Kwoggy Samba Member
Joined: October 11, 2012 Posts: 37 Location: Ventura County
Posted: Wed Jul 30, 2014 4:23 pm Post subject: Got the bus transported to its new home. |
_________________ 1970 Bus |
force3g Samba Member
Posted: Sun Aug 03, 2014 3:32 pm Post subject: |
_________________ Never shoot a large caliber man with a small caliber bullet.
1970 Westy
2010 Jetta |
wanderglobe Samba Member
Joined: December 22, 2005 Posts: 1047 Location: Winnipeg Manitoba
Posted: Fri Aug 08, 2014 9:34 pm Post subject: |
Added the following:
Bluesea ACR
1000 Watt Inverter/Charger
100 Amp Hour AGM Battery
New Fuse Panel
I spent a day installing my new house battery. I shoot a lot of video from the road and it's nice to have the juice for editing in the evenings. The inverter is also a charger and is wired directly into the external bus plug (sounds dirty). When the bus is plugged into shore power it does a 3 stage charge on the battery bank.
I also ordered these 120 watt solar panels that fold together and come with a nice carrying handle. Charge controller and all the other bells and whistles are attached directly to the panels.
_________________ ============================
Owner of Dante the Hellrider
1973 Bay Window Automatic
Website: www.wanderglobe.com
Twitter: www.twitter.com/wanderglobe
YouTube: www.youtube.com/myvwtravels |
skid Samba Member
Joined: January 16, 2009 Posts: 1329 Location: Vancouver, BC
Posted: Sat Aug 09, 2014 10:37 am Post subject: |
Finally moved the oil filter out of the engine compartment and under the left battery tray. Put in the proper engine tin and its better sealed now that there aren't any oil filter hoses running through it. Adjusted clutch cable, replaced both brake light switches (one stopped working, figured we'd do both while we were down there) and bled the brakes. Adjusted valves, greased the front end, new grease in front wheel bearings, oil change, new battery ground strap, finally hooked up the oil temperature switch the PO started to hook up but never finished, installed a new retrosound radio and I think we're good to go for our road trip down the 101! Pumped! _________________ '71 Westfalia |
karlonwheels Samba Member
Joined: February 09, 2014 Posts: 128 Location: new yorkish
NEFARIOUS1 Samba Member
Joined: March 25, 2011 Posts: 27 Location: JAMESTOWN,CA
Posted: Sat Aug 09, 2014 10:26 pm Post subject: |
For the first time in years... I drove it!
[/img] _________________ 1971 slammed bus "Lenny"
1974 Thing
1978 westy bus"unknown" |
timo78 Samba Member
Joined: July 03, 2009 Posts: 931 Location: Overcast and Loving it
Posted: Sun Aug 10, 2014 11:02 am Post subject: |
Star adjustment on the rear brakes for parking brake nirvana. Just a few clicks makes a big difference. Test drive and stomping on the brakes showed no sideways pull...good ta go ..err stop _________________ > 78Grµn Westfalia `Donkey`
It may be bigger than you and it may be bigger than me, but it’s not bigger than you AND me; can you dig it? |
Jalabert Samba Member
Joined: December 06, 2005 Posts: 631 Location: On the coast in NZ, somewhere...
Posted: Sun Aug 10, 2014 6:30 pm Post subject: |
Horn fixed, finally. At the third time of asking. Definitely one of those first time - twelve hours - second time - half an hour - jobs... _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
'73 westy, 1700 type 4 with 34icts |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Sun Aug 10, 2014 7:08 pm Post subject: |
I installed an Innovate MTX-L fuel/air gauge and oxygen sensor in my bus. I consider it the ultimate gauge because the main reason fuel injected type 4 engines take heat damage is because L-Jet runs so well in a lean condition and quickly destroys the engine in that state. I got it perfectly tuned, although it was very close to begin with.
_________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
airkooledchris Samba Member
Posted: Sun Aug 10, 2014 8:31 pm Post subject: |
tootype2crazy wrote: |
Are you going to move that gauge elsewhere eventually? I also plan on adding one, but that digital display looks like it would be really distracting up on top like that. (after your done tuning and just want it for reference) |
Posted: Sun Aug 10, 2014 8:33 pm Post subject: |
that's my next project. tail-lights, side marker lights, and all sorts of little breaks I found in the wires going to/around the alternator.
nice setup with all the right tools at the ready! |
Posted: Mon Aug 11, 2014 6:42 am Post subject: |
airkooledchris wrote: |
Nope, that is where it's staying. I am not cutting into my pristine dash or putting it at the bottom of the dash where I can't see it. I thought long and hard about where to put it. I'm 6'3" so it's really not distracting to me at all. I have LED lights in my gauges, and although you can't tell in that crappy cell phone picture, they are really bright too. Plus the gauge dims when you turn the headlights on. _________________ air-cooled or nothing for me
richparker Samba Member
Joined: November 24, 2011 Posts: 6981 Location: Durango, CO
kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
Posted: Wed Aug 13, 2014 9:31 am Post subject: |
Troubleshooting another issue.....new battery ground strap, new connectors on FI grounds, cleaned transmission grounds, moved AFM wiper a smidge for a fresh track.
Things I did for fun....new $12 fog lights, DD CHT gauge, and fuel pump kill switch in engine bay for theft prevention. _________________ 1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/ |
encsdaddy Samba Member
Joined: September 16, 2007 Posts: 156 Location: Inland Empire, CA
Posted: Thu Aug 14, 2014 9:41 pm Post subject: |
Do you have a thread documenting the installation??
Sounds like a project I would like to undertake. _________________ 77 Westy named Tiki - Daily Driver 80 miles a day!
(2.0L with hydro lifters)
78 Bus (8 seater w/ front bench) - Still trying to get it running! (fuel pump cuts out)
69 Sqauareback - RIP (Rear ended by a Volvo)
72 Bug - RIP (Rusted away!) |
1mom2grace Samba Member
Posted: Sat Aug 16, 2014 8:52 am Post subject: |
Started the tear down (to clean out 40+ years of "ick"). It was like a museum of grossness! NOT my gunk, the po's. Going to purple clean it, sand and coat it. Then will work on restoring and re installing the westy stuff.
_________________ Single mom to a teenage girl.
Proud VW owner with no experience.
68 bug
68 bus tin top camper
How the heck did this happen??? LOL |
kevinj73us Samba Member
Joined: September 25, 2011 Posts: 228 Location: Laurel, MD
Posted: Mon Aug 18, 2014 8:37 am Post subject: |
Had my accelerator cable snap yesterday, so thanks to Home Depot I made a Muir-worthy roadside repair to get me home. Now I get to replace the cable!
kj _________________ 1973 Station Wagon
m-plate |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Tue Aug 19, 2014 8:56 pm Post subject: |
skid wrote: |
Finally moved the oil filter out of the engine compartment and under the left battery tray. Put in the proper engine tin and its better sealed now that there aren't any oil filter hoses running through it. Adjusted clutch cable, replaced both brake light switches (one stopped working, figured we'd do both while we were down there) and bled the brakes. Adjusted valves, greased the front end, new grease in front wheel bearings, oil change, new battery ground strap, finally hooked up the oil temperature switch the PO started to hook up but never finished, installed a new retrosound radio and I think we're good to go for our road trip down the 101! Pumped! |
hit me up when you roll through washington...ill see what i can do
just before my trip to the great land of canada last weekend, me and Dale took off my front bumper, and properly grounded and wired up my driving lights, and fixed my horn. also got a new to me set of 27 inch maxxis 751 tires from schwabb, used and only for 150 with rims. i like the look kinda, but these are feathered and hum and i hate that....gonna try and minimize it by rotating a few times to find the best placement, but whatever. i will go with grabbers next time i have money for such extra things as tires. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
MonkeySee Samba Member
Posted: Wed Aug 20, 2014 9:32 pm Post subject: |
Bought it a 1958 one wheel trailer.
