toomanyveedubs Samba Member
Joined: November 26, 2007 Posts: 596 Location: Great White North
Posted: Wed Mar 30, 2011 11:25 pm Post subject: Syncro Off Road tool kit help needed |
I just got a decent bonus at work and feel like spending some of it on my Syncro.
I'll be attending Syncro fest in a couple weeks and was thinking of getting a hi lift jack, shovel, axe, chains, straps, that kind of stuff. Better to be prepared right! I already(only) have a small air compressor and tire repair kit.
Suggestions anyone? What are the off road must haves? Best price vendors?
Tia |
JED THE SPREAD Samba Member
Joined: July 14, 2009 Posts: 626 Location: South London UK
Posted: Wed Mar 30, 2011 11:42 pm Post subject: Re: Syncro Off Road tool kit help needed |
toomanyveedubs wrote: |
Tia |
Hi Tia,
This might be of some interest to you and may help you out a little, Its a list of recommended tools to take away with you.
http://campervanculture.com/2011/03/tools-to-take-away-in-a-syncro/
Jed _________________ Visit CAMPERVANCULTURE.COM real camping and video uploads
Subscribe to Campervan Culture by Email
Follow us on Facebook, Campervanculture.com |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Thu Mar 31, 2011 12:11 am Post subject: |
I agree with SyncroDoka that if traveling or offroading with a group you don't need a lot of things that you would normally need for solo. Strap/shackle, shovel, handheld CB radio (normally used on trails - not sure what the Syncro world uses) sturdy work gloves, proper recovery hooks front and rear, and a way to air up the tires would be paramount. Much beyond that for solo travel and your gear would be shaped by the type of terrain you intend to traverse. For instance, sand/desert/beach means sand ladders, and river crossings mean a tarp to cover the grille and snorkel (neither apply to Syncros, oddly), etc.
To me one of the best upgrade pieces of gear for any kind of offroad use would be a quality set of sturdy offroad tires. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Thu Mar 31, 2011 12:23 am Post subject: |
Any VHF radio suggestions? Any syncros got one mounted in their rig? |
Posted: Thu Mar 31, 2011 12:31 am Post subject: |
Aren't those for boats? |
Jon_slider Samba Member
Posted: Thu Mar 31, 2011 8:15 am Post subject: |
Sure, we will be glad to help you spend your money on toys.. er tools
http://www.hi-lift.com/accessories/index.html
If you choose to build up a kit based around a Hi Lift, (very good idea)
1. I recommend the Wheel lift accessory because it allows you to get out of a hole by piling stuff under the tire.
If you jack from the normal jack point, also a desireable part of the kit, it takes a lot more lifting to get the tire high enough off the ground to fill in a hole.
If you want hi lift winch ability, then you want the ORK and 30' of chain, and possibly also a snatch block (pulley)
lots of recovery gear ideas here
http://www.expeditionexchange.com/cart/home.php?cat=268
here is an article about the Hi Lift
http://www.bb4wa.com/articles/hilift_jack.html
2. You might enjoy owning a set of Staun deflators
http://www.4by4connection.com/stauntirdef.html
3. The Bushranger Xjack has always interested me, buy one and tell us what you think <g>
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Thu Mar 31, 2011 5:16 pm Post subject: |
You might consider a second compressor, depending on your tire size, it can take a very long time to air all 4 back up to highway pressure. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
Posted: Thu Mar 31, 2011 8:43 pm Post subject: |
Agreed, but that also means your group needs one operator's licence per equipped vehicle, might be tough to arrange.
I have a FCC Radiotelephone licence, I'm pretty sure I can use anything on the market, but I don't know anyone else that could go out with me in another van. _________________ '86 Syncro CHC Top AAZ Turbodiesel
Posted: Thu Mar 31, 2011 8:53 pm Post subject: |
But only a simple exam to get the license, why not?
Bettery than the 2way walkies I use now. |
Posted: Fri Apr 01, 2011 12:22 am Post subject: |
Oh, you are talking about ham radios. I usually hear of VHF for boats- just different lingo.
The thing about CBs is that they are easy/cheap to get and many people have them, ham radios not so much. They are stronger and can travel much farther but someone has to be on the other end to pick you up. If you are using FRS 2 way radios right now anything is a upgrade.
The rock crawler deflator that you bought will probably never see use unless you are running bead lockers. The standard one goes more than low enough for most people. I rarely even go under 25 PSI which those deflators cannot even go to. |
Baxta Samba Member
Joined: November 09, 2008 Posts: 356 Location: Abbotsford, BC
Posted: Fri Apr 01, 2011 6:55 am Post subject: |
Just noticed that Cambodian Tire has their hi-lift jack on for $49.99 this weekend... Not an endorsement, just a notification! _________________ Greg
'87 Syncro Westy 'Bastian'
2.2l |
Posted: Fri Apr 01, 2011 7:30 am Post subject: |
syncrodoka wrote: |
Right now I run my 235/75r15 BFG MT at 28psi on the street and at SDM last year ran them at 18-20psi in the dirt. Your probably right, the low psi version may not get used except if I hit the sand or snow. What size tires do you run at 25psi? |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Fri Apr 01, 2011 7:38 am Post subject: Re: Syncro Off Road tool kit help needed |
What are the off road must haves? |
Often overlooked, but...
No 1 on my list is an expedition level First Aid Kit
..and the knowledge to use it.
Classes are offered in wilderness medicine.. Do some research on whats available in your area... as they vary by quaility of instructor.
Check your local community college.
You don't need to be a medic. But a one week course will go a long towards being prepared for most all emergencies.
Also.. regarding hi-lift jacks. There is only one brand "Hi-Lift" and any other is a knock-off. I got by for years with a knock off. But there was no rebuild kit available, the paint was crap.. and the thing rusted into oblivion in 5 yrs. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Posted: Fri Apr 01, 2011 9:01 am Post subject: |
(background, tire pressure calcs.. vehicle weight divided by max load of 4 tires, times max pressure.) In practice I find 120% to 140% of that calculation useable, subject to test driving. In the case of the 215, I think 140% is closer to what seems to actually work.
Mario runs a 215x75x15 bfg AT KO rated for 1765lbs @ 50 psi
If Mario runs 40psi street front, +5 rear, (thats 140% of the calculated pressure) then 25psi offroad makes sense for that tire, (24psi is the calculated 60% of his front street pressure)
a BFG KM2 mud terrain is rated 1985lbs@50psi
the 215 has a load range of 100, the 235 has a load range of 104, meaning the sidewall is stiffer on the 235
sample calculation for 215 tire, assume doka weight is 4000lbs (verify that) 4000lbs divided by (1765*4) times 50 = 28psi, times 1.4 = 40psi
60% of street pressure gives offroad pressure of 24psi.
sand at 50% of offroad gives 12 psi
sample calc for 235 tire, 4000/7940*50=25 psi, times 1.2 = 30psi street, offroad at 60% = 18psi.. sand at 50% of offroad gives 9psi
for your beefier tire, I think 120% of calculated pressure makes sense, it is 30psi.
What is your actual driving experience?
How does the wear pattern look with your current inflation, seem even accross? How does it handle pavement curves, not too much body roll?
for yanking
ARB 8,000 KG Snatch Strap (ARB705)
SKU: ARB705
for the hi lift as a winch
Curt Manufacturing 3/8" x 20' Grade 70 Chain With Clevis Grab Hooks (J311)
ARB Snatch Block 9000 (10100020)
SKU: 10100020
For D-Ring Shackles, I prefer these beefy ones
http://www.4by4connection.com/drings.html
the 3/4 is rated at 6.5 tons,
whereas the normal 3/4" shackle from here:
http://www.expeditionexchange.com/cart/product.php?productid=18458&cat=268&page=1
is rated for 4.75 tons
Posted: Fri Apr 01, 2011 9:09 am Post subject: |
Thanks John. I run 28 & 32 based on calculations you did for me last year. Tire wear is dead even and handling is very stable/good right up to 70mph (my trucks top speed) |
Posted: Fri Apr 01, 2011 9:19 am Post subject: |
Where to mount shackles? |
