than a larger capacity group 41 type. Though it works, I'm pretty sure it doesn't have as many amp hours as the group 41.
Initially I was concerned about off gassing from a normal starter battery, hence the purchase of a deep cycle.
I'm pretty sure there isn't any off gassing issue, though I could be wrong.
Neil
A shovel and a Freshette is all you need.
1981 VanaJetta 2.0 Westy "Jaco"
1988 Westy To Be Named! :^)
Vanagon VAG GAS engine swap Google Group:
https://sites.google.com/site/t2t3vaggasengineswaps/home
My Air Cooled Vanagon to 15 Jetta ABA swap pages:
https://sites.google.com/site/tubaneil2/15degreeengineconversion
Matt_Flagstaff
PostPosted: Fri Feb 29, 2008 11:20 am    Post subject: THANK YOU ALL FOR YOUR HELP Reply with quote
I want to thank everyone that chimed in. After much reading and research on the topic I have decided to go with the Odyssey PC1200 battery and a Yandina. This will allow me to set up my electrical system to run power in the van without the main battery and also allow me to hook up a morningstar solar charge controller to a panel and my aux. battery. Again...thank you for your help in this matter.
PDXWesty
PDXWesty is offline
PostPosted: Fri Feb 29, 2008 12:02 pm    Post subject: Reply with quote
One thing I learned from my research is that a solar controller for my application was a waste of money. For the amount of time I actually use my solar panel, there's no fear of overcharging. If you had a solar panel perminantly connected and running all day every day, yes you need one. But just for camping?...not really.
I have a 7 amp controller I never hooked up I'll sell you real cheap.
http://www.campingworld.com/browse/skus/index.cfm/...unum=31284
riceye
riceye is offline
PostPosted: Fri Feb 29, 2008 12:16 pm    Post subject: Reply with quote
Hey Matt,
Check out Batteries Plus. They have the equivalent 44 amp hour AGM as the Odyssey, but for $ less, and no shipping if you have a local store.
Batteries Plus# WKA12-44C/FR.
Current price is $120. What is the current price on the Odyssey pc1200?
Good choice on the Yandina!
Salud-
Ric
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
Matt_Flagstaff
PostPosted: Fri Feb 29, 2008 8:31 pm    Post subject: PC1200 Cost Reply with quote
I was able to find a PC1200 for $140 on e-bay.
It'sMeGoddamnIt
It'sMeGoddamnIt is offline
PostPosted: Sun Nov 15, 2009 8:41 am    Post subject: Yandina vs. Hellroaring Reply with quote
Matt:
Can you tell me why you decided to go with the Yandina instead of the Hellroaring BIC?
Cheers,
Cody
