What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 373, 374, 375 ... 462, 463, 464  Next
SixStringMadMan
SixStringMadMan is offline
PostPosted: Mon Apr 06, 2015 5:31 am    Post subject: Reply with quote
justcruzin wrote:
Added some emblems. Very Happy
Which light up when the lights are turned on! Very Happy
They look better in person. They are actually red. Very Happy
That is badass!!
1978 Kombi
http://www.vw-mplate.com/mplate-10020.htm
Tcash
Tcash is offline
PostPosted: Mon Apr 06, 2015 9:03 am    Post subject: Reply with quote
Where did you buy them? Are they battery operated or wired into your lights?
Thank You
Tcash
pitbug
pitbug is offline
PostPosted: Mon Apr 06, 2015 1:34 pm    Post subject: Reply with quote
Thank You
Tcash
yea! what he said ?!?!?! Cool Laughing
71' Bus "Sunshine"
68 Eriba Puck!! Wink
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Gallery Classifieds Feedback
justcruzin
justcruzin is offline
PostPosted: Mon Apr 06, 2015 2:52 pm    Post subject: Reply with quote
Thank You
Tcash
I got them off of eBay. I actually bought one about a year ago and had plans on making it a third brake light. Then I decided I didn't like any of my mounting options for a third brake light and decided to buy another and make them come on with the running lights. Yes, I tied them into my license plate light. I did have to drill two small holes to allow the wire to go inside the decklid. Being that it isn't the stock decklid I wasn't to worried about the holes.
They are actually made for Jetta trunks.
Kim
Sacramento, CA
1964 Split Window Bus
1966 Beetle Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=472933
1969 Delivery Van= http://www.thesamba.com/vw/forum/viewtopic.php?t=566282
1970 Westy Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=479538
1971 Squareback Build Thread = http://www.thesamba.com/vw/forum/viewtopic.php?p=6652459#6652459
1970 Single Cab, Samson = http://www.thesamba.com/vw/forum/viewtopic.php?p=8022609#8022609
GMATech
GMATech is offline
PostPosted: Tue Apr 07, 2015 7:51 pm    Post subject: Reply with quote
Got the holes for the coolant pipes just about finished. The pipes fit through very snug, and both threaded right in. I just gotta open them up a little bit more.
Plus my Jamie Rivers trailer hitch just arrived and looks great.
77 westfalia vr6 project
72 standard beetle project - for sale
ASE Master Tech since '03 A1-A9 L1 L3 G1
PA safety and emissions inspector
General Motors guru
Jmack223
Jmack223 is offline
PostPosted: Tue Apr 07, 2015 10:35 pm    Post subject: Reply with quote
what are the pipes for??
do you have a build thread?
GMATech
GMATech is offline
PostPosted: Wed Apr 08, 2015 4:57 am    Post subject: Reply with quote
They're coolant pipes for my vr6 project. No build thread. More pics in my gallery tho
General Motors guru
Bashr52
Bashr52 is offline
PostPosted: Wed Apr 08, 2015 5:25 am    Post subject: Reply with quote
You are kidding, right?
Amskeptic
Amskeptic is offline
PostPosted: Wed Apr 08, 2015 9:33 am    Post subject: Type I Crankshaft stock pulley early and late Reply with quote
Here, quick, some cooling balm . . . :
Installed a correct "D" pulley for a little more fan rpm and the chance to use the proper 905mm belt. Apparently, the pulley that I got in Albuquerque in 2011 to get rid of the cheap new brazilian wobbler that came with the car was a smaller earlier pulley that gave me a floppy loose belt even when there were no shims between the generator pulley halves and even after I switched to a 900mm belt.
Then I painted the steering wheel with engine enamel because whatever the paint was on it before sucked.
Colin
(good luck with that VR6 cooling system, GMATech, will the diameter of that pipe over such a long traverse be large enough to maintain critical no-boiling-allowed pressure within the cylinder head at whatever volume is required?)
www.itinerant-air-cooled.com
GMATech
GMATech is offline
PostPosted: Wed Apr 08, 2015 4:55 pm    Post subject: Reply with quote
Bashr52 - no not kidding. What would I be kidding about?
The vr6 is naturally a hot motor, 6 holes in one head. It came with an aux coolant pump from the factory(and a second radiatior in the fender). I can always add another aux pump in my pipe if I need to. As with most home made cooling systems there will be some trial and error, but with plenty of airflow through the massive rad I plan to put on. Plus the volume of coolant needed to fill the system, it's gonna be fine. Will probably take forever to get heat in the winter time.
General Motors guru
GeorgeL
GeorgeL is offline
PostPosted: Wed Apr 08, 2015 5:25 pm    Post subject: Reply with quote
Also, what are the provisions for heat expansion on that long fore-aft run? That pipe will grow by about an eighth of an inch as it warms to operating temperature.
When was the last time black iron pipe was used on an automotive cooling system?
Zeen
Zeen is offline
PostPosted: Wed Apr 08, 2015 8:44 pm    Post subject: Reply with quote
GMATech wrote:
...it's gonna be fine...
We'll see, please share your results.
30 feet of 1" steel pipe with sharp-angle fittings is a different animal from a few feet of 1.25" smooth rubber hose, auxiliary pump or not. You might consider experimenting with hoses before cutting up the body and committing to rigid pipe.
The consequences of your decisions should not be confused with fate.
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Thu Apr 09, 2015 6:36 am    Post subject: Reply with quote
No wonder GMATech doesn't have a build thread!
Naysayers gonna naysay.
It looks super cool, good luck on your build!
btw Prickle rocks dude!
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI
melville
melville is offline
PostPosted: Thu Apr 09, 2015 6:55 am    Post subject: Reply with quote
I get it! It's a SteamPunk build!
Emphasis on the Steam!
2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan
GMATech
GMATech is offline
PostPosted: Thu Apr 09, 2015 3:43 pm    Post subject: Reply with quote
Nailed it, you all can see pics when it's done. Not lookin for any input.
General Motors guru
melville
melville is offline
PostPosted: Thu Apr 09, 2015 4:12 pm    Post subject: Reply with quote
You could mount a blow-off valve to that rear-facing nipple and then mount a steam whistle to that for a temperature gauge.
2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan
Zeen
Zeen is offline
PostPosted: Thu Apr 09, 2015 7:23 pm    Post subject: Reply with quote
Laughing
That's a choice. There's no downside to asking for assistance. There are people who are willing to help, some of whom are experts and make real money doing what they'll share with you for free. All it costs is a little ego control (and indulgence of their humor).
Amskeptic
PostPosted: Fri Apr 10, 2015 12:59 pm    Post subject: Reply with quote
Zeen wrote:
Laughing
I really like that steam whistle idea . . . that would cut through the Grateful Dead and the pot haze blocking the temperature gauge.
Colin
GMATech
GMATech is offline
PostPosted: Sat Apr 11, 2015 12:19 am    Post subject: Reply with quote
My wife says I love this hole to much, cleaned it up a little bit more.
General Motors guru
khalimadeath
khalimadeath is offline
PostPosted: Sat Apr 11, 2015 8:50 am    Post subject: Reply with quote
I dont even really know what to think about that. ^
Page 374 of 464
