One Owner Samba Member
Joined: August 09, 2005 Posts: 243 Location: Nahville,TN
Posted: Sun May 20, 2012 6:14 pm Post subject: |
Lots of little things today:
Painted the tow hitch:
Added a cargo basket:
Painted the tire mount now its Invisible-ish:
New gasket for the pop top
Installed bamboo trays
Changed all pulls from the hideous yellow to black:
Put in shelf paper:
Not a bad day
Ray _________________ Watch PASSTIME only on SPEED
--77 Riviera--
http://www.thesamba.com/vw/forum/viewtopic.php?t=489967 |
EMPIFLAKE Samba Member
Posted: Sun May 20, 2012 7:12 pm Post subject: |
| Nice work where did you get your gaskets for your pop top?? Ive got a Riviera also and need all of them! |
curtis4085 Samba Member
Bruskyvw Samba Member
Joined: May 30, 2009 Posts: 563 Location: Seattle , Washington
Posted: Sun May 20, 2012 7:53 pm Post subject: |
Hi-lo's Social II in Bremerton had about 36 vw's there it was extremely cool! _________________ CURRENT:
1991 Wolfsburg Jetta
My Past Experiments:
1978 Sage Green Transporter 2.0 FI (Paddy)
1980 Rabbit Diesel LS
1969 Karmann Ghia Autostick
1991 Vanagon GL
1992 Tornado Red GTI 8V |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 9938 Location: Sandpoint, ID
Posted: Sun May 20, 2012 7:56 pm Post subject: |
Well done. The bus looks great! _________________
| Olddog52 wrote: | | horn test. one tab to ground, the other to a 12 volt source. Listen intently for a sound. |
Posted: Sun May 20, 2012 8:14 pm Post subject: |
| EMPIFLAKE wrote: | | Nice work where did you get your gaskets for your pop top?? Ive got a Riviera also and need all of them! |
Thanks its the Westy kit, works great
--77 Riviera--
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5371 Location: Edmonds, WA.
Posted: Sun May 20, 2012 10:44 pm Post subject: |
| cdennisg wrote: |
Well done. The bus looks great! |
like i said before ...hot vws needs a new centerfold.... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
Posted: Sun May 20, 2012 10:47 pm Post subject: |
picture from Hi-Lo's ~35 cars total
1991 Vanagon GL
Posted: Sun May 20, 2012 10:51 pm Post subject: |
put 200 miles on maisy, and met theizzardking finally...great way to end the day...cruisin home in the buses...
Maisy and Wanda
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3307 Location: Australia
Posted: Mon May 21, 2012 3:10 am Post subject: |
Today I followed one last lead to getting brake hoses locally. It ended at the same place which I got to make a custom section of brake line for it. If I bring them the originals they can use them as a template to manufacture new ones at $38 per corner. honestly I don't know if that's good or not.
My other automotive news was more depressing and Ford related. My least favourite letters are N, L and A in that order. Then the indicator relay buried deep behind the dash failed in rush hour traffic.  _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Mon May 21, 2012 8:30 am Post subject: |
| RatCamper wrote: | Today I followed one last lead to getting brake hoses locally. It ended at the same place which I got to make a custom section of brake line for it. If I bring them the originals they can use them as a template to manufacture new ones at $38 per corner. honestly I don't know if that's good or not.
http://www2.cip1.com/searchresults.asp?cat=1185
Here's some prices from the US. Don't these guys deliver to your side of the pond? _________________
Posted: Mon May 21, 2012 1:33 pm Post subject: |
| cdennisg wrote: | | RatCamper wrote: | Today I followed one last lead to getting brake hoses locally. It ended at the same place which I got to make a custom section of brake line for it. If I bring them the originals they can use them as a template to manufacture new ones at $38 per corner. honestly I don't know if that's good or not.
Here's some prices from the US. Don't these guys deliver to your side of the pond? |
Haven't tried them yet. Everyone else I get all excited about the rock bottom prices especially when I see they post to here, then discover that for one reason or another postage is between $50-$100 and well you can imagine what i say to that. It's why I had that bit of brake line custom made, and why I didn't buy the Rhino shift coupler. I should say the urethane one I got instead from aircooled.net is a nice coupler. I didn't get the brake line from them though because even though it was only a really small piece, the price shoots up on packaging really fast. I'm just assuming some U.S. commercial export tax. So not dissing aircooled at all. Gotten some desperately needed small items from them in a couple of orders including carb jets. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1078 Location: United States
Posted: Tue May 22, 2012 4:44 am Post subject: |
Been too busy, but something arrived.
like last time, today more Ford fun. Both front wheels' brakes decided to hit metal on metal. Bought a set of pads to fit on Thursday. Eats front pads like popcorn. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
La.2Ak. Samba Member
Posted: Wed May 23, 2012 7:47 am Post subject: |
| I Ordered an EZ up Awning from Bus Depot and a tent that is supposed to fit the back area from Amazon.com. I'll see how they work on June 8th when I get home . Super excited about using the bus for a whole 3 weeks . |
Posted: Wed May 23, 2012 8:30 am Post subject: |
Since I am heading to Indy this weekend for the 500 and will be camping in the bus (with electricity) I added AC to my hotel suite
--77 Riviera--
minispdrcr Samba Member
Joined: September 13, 2010 Posts: 264 Location: Oklahoma City, OK
Posted: Wed May 23, 2012 8:43 am Post subject: |
Changed plugs to make it run like a champ _________________ Marcin P.
1969 Westfalia Weekender Edition
1973 Morris Mini 1300 Super
1998 Audi A6 |
Posted: Wed May 23, 2012 3:29 pm Post subject: |
Went for a wander at the wreckers. Only went there for a relay. Got a couple of other bits from a wrecked Toyota poptop.
An ancient K-Mart 12v fan and what I believe is a radio housing. It was bolted to the top of the dash with a couple of grade 10 bolts. Also grabbed the push / pull switch for the fan.
interesting to note the fan was mounted to a crossmember on the ceiling just behind the passenger seat.
I liked the pop top. Full length one.
photo courtesy of my "new" phone. A low-ish end pre-paid smartphone with a relatively unpopular network that had been on the shelf a couple of years which I purchased yesterday 20% off. I'm such a high roller My current phone was made in '06 and is getting a bit cranky at times. Besides I wanted one I could connect to my netbook and use for internet access on the road. As in, in the bay. Plus because it's Android and seems to support USB debugging I can use it as a test platform for Android apps. My plan for ages has been to use my bay as a mobile office of sorts where I can do software development. One step at a time. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
vw76westy Samba Member
Posted: Fri May 25, 2012 9:11 am Post subject: |
for a "bay window" to win " best in show"
is something to really be proud of..........
it makes a statment of just how well done the
the paint & restoration is
because bays never get any respect at the vw car show _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1449189
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor, |
notchboy Samba Member
Joined: April 27, 2002 Posts: 11312 Location: Seattle WA
Posted: Fri May 25, 2012 10:07 am Post subject: |
| vw76westy wrote: |
because bays never get any respect at the vw car show |
I was thinking the same. Ive posted back and forth with Ivan-Editor of VolksWorld on other stories and I brought curtis up to him. Ive yet to hear back so we may need to get some better shots and a story to pass along curtis. He tends to like a complete package to put in the mag. But it seems this is a well deserved placement in VW or Camper mags.
If you plan on having it at say the VW Classic in Cali I know for sure Kiki-one of the mags photographers and or Ivan or a couple of staffers are usualy there. Then they may take the time to ask you to pull it aside and have a shoot. Food for thought.
On another note- today I let my bus go out for a photo shoot. A girl named Dana posed here awile back asking for a bus to shoot. She found me at the Spring meet here while I was hanging out with Stuart. She like the old 77 and asked if she could use it. Today she was able to meet up with me and I let her borrow it for some North Bend shots.
Ill post some promised pics when I get them-should be neat as its an all out affair with models and all. Sorry Ive already heard its a bunch of dudes-no chicas
Back in 08 he took the time to do a shoot for Rob Kingsburrys freshly restored 64 Sunroof notchback as well as a group shot of our club. Good times.
 _________________ Jason "notchboy" Weigel
1963 Pearl White Sunroof Notch
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
the1500club.com
TOOB Member #5 |
