Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
Posted: Tue Aug 25, 2015 7:01 am Post subject: |
I have been having issues with my bay where i have been hearing this grinding noise and also had to pump the brakes just to get it to stop. Then when I least expected it wouldn’t even stop and the brakes locked up taking me to the left side each time I pressed on the brakes.
It was time to open up the drums and see what was happening underneath.
Before starting the job I needed to make sure that I had the proper jack and jack stands for safety.
Lift vehicle at points indicated in link:Jacking up bus
Jack stands not pictured. Place under Frame or Front Beam.
Look at what I found
No more cheap bearings this time and here I will use these FAG bearings
Wheel cylinders were shot and leaking on both sides
Lets replace the bearings and also the seal with good quality Elring seals
I cannot remember the order of the following photos but I did use a 1-1/8” socket to put in the outer bearing race and to remove it was simple as well since I used a flat punch and also used the old race to tap in the new one.. you have to turn it upside down and you will see how the edge meets perfectly so you can tap this new baby in…
This is what I used to tap the new one in and then after that took a flat punch to the remaining til It sat snugly in
There it is all snug outer wheel bearing race case
Now to tap in the inner bearing race case
There it is all in tapped in a cross pattern to insure that its even on all sides
Make sure to put ample grease in the middle section of the drum also to keep that are reservoired with grease.
I then gently tapped in the new Elring rubber seal
You need to pack the bearing like this:Repacking Bearings
Now lets set the brake drums aside so we can do replaces the shoes and wheel cylinders $18.00 Fronts to $24.00 rears which is my wholesale pricing but if you want some for you I can get them for you at the same price plus a flat fee of $5.00 on top for each one.
Removing the 11mm brake line fitting is tough so I suggest putting them on a vise and using a pipe wrench or else you will wear away at the fitting with your 11mm box wrench and then you will up the creek without a paddle. These brake lines measure 14”-15” in length and you will have to make the bends to form them like the ones that came out of there to begin with.
Or spray them with a rust penetrant, heat if needed. They will come right off.
I decided to replace the rubber brake hoses also and these you have to use a 17mm wrench and an 11mm (flare nut wrench) box wrench but if it begins to strip it then go to the pipe wrench because it really grips. Look at the following photos
Soaking with rust penentrant and the correct, Flare nut wrench will not damage the brake line flare nuts.
The brake hose from behind the brake drum is removed with a 14mm box wrench and this one you can lubricate prior to attempting to loosen with the box wrench but in order to remove it from here you have to remove from where it meets the hard brake line.
Now it is time to slap everything back on and have someone help with pumping the brake pedal to bleed the brakes and for this you will need a 10mm wrench.
Edited in blue and red.
Nice write up. Thank you for sharing.
Tcash _________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870 |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20230 Location: Sandpoint, ID
Posted: Thu Aug 27, 2015 8:37 pm Post subject: |
Goshen wrote: |
I can't even imagine using a pipe wrench on those fittings unless I planned to replace the hard line entirely. MAYBE a well placed Vice grip, but never a pipe wrench.
Also, you really need to put a grommet in the hole where the hard line passes through the hole in the body. That metal-to-metal contact will wear a hole in the brake line and result in complete brake failure. Looks like that metal line needs to be bent properly to align in that hole better, too. _________________ nothing |
Goshen Samba Member
Posted: Fri Aug 28, 2015 10:28 am Post subject: |
cdennisg wrote: |
Also, you really need to put a grommet in the hole where the hard line passes through the hole in the body. That metal-to-metal contact will wear a hole in the brake line and result in complete brake failure. Looks like that metal line needs to be bent properly to align in that hole better, too. |
I used a flare wrench but it was not working.. it kept slipping.. i used the pipe wrench bc the vise grip wasnt working to well
as far as the grommet.. i will definitely do that.. thanks _________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3889 Location: Seattle, WA
Posted: Sun Aug 30, 2015 12:06 pm Post subject: |
Pipe wrenches are great - much better than vicegrips. In this particular case, I would've used a 6-inch pipe wrench
(with an extension over the handle if necessary) on the nut. Yes, they will leave marks on the nut, but it can still be used.
A really tight brake line nut will cause most flare-nut wrenches to bend (permanently!), slip, and ruin the nut anyway. _________________ '67 bug: seized by the authorities
Silverboot Samba Member
Posted: Sun Aug 30, 2015 2:07 pm Post subject: |
Just picked up my 79 Riviera from the shop, needed a new needle bearing and shifter bushing, its like night and day driving her now. Speaking of night and day, sorted out all of the lights, so blinkers and flashers are now in working order.
Driving the wife bananas, keep finding excuses to run here or there to grab something so I can drive the bus. _________________ 79 FI CA Riviera
74 Smallframe Vespa |
HelmutofBuffalo Samba Member
Joined: August 22, 2005 Posts: 554 Location: West Coast of New York
Posted: Mon Aug 31, 2015 8:37 am Post subject: Cheap back up camera |
Just installed this $34.00 back up camera from HDE Electronics from auction site. I did not want to put it up on dash and did not want to drill holes in dash. I cut off the mounting sticky and JB welded the mounting bracket to a rare earth magnet recycled from some electronics and mounted it to my ashtray. Magnet makes for easy removal or adjustment. Only other drawback was I barely had enough cable to run it back to the camera mounted on license plate, but I did take a long route. I can see the pavement about 6 inches from Bus.
_________________ 1979 Type I Convertible |
christine72 Samba Member
Joined: August 31, 2014 Posts: 84 Location: Portland, Oregon
Posted: Sat Sep 12, 2015 11:05 pm Post subject: Installed sound deadening |
I used inexpensive tip from Chris Vallone (Classic VW, NY). Used Quick Roof video http://youtu.be/u7eIF4cgFx4
Took out the Z-bed and seat belts and laid it in. Was pretty simple process.
Also removed the old vent and switch for the gas heater. Don't have the heater, and the vent just serves as a leak for fumes. Ultimately sealed it with a piece of thin flexible plastic "cutting board" and theQuick Roof over top.
The engine hatch is well insulated and deadened already so left it stock.
Sure hope it makes a difference. Haven't been able to hear music or conversation.
Will install in front of bus-cab floors, front wall, and doors. _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
1967 Fastback (my first car); 1971 Square back; Several Jettas '88 -'97
The one I regret not buying:
72 Karmann Ghia, with autostick. |
BerryBus Samba Member
Posted: Mon Sep 14, 2015 7:40 am Post subject: |
Had to take a shortcut. Was getting water through windscreen and no budget/time to replace glass and weld in patch for permanent fix. To slow it down just a bit, I taped off the seal and applied 100% black silicone to seal all the way around. The glass is coming out in pieces anyway, so I figured, $3.95 and it wouldn't hurt anything
_________________ 1970 7 Pass/Riviera/Westfalia - Ours
1968 + 1971 Bus Trailer
1991 Porsche 964 C4 Cabriolet - Mine
2005 New Beetle Convertible - Wife
2012 Touareg TDI |
panic_fan Samba Member
Joined: April 21, 2008 Posts: 711 Location: Mcdonough GA
ggaeta Samba Member
Joined: January 19, 2009 Posts: 32 Location: Costa Mesa
Posted: Mon Sep 14, 2015 2:11 pm Post subject: Re: Cheap back up camera |
HelmutofBuffalo wrote: |
a back up camera is a great idea. It looks great except ...i think your camera is mounted upside down. the colored lines are supposed to be on the bottom side. I only say this because it might mess up the distance and the distance beeps. |
TurtsMcSlow Samba Member
Joined: August 07, 2015 Posts: 78 Location: Derby City, Cantuckee
Posted: Fri Sep 18, 2015 8:30 pm Post subject: |
Read 383 pages of What Have You Done For Your Bay Recently. |
Posted: Fri Sep 18, 2015 9:14 pm Post subject: |
TurtsMcSlow wrote: |
canes5time Samba Member
Joined: October 25, 2008 Posts: 124 Location: Boca Raton, FL
Posted: Sat Sep 19, 2015 9:59 am Post subject: |
How many hours did that take? |
Posted: Sun Sep 20, 2015 9:50 am Post subject: |
canes5time wrote: |
Let's just say it adds up to a whole lot of toilet time. |
Posted: Sun Sep 20, 2015 11:58 am Post subject: |
canes5time wrote: |
Magpiecandles Samba Member
Joined: September 20, 2015 Posts: 2 Location: Salem, AL
Posted: Sun Sep 20, 2015 5:53 pm Post subject: |
Been working on our first rebuild. Finally got the splitting the crank case. Still a long way to go, but it has been a fun learning adventure so far. Next is finding a shop we can trust for a valve job.
Jmack223 Samba Member
Posted: Tue Sep 22, 2015 6:32 pm Post subject: Re: Installed sound deadening |
christine72 wrote: |
Will install in front of bus-cab floors, front wall, and doors. |
let us know how well it works! ^^ |
Goshen Samba Member
stuartcamenson Samba Member
Joined: September 24, 2009 Posts: 25 Location: Santa Cruz, CA
Posted: Thu Sep 24, 2015 5:13 pm Post subject: |
I removed a weird oil cooler setup that was running from the pump, to the front of the bus, through an air cooler under the front, back to the filter, then back into the pan. The long line couldn't be primed by the pump so I had no oil pressure after giving it nice new oil and a filter. I couldn't figure out why and was freaking out. But the nice people on here helped me through it and educated me that the oil cooler setup was garbage. Now my baby is back on the road =D |
m.pendzick Samba Member
Posted: Fri Sep 25, 2015 6:41 am Post subject: |
Pulled engine and gas tank for rebuild
