stigg99 Samba Member
Posted: Sun Mar 09, 2008 9:28 pm Post subject: So I think i need a 4 inch narrowed beam? |
I want to use stock wide 5 steels, but if i ever wanted to change the steels out for say BRM's or something else. Would i have a problem with tire rub if the front is narrowed, say 5-6 inches? Those are number's i jsut came up with in reality i have no idea how low it will be, but i would like the option to go as low as i want. Any help is much appreciated. |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Mon Mar 10, 2008 8:44 am Post subject: |
You'd be better off with an 8" beam,or even a 9".
6.5"beams are the norm now
Check out the pics of GermanPride's 58;his is still too high but will give you an idea of how your bug will look lowered on a 6" beam _________________ die schwarzen Schafe #666 |
dubsquared Samba Member
Posted: Mon Mar 10, 2008 8:47 am Post subject: |
6" beam...
before:
after:
_________________ 65 hp air-cooled, now with 100 hp
800+hp water-cooled
Both VWs... |
hpw Samba Member
Alan Willis Banned
Posted: Mon Mar 10, 2008 12:06 pm Post subject: |
Even better;hows the turning radius _________________ die schwarzen Schafe #666 |
Posted: Mon Mar 10, 2008 1:28 pm Post subject: |
hpw wrote: |
I would love to know what that does to the lateral accerlation(g's)
before and after |
Yeah, lemme go put it on the skid pad and get back to you.
You think any of these cars with 165s or smaller up front can turn for anything?
This thing is a toy for me. _________________ 65 hp air-cooled, now with 100 hp
800+hp water-cooled
Both VWs... |
Cloud9Alpine Samba Member
Joined: April 03, 2007 Posts: 199 Location: Tacoma WA
Posted: Thu Mar 13, 2008 7:44 pm Post subject: |
Alan Willis wrote: |
You'd be better off with an 8" beam,or even a 9". |
thats crazy talk. i personally dont like bouncing around the road because i cant run shocks.
I've always thought 4" was plenty unless you want a hardcore hammerhead look (and like bouncing around). |
Posted: Fri Mar 14, 2008 8:29 pm Post subject: |
hpw wrote: |
dubsquared wrote: |
6" beam...
before:
after:
before and after |
A bit late in the week. Where does the time go?? Anyways, that 6"er looks good, does anyone sell them adjustable or do i have to make my own? (not a problem.) |
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: Escondido
Posted: Mon Mar 17, 2008 11:14 pm Post subject: |
I don't think I've ever seen a narrowed beam for sale that was not adjustable.
I had a five inch on one of my old cars and it was not bouncy at all! You would have never known there were not any shocks under it.
In answering the original post. If you run a 5 or 6" beam with stocks, you will not have a problem bolting up a set of said BRMs. You will have more rubbing issues (on the inner fender) with the stocks than with any other aftermarket wheel. It's all about the backspacing. _________________ 1959 Ragtop Beetle - sold
1958 Danish Beetle
1967 SO-42 West. - sold
1961 Sunroof Beetle - sold
1969 Sunroof Beetle |
Posted: Tue Mar 18, 2008 7:14 am Post subject: |
If you have urethane bushings, you don't need shocks. But with the stock needle bearings, with shocks, you will be in for a seriously sketchy bouncy ride...
No shocks, you have to have urethane bushings. _________________ 65 hp air-cooled, now with 100 hp
800+hp water-cooled
Both VWs... |
surferdudedav Samba Member
Posted: Tue Mar 18, 2008 5:33 pm Post subject: |
i got 4" w/ needle bearings and no shocks it doesnt bounce around alot.. rides like a caddy...
Kuncle I am Kyle Deese
Joined: June 08, 2005 Posts: 1284 Location: Greer...South Carolina...
Posted: Tue Mar 18, 2008 7:28 pm Post subject: |
I have a seven inch beam on empi 5s and I still have full turning radius and can cut a U turn in a 2 lane road.. Do Werk _________________ Ost Kuste. |
Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Wed Mar 19, 2008 11:17 am Post subject: |
Narried beams are dangerous!!!!
I have a 4" in my car and hate it with stock wheels, it ISNT narrow enough. My wheels rub the fender before they rub the inner.
5 or 6 is perfect with the right wheels. You could always go 5.5 and have the best of both worlds.
Of course the 8" beam in my ghia with Sprints turns lock to lock. _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
67bugnut Samba Member
Posted: Wed Mar 19, 2008 11:36 am Post subject: |
It helps to know what rims your going to run before the beam work. Overall 6 inch will usually do the job. |
Posted: Wed Mar 19, 2008 10:12 pm Post subject: |
I was planning on going with regular 15 inch steels, and possibly switch to BRMs if i felt they might look b etter down the road. On the other hand if someone would sell some 16 or even 17 inch radars in the states, those would be the wheels of my choice....But it's looking like steels for now.
EDIT: forgot to add, does anyone like CB performance or online sell a 6 inch narrowed beam or do i have to make it on my own? (think i asked this already?) |
JDGas Samba Member
rory_a Samba Member
Posted: Wed Mar 26, 2008 12:26 pm Post subject: |
There's always narrowed beams listed in the classifieds. I got a 4" from Keoki. Great work, I'm very happy with it. The shock towers are flexible in/out, but solid with the stroke of the shocks.
Running 17" BRMS, CB dropped spindles, discs, stock (Austrian aftermarket) steel fenders, stock body, and no rubbing, with one adjuster about mid range, the other removed, although the car is still just a roller awaiting paint and reassembly. I pulled the bottom adjuster to check clearance at ride height during body work. Keoki indexed the adjusters for use with dropped spindles so it wouldn't sit low enough as a bare shell without removing the adjuster.
Keoki makes great beams and offers 5" and 6", with adjusters but no shock towers. |
heycop2002 Samba Member
Joined: March 05, 2008 Posts: 5 Location: Kansas City Area
Posted: Tue Apr 01, 2008 10:29 pm Post subject: |
Does anyone have a pic of a 4" narrowed beam, w/ an empi 15" 5 spoke? _________________ 67 bug, work in progress
2005 Jetta GLI 1.8T |
JDGas Samba Member
rory_a Samba Member
Posted: Wed Apr 02, 2008 12:54 pm Post subject: |
Wait - you can search for images? |
