christine72 Samba Member
Joined: August 31, 2014 Posts: 84 Location: Portland, Oregon
Posted: Sun Jul 05, 2015 12:03 pm Post subject: Fixed odometer |
Hoping it holds. 2nd try.
Had the ever present broken gear. Re positioned it and put only Sugru on the end. Only let it set up overnight and drove. Worked for half a day then failed.
This time used a Lock-Tight 2 part glue, and Sugru on the end, and wrapped safety wire around it a couple times. Giving the Sugru 3 days to cure.
The wire shown to right of numbered.
Sugru on the end.(white blob)
_________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
1967 Fastback (my first car); 1971 Square back; Several Jettas '88 -'97
The one I regret not buying:
72 Karmann Ghia, with autostick. |
Posted: Sun Jul 05, 2015 1:06 pm Post subject: Cleaned mildew Off tent |
Washed it with Castillo soap and warm water using thick Terry cloth and soft brush removed dirt.. This is what that lrft me with:
After taking the Magic Eraser to it (and rinsing it);
[ _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
Posted: Sun Jul 05, 2015 1:21 pm Post subject: Re: Installed an electronic ignition |
How did you manage without a pointer or a degree scale?
Al[/quote]
Did a triple cross check. Found the mathematical formula to place a mark at specified degrees on the pulley on http://vw-resource.com, and compared my calculations with a graph image in these forum pages. Also confirmed my TDC by rotor pointing to #1. And had to call a friend, because found official Vw specs showing this engine times to 10 degrees and 5 degrees... We went with 7.
Took most of the day too sort that out and a couple minutes to set the timing.
Used the Dremel to add 7 and 32 degree marks on the pulley. _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Sun Jul 05, 2015 2:54 pm Post subject: Re: Installed an electronic ignition |
christine72 wrote: |
Al |
Used the Dremel to add 7 and 32 degree marks on the pulley.[/quote]
WHAT I MEAN IS:
Checking rotor position will give you a measurement with about 30 degrees plus or minus TDC. One can:
1. Put a stop bolt in #1 or #3 spark plug hole and go forward and backward and split the difference to get TDC. (This is MOST accurate.)
2.Do about the same thing with a dial while building the motor.
OR,
3. Just get the factory timing scale or the Bus Depot repop.
This would seem like by far the simplest and most accurate solution.
This picture of a 72-74 that uses a 2 stage vacuum advance; initial is set 5 degrees AFTER TDC with hoses connected, running, of course.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Mon Jul 06, 2015 8:11 am Post subject: Re: Installed an electronic ignition |
69doublecab wrote: |
WHAT I MEAN IS:
OR,
Al |
I'll pick up the replacement scale for good measure (pun).
Trouble is, just had the engine replace. Not quite sure what year it is as went from 1700 to 2000cc.
Also using 009 distributor.
Anyhoo, appreciate the tip. Thanks! _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
Posted: Mon Jul 06, 2015 8:16 am Post subject: Re: Fixed odometer |
Didn't work. Clearly the broken gear is a symptom and haven't addressed the cause. Which confuses me somewhat in that it worked for about 14 miles with the first attempt at a fix.
Should there be any play at all, the tiniest bit, in the 10th of a mile numbered gear? I have none whatsoever.
No problems with the speedometer. _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
Posted: Mon Jul 06, 2015 2:24 pm Post subject: Re: Fixed odometer |
No problems with the speedometer. |
I realize this is a bay. I do not think this is a symptom of anything except bad plastic or perhaps just PLASTIC GEARS.
MOST of them seem to break on Vanagons. I think one can buy the gears somewhere.
I'd like to find out where, also.
Vanagons:
melville Samba Member
Joined: August 09, 2006 Posts: 1245 Location: Just Outside the Redwood Curtain
Posted: Mon Jul 06, 2015 5:34 pm Post subject: |
Pulled the motor and trans from El Kombi and put El Kombi on CL.
I'll have a Samba ad tomorrow. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
Posted: Mon Jul 06, 2015 7:34 pm Post subject: |
melville wrote: |
I'll have a Samba ad tomorrow. |
SOLD!!!
Local sale, and he's a Sambanista. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
Posted: Sun Jul 12, 2015 3:45 pm Post subject: |
Washed the Westy today with the boys. It'll be for sale soon. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
Posted: Sun Jul 12, 2015 7:05 pm Post subject: Re: Fixed Mechanical Odometer Gears |
Al |
Found the gears for $25 each here
Odometer Gears http://www.odometergears.com/products/Volkswagen/Mechanical+Speedometer/19 _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
Goshen Samba Member
Posted: Mon Jul 13, 2015 8:22 am Post subject: Sound deadening of rear are of my bay |
I went to Lowes and bought a roll of this tape 9' x 33' for $19.68 + Tax
I was told by a well known VW guy to use it and i did..
Here are the before and after pics..
I did use clean the surface area that had surface rust with OSPHO and later i used POR-15 so i didnt take photos during that step because i didnt want to get POR-15 on my Samsung Note 4
That stuff doesnt come off at all once applied.. it may take a month to get off your skin.
BEFORE:
AFTER:
*** Yes, that is a 6" Access panel if i should have to replace the Fuel Sending unit sometime without having to pull the motor out. ***
_________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870 |
1967250s Samba Member
Posted: Mon Jul 13, 2015 8:22 pm Post subject: Re: Fixed Mechanical Odometer Gears |
Al |
Odometer Gears http://www.odometergears.com/products/Volkswagen/Mechanical+Speedometer/19 |
I had this same problem on my 944. Only solution was to get all the number rollers off the shaft and clean the shaft and number wheels with alcohol; reassemble with NO grease of any kind, maybe a very light touch of graphite. Any grease or oil left will cause the rollers to bind and same problem appears. Then slightly enlarge the inside hole of the gear so when it goes on, the gear is not spread open, and then glue it on with a touch( and I mean a tiny amount) of epoxy or other permanent glue(locktite). Still holding after 10 years. Boy, was that a hard speedo to open as the back is pinched to the glass with the face ring. _________________ '72 Elm Green Deluxe |
Posted: Mon Jul 13, 2015 8:33 pm Post subject: Re: Sound deadening of rear are of my bay |
Goshen wrote: |
AFTER:
where did you get that access cover assembly?
Vanagons:
Goshen Samba Member
Marya Samba Member
Joined: August 31, 2004 Posts: 353 Location: Portland, OR
Posted: Sun Jul 19, 2015 2:57 pm Post subject: Re: Cleaned mildew Off tent |
Very nice! That's the Rivi pop top yes? I used a wet wipe on a corner to test (was actually the mechanics' kind of wet wipe) and it worked like magic... but not sure about how to best clean the bug screen itself! _________________ 1970, Riviera, 1600 cc type I [single port] |
BerryBus Samba Member
Posted: Sun Jul 19, 2015 6:59 pm Post subject: Re: Cleaned mildew Off tent |
Marya wrote: |
Very nice! That's the Rivi pop top yes? I used a wet wipe on a corner to test (was actually the mechanics' kind of wet wipe) and it worked like magic... but not sure about how to best clean the bug screen itself! |
I need to try the magic eraser when I get the bus back. We did not try that. I hope it looks as good as yours does. _________________ 1970 7 Pass/Riviera/Westfalia - Ours
1968 + 1971 Bus Trailer
1991 Porsche 964 C4 Cabriolet - Mine
2005 New Beetle Convertible - Wife
2012 Touareg TDI |
ohnomrbill Samba Member
Posted: Mon Jul 20, 2015 3:46 pm Post subject: Added Horseshoe Vent |
Mounted a replacement horseshoe vent for my ’73 Westy (the plug and paint job are just temporary so please ignore). It was 3D-printed by these guys based on measurements from the original damaged part ... never found one that fit exactly right from the RV supply places ... maybe I had an oddball or something. Anyway this worked out great.
[/url] _________________ 1973 Westfalia Tintop |
Posted: Thu Jul 23, 2015 9:58 pm Post subject: |
Got bus back from paint. Now, putting back together. (Separate thread)
Also dyed my curtains. I posted in separate thread as well.
2012 Touareg TDI |
