Gatesvillebill Samba Member
Joined: March 26, 2008 Posts: 5 Location: Gatesville, Texas
Posted: Wed Mar 26, 2008 10:32 am Post subject: Wiring for 1974 Alternator with internal regulator |
Howdy from Texas. I am bringing back to life a 1969 Bus. I bought the thing without engine or transaxles, both of which are now installed. The engine came out of a 1974 Beetle, and I have been unable to determine what the three wires coming out of the plug on the internal voltage regulator attach to. One is red, one is green and the other is white. I assume the big connector post to the right of the round plug on top of the alternator goes to the battery + terminal, but I don't know what the three smaller gauge wires go to. I assume one goes to the "idiot" light on the instrument panel, but do not know which one. I am afraid I'll do harm to the alternator if I start connecting those three wires willy-nilly. Any help would be greatly appreciated. I have looked in Haynes manuals and all I find is a generic wiring diagram that does not address the three wires.
Thanks for any help,
Bill Herridge, Gatesville, Texas |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19612 Location: Samba Center for Behavioral Science
Posted: Wed Mar 26, 2008 10:34 am Post subject: |
If you alternator has 3 spade connection coming out the top it is an AL 78 not an AL 82 ( internal) and it takes an EXTERNAL voltage regulator...
this is an AL 78 that used the external regulator under the rear seat.
and this is the AL 82 unit with the internal regulator inside the alternator housing
 _________________ my seller feedback
rebuilt carb info = for sale
"STFU Polly and go eat a cracker!" 12-21-2012.... can't wait! |
Posted: Wed Mar 26, 2008 11:52 am Post subject: |
Thanks for the reply, but I'm somewhat confused. The alternator has a VW part number on it, and is stamped with the VW logo and was made in the US. When I had a local parts house look that number up, it indicated that the 1974 was the ONLY year that particular part number was used. It also showed that alternator to have an internal regulator. I still need to know what the red, green and white wires coming out of the plug on the top of the altnernator are connected to. I have a wiring diagram for a 1969 bus but since the engine now installed came from a 1974 Beetle, my diagram doesn't help with the alternator question. The alternator that is on the engine has a plug similar to the one shown in your photo, but the big connector post is located just to the left of the circular plug. I have no problem jerry-rigging an external alternator but I still need to know what the wires are for coming from the round plug.
Bill Herridge |
Posted: Wed Mar 26, 2008 12:09 pm Post subject: |
| Gatesvillebill wrote: | Thanks for the reply, but I'm somewhat confused. The alternator has a VW part number on it, and is stamped with the VW logo and was made in the US. When I had a local parts house look that number up, it indicated that the 1974 was the ONLY year that particular part number was used. It also showed that alternator to have an internal regulator. I still need to know what the red, green and white wires coming out of the plug on the top of the altnernator are connected to. I have a wiring diagram for a 1969 bus but since the engine now installed came from a 1974 Beetle, my diagram doesn't help with the alternator question. The alternator that is on the engine has a plug similar to the one shown in your photo, but the big connector post is located just to the left of the circular plug. I have no problem jerry-rigging an external alternator but I still need to know what the wires are for coming from the round plug.
Bill Herridge |
Simple.. look at a wiring diagram for the 74 type 1...
also what you have is then a MOTOROLA alternator ( look for the M in a circle on the front of the housing) they supplied them and were used as well as the Bosch AL 78.. but if it has 3 prongs ( no matter what) it is for an external reg. _________________ my seller feedback
BDSBSS23 Samba Member
Joined: January 03, 2008 Posts: 1598 Location: Home of the potatoes.
Posted: Wed Mar 26, 2008 9:11 pm Post subject: |
| Brett Ross wrote: | | Kiefernet where did you get that alternator AL 78? |
That is a pic that Glenn has posted many times... I do have a couple of used ones on the shelf though. _________________ my seller feedback
souwilpa Samba Member
Posted: Thu Mar 27, 2008 9:16 am Post subject: Alt. wiring |
This may help too. The Samba has lots of wiring diagrams listed in technical-wiring.
C=Alt. & C1=Regulator
Look to the left hand side.
Thanks to those who have contributed these diagrams.
God Bless!! _________________ If you don't crank it, it want wear out;
If you don't crank it, you want go anywhere! |
thing1 Samba Member
Posted: Thu May 01, 2008 12:51 pm Post subject: wiring plug for Motorola regulator |
| I have a motorola alternator with a remote motorola regulator(Model 8RH2011). The factory plug was cut off the regulator, so I need to know where the wires are to be placed on the three terminals. My colors are: Orange, brown, blue, and white.(the white may be yellow). |
marine6282 Samba Member
Joined: April 06, 2008 Posts: 49 Location: Al Asad, Iaq
Posted: Mon May 05, 2008 11:13 am Post subject: |
my alternator is internally regulated and has a brown wire on the screw to the left of the regulator what does this do??????? _________________ 71 super beetle w/ 1776 dp |
thing1 Samba Member
Posted: Mon May 05, 2008 11:35 am Post subject: |
| The brown wire should be the ground. I also have a VW with an internally regualted alternator. I can check tonight to be certain, but brown is always a ground on VW. |
mccracki Samba Member
Posted: Tue Oct 07, 2008 6:55 pm Post subject: |
Is it possible to convert an externally regulated alternator to an internal? I'm putting a 1600 SuperBeetle engine into a 66 and would like to keep the 66 harness while converting to the 12V system.
Thanks.
Cam |
JoelH Samba Member
Joined: October 16, 2003 Posts: 974 Location: North Dakota
Posted: Sun Jan 30, 2011 7:24 pm Post subject: |
I know this is an old thread, but you gotta credit me for searchin' out the topic before just posting!
anyways,
So, I have a '74 super I'm working on for a customer. I've put a new alternator on it (motorola). The dash light still won't go out. The reason I installed the new alternator is because the top white section of the alternator that is held on by 2 screws was loose and was causing arcing.
I found the voltage regulator under the back seat. It is a motorola 8RH2011. Is there a possibility that, with the arcing and what not that was going on, it might have shorted something out inside the voltage regulator or something? I guess I don't know what else to check and I'm at my wits end with this thing......
please help! _________________ RED RIVER VW CLUB---www.redrivervwclub.com
WIDEFIVE.NET
'60 DD SWR Panel
http://www.thesamba.com/vw/forum/viewtopic.php?p=2522353#2522353
'62 Gulf Blue Ragtop Bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=420720&highlight=
'60 Black RHD Beetle http://www.thesamba.com/vw/forum/viewtopic.php?p=6478591#6478591 |
