SixStringMadMan Samba Member
Joined: December 02, 2011 Posts: 263 Location: Roseville, CA
Posted: Sun Feb 07, 2016 7:34 am Post subject: Re: What did you do for your Bay recently? |
After installing new rubber hoses and brakes all the way around 6 months or so ago, I finally got some free time to take the next step. Had a friend over and we bled the brakes. Then we got a new battery in and fired the beast up. She turned over and ran after only 3 tries. Did we get a chance to drive her around and test the brakes at that point? Of course not... I swear every time I think I'm in the clear to work on the bus, life creeps in and takes over.
Hopefully I can drive her next weekend and see if the brakes are adjusted properly. Then it's getting her ready to pass smog. Oh joy. _________________ 1978 Kombi
http://www.vw-mplate.com/mplate-10020.htm |
melville Samba Member
Joined: August 09, 2006 Posts: 1247 Location: Just Outside the Redwood Curtain
Posted: Tue Feb 09, 2016 4:14 am Post subject: Re: What did you do for your Bay recently? |
airkooledchris wrote: |
melville wrote: |
Sold it!
After 23 years and a half dozen or so of these, we are once again fatchick free chez melville.
Spozedly it's going to the Netherlands. |
Sad that we lost an excellent T4 bay from up here in waynorcal, but you can't keep em all (try as we might.) |
They want them more than we do. All the interest I got from the Samba ad was from Europe, but none were able to pull the trigger. Bus was sold on eBay to a Bay Area broker who was bidding on behalf of a Dutch buyer.
Having relatives in the Netherlands myself (the Dutch are legendarily frugal) I can say that if they're outbidding VW people in the US, that we have to be the cheapest folk around. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Tue Feb 09, 2016 10:25 am Post subject: 221 255 795 Intermediate piece-Heater pipe (LHD) |
Over the last week or so, I did a bunch of winter time maintenance and repair on my frankencamper. The standard stuff like oil/filter change, valve adjust, etc. I messed around with the front end alignment cause I thought the drag link was bad (it's fine). I finally installed a pedal pan, too. Only been six years since I have had both the bus and the pan, I figured it was about time to mate them together.
While I had the bus on the lift and the wood stove was crankin', I figured I would try to figure out why my heat cable to the passenger compartment was stuck. This is the one that blows heat out right at the base of the front seat walk though area. The knob would only move just slightly so I figured the cable was stuck. So I pulled it off at the main feed line underneath.
Here is the connection with the flap inside.
And here is the reason the flap wouldn't move...
Somebody, sometime, way back in the life of this bus, shoved this little brass lock down the heater slot. _________________ nothing |
Tcash Samba Member
Posted: Tue Feb 09, 2016 11:24 am Post subject: Re: What did you do for your Bay recently? |
That is an unusual lock
http://www.ebay.com/itm/Vintage-FTH-MACH-2-commemo...SwnLdWqUuW
cdennisg wrote: |
Is that #36? 221 255 795 Intermediate piece-Heater pipe (LHD)
Thanks you
Tcash |
Posted: Tue Feb 09, 2016 12:06 pm Post subject: Re: What did you do for your Bay recently? |
Looks like #36 to me.
The lock is tiny. Neat engraving, though. I didn't find a key. _________________ nothing |
zoobum Samba Member
Joined: June 09, 2015 Posts: 211 Location: Los Angeles
Posted: Tue Feb 09, 2016 9:51 pm Post subject: Re: What did you do for your Bay recently? |
Painted the sliding door handle while at the beach.
I went to the beach for 10hrs this Sunday and decided to paint the sliding door handle while I was there. It was beautiful outside and what better time then now to work on the bus.
After the handle was on and painted we decided to go down to the beach and build a fire.
Another Great day w/ the bus.
Nothing fancy, but much needed.
Before:
After:
Sunset & Fire:
Goodhand77 Samba Member
Joined: August 18, 2013 Posts: 236 Location: Forest Ontario
Posted: Sun Feb 14, 2016 4:04 pm Post subject: Re: What did you do for your Bay recently? |
well guys my westy didn't come with a dinette table so i built one using actual dimensions and as the process went it greatly improved installing cup holders first than it5 turned into double hinged and multi functioning:)
worked great
_________________ my world consists of my three girls , my wife and my daughters
and my 72'S!!!!!
1972 beetle sedan almost original
1972 westfalia current project, and loving it!!! |
danfromsyr Samba Member
Posted: Mon Feb 15, 2016 1:11 pm Post subject: Re: What did you do for your Bay recently? |
this is a great idea/improvement.
you should have inlaid a smile into the face.
Goodhand77 wrote: |
worked great
Abscate wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Mon Feb 15, 2016 1:47 pm Post subject: Re: What did you do for your Bay recently? |
danfromsyr wrote: |
Goodhand77 wrote: |
worked great
Pretty clever to have it double hinged for the cups then laid down for the bed _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Mon Feb 15, 2016 2:40 pm Post subject: Re: What did you do for your Bay recently? |
This is genius. _________________ nothing |
Jalabert Samba Member
Joined: December 06, 2005 Posts: 632 Location: On the coast in NZ, somewhere...
Posted: Mon Feb 15, 2016 6:41 pm Post subject: Re: What did you do for your Bay recently? |
Good work! _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
'73 westy, 1700 type 4 with 34icts |
fastmc25 Samba Member
Joined: January 01, 2004 Posts: 1202 Location: East Tennessee
Posted: Fri Feb 19, 2016 5:43 am Post subject: Re: What did you do for your Bay recently? |
Finally got the wheels i've been wanting for my new build.... Meet Pickle... soon to be rolling on 17x7" New Beetle Heritage wheels...
_________________ Peace,
Paul
1973 Type181 Kubelwagen (Thing 2 ) 2110cc
1971 Transporter (Pickle) 1914cc
1961 Deluxe Beetle (Christine) 1776cc
1973 Adventurewagen Baja Bus (Clyde) 3.4L
1970 Formula Vee Beetle 2276cc
I identify as: “A Pissed Old GI ” |
MonkeySee Samba Member
Posted: Fri Feb 19, 2016 9:30 am Post subject: Re: What did you do for your Bay recently? |
Installed LED headlights in the '70. Also shown but not posted before, installed vintage Hella driving lights
converted to LED using camping lanterns from WM. Looks super at night. Now to work on LED-ing the other
lights as well.
Posted: Fri Feb 19, 2016 9:35 am Post subject: Re: What did you do for your Bay recently? |
Goodhand77 wrote: |
worked great
I'm so stealing this idea for my other '70 which I also didn't get with a table. |
Posted: Fri Feb 19, 2016 10:45 am Post subject: Re: What did you do for your Bay recently? |
Sooo worth it , works great , feel free to pm me when you getting ready I would gladly share a few of me trial and errors upon the completion of project took a lot of time to get it "just right" for my pride and joy!!!
We love our vws!!!! _________________ my world consists of my three girls , my wife and my daughters
and my 72'S!!!!!
khalimadeath Samba Member
Posted: Fri Feb 19, 2016 11:29 am Post subject: Re: What did you do for your Bay recently? |
Goodhand77 wrote: |
We love our vws!!!! |
Ill be making mine like yours soon, post any tips here so we can reference them here. |
Derek Cobb Annoying
Posted: Fri Feb 19, 2016 2:45 pm Post subject: Re: What did you do for your Bay recently? |
MonkeySee wrote: |
Goodhand77 wrote: |
worked great
I will be shamelessly stealing this as well for my 69. Elegant solution. |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri Feb 19, 2016 3:56 pm Post subject: Re: What did you do for your Bay recently? |
GoodHand Awesome job and well thought out too......
I do have a question though. What did you use for the table leg ?
I have a westy interior and the factory table leg broke at the pivot
bracket so it's kaput.
Thank You for sharing.
Chris _________________ V.W.owner since 1967 |
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Fri Feb 19, 2016 8:23 pm Post subject: Re: What did you do for your Bay recently? |
I have been gathering parts squirrel style over the winter months. Carb from Tim at volkzbitz, intake manifold and a Pertronix" II SVDA Distributor from aircooled.net. Bus is in storage an hour away, it'll have to wait. _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
sean14538 Samba Member
Joined: June 03, 2014 Posts: 161 Location: West Jefferson, OH
Posted: Sat Feb 20, 2016 6:42 pm Post subject: Re: What did you do for your Bay recently? |
Do you think that you could post the link of what lights you bought? they look great!
MonkeySee wrote: |
lights as well.
_________________ '71 Westy - 1600cc
Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=631317
How to post photos:
