Wayland Samba Member
Joined: December 29, 2005 Posts: 498 Location: Lasqueti Island B.C.
Posted: Fri Mar 07, 2008 4:42 pm Post subject: Bumpers and Bumper Trim |
Here is a breakdown of front and rear bumpers:
50-58 Buses used "ribbed" or "pressed" bumpers, front and rear.
Front
http://www.thesamba.com/vw/forum/album_page.php?pic_id=57496
Rear
http://www.thesamba.com/vw/forum/album_page.php?pic_id=57497
50-early 56 Buses have the "Wolfsburg" front bumper as the ribs are longer, creating a smaller license plate area in the front.
Longer ribs
http://www.thesamba.com/vw/forum/album_page.php?pic_id=2593
Long vs. short ribs
http://www.thesamba.com/vw/forum/album_page.php?pic_id=335916
Distance between the ribs is 17" (43cm) vs. 21.5" (55cm)
Barndoor Buses had weld nuts welded to the back of the front bumper for the license plate to mount. Non-Barndoor Wolfsburg bumpers eliminated these.
Weld nuts:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=600227
Rear pressed bumpers were introduced at different times for the different models:
Deluxes at Chassis # 20-047102
Standard Microbus, Kombi, and Panelvan at Chassis # 20-069409
Pick-up at Chassis # 20-079856
The rear pressed bumper for the 54-58 truck had sharper, right-angle, corners to allow for the truck corners:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=546832
(Reproduction bumper but same shape)
In 1959, larger front and rear bumpers were introduced.
Specifically:
29 Aug. 1958 - Chassis # 384 816 (European)
29 Aug. 1958 - Chassis # 384 875 (Export - USA and others)
Reference:
http://oacdp.com/progref4061/a021.jpg
Slash rear:
Slash front and pointed rear:
59-early/mid 1960 Trucks use a "truck only" rear bumper due to the shape of the rear corners. The corners are much more square. It's hard to distinguish the difference between the 2 bumpers unless they are side by side. A Bus rear bumper can be lightly ground along the top edge to fit these early truck corners.
59-65 Buses use slash end front and rear bumpers.
In mid-65 VW began using pointed rear bumpers
66-67 both bumpers had pointed ends.
For 59-67:
Front bumper trim was always pointed.
A mid-late '65 deluxe would have pointed rear bumper with slash trim.
66-67 had pointed rear bumper trim
Slash front:
Pointed front:
More discussion
http://www.thesamba.com/vw/forum/viewtopic.php?t=159879
Hardware used, from the Bus parts book:
Front bumper brackets to body:
Ribbed bumpers:
4 - M8x25
4 - M8 Washer
4 - M8 Lock Washer, galvanized
59-67 Bumpers, brackets to body:
4 - M10x20, galvanized
4 - M10 Spring washer
4 - M10 Lock washer, galvanized
Front bumper brackets to bumper/overriders:
2 - M8x60
2 - M8x70
4 - M8x20 (includes side brackets)
Rear bumper brackets to body:
4 - Lock washer, galvanized
4 - M10 Nut, galvanized
Rear bumper brackets to bumper/overrider:
2 - M8x50
2 - M8x70
Splash pans to body, upper mount:
2 - M8x15
2 - M8 Lock Washer, galvanized
Splash pans to body, lower mount:
2 - M5x12
2 - M5 Lock washer
2 - M5 Nut
Splash pans to bumper, lower mount:
2 - M8x20
2 - M8 Spring washer
2 - M8 Lock washer, galvanized
Splash pans to bumper bracket:
2 - M5x12
2 - M5 Lock washer
2 - M5 Nut
Bumper trim mounting position discussion:
https://www.thesamba.com/vw/forum/viewtopic.php?t=185854 |
vwrus66 Samba Member
Joined: February 08, 2006 Posts: 141 Location: Spokane Washington
Posted: Fri Mar 07, 2008 10:26 pm Post subject: |
Speaking of bumper trim does anybody sell a repop set? _________________ 60 Mango
64 13 Window
66 Beetle |
Daniel Samba Member
Posted: Fri Mar 07, 2008 11:05 pm Post subject: |
I think Creative Engineering in the UK does them, but not 100% on that one.
Someone should start, there would be a lot of people who would want them. |
deluxe hunter Samba Member
Posted: Sun Mar 09, 2008 2:37 am Post subject: |
what about bumper trim for pressed bumpers ?
Will either the slash or point trims fit the pressed bumper's curves? |
Rich Hanson Samba Member
Joined: February 10, 2004 Posts: 61 Location: Becker, MN
Posted: Sun May 10, 2009 7:08 am Post subject: bumper trim |
Pressed bumpers are a different profile than American or Euro bumpers. Westling Machine has started manufacturing them and ships quickly. I bought the first set of production for my 57 and they fit perfectly, even had holes pre-cut to clearance for the bumper bolts. check out westlingmachine.com
Rich _________________ Ragtop Rich
61 Ragtop Bug
60 Bug
57 23-Window Bus
57 oval window
83 1/2 Westy |
bherder Samba Member
Joined: July 19, 2008 Posts: 374 Location: Portland/Forest Grove, OR
Posted: Wed Dec 02, 2009 1:48 pm Post subject: |
Figured I would post my question in the bumper "FAQ" thread. After looking at many pics in the gallery, I think I figured out the difference between slash and pointed bumpers.
Just to clarify, does a 1966 have pointed on both front and rear? _________________ My bus resto thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=371654
Parts manual:
http://oacdp.org/ |
DownRiver Samba Member
Joined: January 05, 2003 Posts: 797 Location: threeonethree
Posted: Wed Dec 02, 2009 2:22 pm Post subject: |
Yes, 66 is pointed, pointed.
I was looking through bumper threads today too. My question involves a rear pointed bumper.
Is there supposed to be a transition on the top of the bumper, a couple inches in from the insides of the uprights?
hard to confirm in pictures. _________________ Whether you think you can or think you can't, you're right. -Henry Ford
VanSlyke VW Doublecab |
Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Sat Feb 25, 2012 10:37 pm Post subject: Bumpers Slash & Pointed |
Hi,
I did read this posting about what bumpers the buses came with originally.
Currently, my 1966 has a front pointed with the deluxe trim and the rear is a slash bumper, but no deluxe trim.
I have seen a few buses with the slash bumper in the front as well and I like the look.
From what I read on the thread my 1966 came with both pointed bumpers.
Is it still considered a stock look with the slash bumper in the front?
Also, will all of the parts from my diamond front bumper currently on my bus, will those be able to be bolted onto a slash bumper, are the parts interchangeable?
Thank you for the response,
Spitty |
Posted: Sun Feb 26, 2012 9:15 am Post subject: Bumper Trim |
Go to westlingmachine.com. Alex has the correct bumper trim listed by year appropriate references. I believe it to be very accurate as to what is supposed to be on each year of bus.
61 Ragtop Bug
60 Bug
57 23-Window Bus
57 oval window
83 1/2 Westy |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Feb 26, 2012 2:26 pm Post subject: Re: Bumpers Slash & Pointed |
Spitty1974 wrote: |
Also, will all of the parts from my diamond front bumper currently on my bus, will those be able to be bolted onto a slash bumper, are the parts interchangeable? |
Q1- I think only the bus nazis will scoff at using a pre-66 front bumper on your bus. It was commonplace to install whatever was laying around when repairing accident damage (as was the case with my deluxe)- so don't fret IMO. I'd run it until a great deal comes along on the right year.
As for the aluminum trim- these are PLENTIFUL for your bus. I would not buy new fronts when there are always plenty in the classifieds. The rears for 66-67 only are a different story. These are harder to come by- grab the first set you can get if your's are missing.
In Q2- Are you referring to a pointed bumper as "diamond"? I don't know what you are talking about here. Elaborate- or post a picture. _________________
EverettB wrote: |
FU#5 |
Posted: Wed Feb 29, 2012 4:13 pm Post subject: Re: Bumpers Slash & Pointed |
hitest wrote: |
Spitty1974 wrote: |
In Q2- Are you referring to a pointed bumper as "diamond"? I don't know what you are talking about here. Elaborate- or post a picture. |
I was asking if my pointed bumper parts from my front bumper, would those work with a slash bumper? The two guards and the towel bar, are the parts interchangeable? Also, if it does not have holes for the deluxe trim, do people drill holes in them to make them deluxe style bumpers?
Thank you for the response and the help. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Wed Feb 29, 2012 7:21 pm Post subject: Re: Bumpers Slash & Pointed |
Spitty1974 wrote: |
I was asking if my pointed bumper parts from my front bumper, would those work with a slash bumper? The two guards and the towel bar, are the parts interchangeable? Also, if it does not have holes for the deluxe trim, do people drill holes in them to make them deluxe style bumpers? |
Parts are the same. Drill away: using the deluxe trim as a guide. I just finished welding holes shut for the opposite of what you want. |
Posted: Thu Mar 01, 2012 4:15 pm Post subject: Re: Bumpers Slash & Pointed |
Parts are the same. Drill away: using the deluxe trim as a guide. I just finished welding holes shut for the opposite of what you want.[/quote]
I have a deluxe, but I may just run the bumpers without the bumper trim. I've seen several buses in the galleries with deluxe beltline, and no deluxe trim on the bumpers......I have ample time to decide, but was looking at at least buying another slash bumper so that they match up. I go back and fourth and at times think I may run mine without the trim pieces....
There is so much I am learning and so many experts willing to share their knowledge.......Thanks! |
Scooterboyd Samba Member
Joined: January 18, 2009 Posts: 342 Location: Rancho Cordova, California
Posted: Thu Mar 01, 2012 5:20 pm Post subject: |
I know this is a Barndoor, but this rear or lack of rear bumper looked wierd to me until it was confirmed that the trim did mount on the body.
_________________ President of "Society of Unappreciated Overachievers"
62 - 23 Window Bus
60 - Karmann Ghia Convertible
59 - Convertible Raceable Baja Bug
63 - Dune Buggy
65 - Single Cab |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Thu Mar 01, 2012 5:23 pm Post subject: |
I have deluxe bumpers on my '65 standard, and it's driving me nuts. I don't have the trim, just the holes. To make matters worse, they are far and away too nice for my bus. Tryin' to find someone local to trade with hasn't paid off, so I wait. |
maverick98 Samba Member
Joined: January 26, 2012 Posts: 8 Location: Buckley, WA
Posted: Thu Mar 01, 2012 5:57 pm Post subject: |
On my 57 the side mounts to the body from the end of the bumpers are missing. Are there splash pans that go in there or are there just mount that go straight to the body. If so any repop versions that I can get.
Thanks,
Kevin |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
kingsfanrob Samba Member
Joined: December 24, 2007 Posts: 126 Location: San Dimas
Posted: Tue Jun 26, 2012 8:02 am Post subject: |
Which bumpers are correct for a 12-2-58 bus? I have the front and it is slash with no holes for guards or over riders. It is a US spec car. High tail light. |
Posted: Tue Jun 26, 2012 11:30 am Post subject: |
Thanks Everett. |
