babysnakes Samba Member
Posted: Sun Mar 16, 2014 9:53 am Post subject: |
After putting the engine into the '72 last weekend and putting about 80 miles on it, a pushrod tube seal squished out into the rocker box causing an oil leak. So I pulled the engine/tranny again yesterday. [email protected] said the tubes were to long causing the squish and recommended 40hp tubes. Placed an order, now just waiting for parts. |
lugo2214 Samba Member
Joined: January 16, 2014 Posts: 134 Location: Pinckard, AL
Posted: Sun Mar 16, 2014 11:48 am Post subject: |
Here it is
The temp switch under stearing column
Used this pump ziptied under the reservour and replaced all the crusty hoses
Will install next to emergency flashers
This oem switch donated by Jose Gonzalez bus guru in Ozark AL
And will replace the knob with this one
Thoughts?
_________________ RoRo's Campeter
1973 Tin Top Campmobile
Type 4 ENG / 2.0 HYD LIFT
003 Auto Trans 😆/😣
Dual Empi 44
009 Ignition
Ice Auto Air A/C kit 50% installed |
pitbug Samba Member
Joined: May 10, 2010 Posts: 549 Location: San Angelo, Tejas
Posted: Sun Mar 16, 2014 6:27 pm Post subject: Custom Center Console |
A friend of mine with some talent made this for me, I saw something similar to this on here somewhere, that's where the idea was born(not my original idea) but it was to make the draws I got them at antique shop for $2 each, I got five and he made 3 good one from them Its in my 71 Bay Sunshine watcha think??
_________________ 71' Bus "Sunshine"
68 Eriba Puck!! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sun Mar 16, 2014 8:36 pm Post subject: |
^^^ Pretty cool idea. All you need now is some sort of stick down the front to block those drawers from sliding open during a quick stop. _________________ nothing |
pitbug Samba Member
Posted: Mon Mar 17, 2014 3:15 am Post subject: |
cdennisg wrote: |
^^^ Pretty cool idea. All you need now is some sort of stick down the front to block those drawers from sliding open during a quick stop. |
Thanks, They'r petty tight, They Stay Closed, I Just Opened For Pic _________________ 71' Bus "Sunshine"
68 Eriba Puck!! |
ortak Samba Member
Joined: January 11, 2008 Posts: 155 Location: Fountain Inn, SC
Posted: Tue Mar 18, 2014 6:43 am Post subject: |
I got rid of all the separate fuse holders I had in the engine compartment and made a block to hold ATC fuses.
_________________ 75 Westy "Vanna", 2.0 with hydraulic lifters and Freeway Flyer Transaxle
2013 Toyota Prius
2017 Jayco Melbourne 24K diesel motor home
http://www.jkortak.com/home/restorations |
Tcash Samba Member
Posted: Tue Mar 18, 2014 12:40 pm Post subject: |
Looks good. You may want to take a look at this ground.
ortak Samba Member
Posted: Tue Mar 18, 2014 1:24 pm Post subject: |
Thanks.
Yeah the ground does look bad but the wire is just bent down. The ground is only for my engine compartment lights. _________________ 75 Westy "Vanna", 2.0 with hydraulic lifters and Freeway Flyer Transaxle
2013 Toyota Prius
Posted: Tue Mar 18, 2014 3:44 pm Post subject: |
ortak wrote: |
Thanks.
Yeah the ground does look bad but the wire is just bent down. The ground is only for my engine compartment lights. |
Cool job _________________ RoRo's Campeter
003 Auto Trans 😆/😣
Dual Empi 44
009 Ignition
richparker Samba Member
Joined: November 24, 2011 Posts: 6980 Location: Durango, CO
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Sat Mar 22, 2014 12:34 am Post subject: |
richparker wrote: |
Today I changed the main jets in my IDFs from 1.25 to 1.20. Still searching for the 20+ mpg. |
Did you used to get 20+ with your engine? I remember the AZ trip thread being low, but I can't remember what you had before.
I almost cooked my engine coming out of Ghila Bend last month with a vacuum leak… 26.6 mpg!! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Sat Mar 22, 2014 3:08 am Post subject: |
ortak wrote: |
The best mpg I've ever got so far has been 20.6. That was on a return trip of only 100 miles from camping, all on secondary roads and no interstates. I got only 16.8 going to the campground which is consistent with all my other mpg's that I get. The total trip would be 18.7. My normal average on long trips of 700 to 3500 miles has been 17.4. But here's the kicker. This avg 18.7 is the first trip I've taken with my new freeway flier tranny. I'm going on another 200 mile trip which has 40 miles of interstate and the rest is secondary roads. I'll post my mpg for this trip when I return. |
There's a dedicated thread for this discussion- perhaps we should migrate this discussion there. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Sat Mar 22, 2014 6:45 am Post subject: |
asiab3 wrote: |
richparker wrote: |
I almost cooked my engine coming out of Ghila Bend last month with a vacuum leak… 26.6 mpg!! |
I was useing Kadrons on the engine when it was first built, I was getting 21 with them. Not the case with the Weber IDF 40s, Only got 16 mpg on the Tucson trip. The engine does run a lot smoother with the Webers. I will fill up today, I'm gonna be useing a tank this weekend driving to the mtb trails to ride. I'll repost on the MPG thread my results.
BTW, 26.6 is crazy for that 1600. Best I saw was 22 with my 1600. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Sat Mar 22, 2014 11:52 am Post subject: |
richparker wrote: |
asiab3 wrote: |
richparker wrote: |
BTW, 26.6 is crazy for that 1600. Best I saw was 22 with my 1600. |
It was a nasty vacuum leak that only showed up under high RPM running. No engine should be subjected to running that lean, ever, but I was hundreds of miles from home with a deadline. _________________ Learn how your vintage VW works. And why it doesn't!
camit34 Samba Member
Joined: January 14, 2006 Posts: 1567 Location: Commerce City CO
Posted: Sun Mar 23, 2014 4:28 am Post subject: |
Drove it to work last night...hate not having a working defroster and freezing rain on my drive! Had to pull over and scrape the ice 3 times on my 18 mile drive.
_________________ In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD) |
Tcash Samba Member
Posted: Sun Mar 23, 2014 9:23 am Post subject: |
[quote="camit34"]Drove it to work last night...hate not having a working defroster and freezing rain on my drive! Had to pull over and scrape the ice 3 times on my 18 mile drive.
Hi
Might try one of these.
http://www.harborfreight.com/catalogsearch/result?q=defroster |
curtis4085 Samba Member
Posted: Sun Mar 23, 2014 10:38 am Post subject: |
camit34 wrote: |
Why is the defrost not working? Have you checked the booster fan fuse in rear? _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
ultralite Samba Member
Posted: Sun Mar 23, 2014 3:43 pm Post subject: |
My lovely wife stitched a new canvas for the front child cot, today we installed it to test fit. The future owner of the Westy is trying it out.
_________________ Godspeed
'76 Beetle (sold)
'69 Beetle (sold)
'72 BMW 2002 (RIP)
'69 Westy
'02 BMW wagon AWD w/stick shift(sold)
'67 Beetle (sold) |
Banjoben Samba Member
Joined: October 02, 2011 Posts: 220 Location: Finger lakes Region N.Y.
Posted: Sun Mar 23, 2014 5:37 pm Post subject: |
ortak wrote: |
I like the "Frig" fuse. I always wondered how to properly "Frig" up an electrical system.. Friggen thing......
Now you need one to protect the Fridge. hehehe _________________ 1974 VW Westfailia Campmobile Deluxe (Clementine)
1970 VW Type 3 fastback. (Abby Normal )
2008 Passat Turbo Wagon Lux
ASE Certified Advanced Level Master Tec / Toyota Master Diagnostic Tec.
Head Boffin of the legendary(does it really exist?) Stray Cat Vintage and Custom Garage. Home of "The Bomber Squadron" |
ortak Samba Member
Posted: Sun Mar 23, 2014 6:59 pm Post subject: |
I also have a great frig. We have a Norcold marine type that runs like a normal frig. It has a 12 volt compressor and we have run it for 4 days solid on battery. _________________ 75 Westy "Vanna", 2.0 with hydraulic lifters and Freeway Flyer Transaxle
2013 Toyota Prius
