johnny d Samba Member
Joined: March 22, 2004 Posts: 2204 Location: where it all came from. ;)
Posted: Sat Nov 21, 2009 2:52 pm Post subject: |
dennis fixed the left door today..
done..
in the meantime i was buiy make the floor fit
among others, i made some space for the rised steeringbox..
_________________ GermanRestoKommando
Der Barndoor Führers - Slamm Society
VWKernzentrale since 2007 |
Posted: Sat Nov 21, 2009 3:42 pm Post subject: |
just got some pics from tom (wheelerdealer) he is building me a fine cruiser 2110ccm engine
first step..analyse the engine
low54 Samba Member
Joined: March 19, 2004 Posts: 424 Location: cotswolds-england
Posted: Sun Nov 22, 2009 3:23 am Post subject: |
This is going to be so cool when its finished looks like the welding is getting there
Ben _________________ 65 original paint so42 dormobile
52 original paint 52 split beetle |
streetwagens Samba Member
Posted: Sun Nov 22, 2009 4:13 am Post subject: |
Hey Jonny, Progress looks excellent...and fast!! I wonder how many times you guys will knock that mirror arm with your head before you pull it off again! _________________ To catch a fish, you must first think like a fish.... |
Jorge R Samba Member
Joined: August 15, 2004 Posts: 146 Location: Portugal-Europe
Posted: Thu Nov 26, 2009 12:30 pm Post subject: |
Although I don´t appreciate much the tunning thing you´re
planning to do to the Miesen, I think you´re doing a nice job with
the body.
Here you have a photo where you can see the original chromed
front bumper.
Photo taken around 1996 just before I bought the bus.
Scotty Samba Member
Joined: July 02, 2003 Posts: 1525 Location: Northampton - Uk
Posted: Thu Nov 26, 2009 2:21 pm Post subject: |
That doesn't look chrome to me _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Scotty Samba Member
Posted: Fri Nov 27, 2009 6:25 am Post subject: |
The raised part of the bumper (especially under the door) looks to be painted white to me _________________
EverettB wrote: |
Posted: Fri Nov 27, 2009 3:06 pm Post subject: |
here´s what happens today..
we finished the front..
dennis repaired both front doors also today
so we started to make the floor fit!
the next week this will be done..
here´s just a pic for me.. it looks almost like a bus now!
Posted: Fri Nov 27, 2009 3:16 pm Post subject: |
Scotty wrote: |
The raised part of the bumper (especially under the door) looks to be painted white to me |
The photo may not be sharp enough but I can assure you
that the bumper was chromed (saw it with my own eyes).
The iron was almost gone it was mostly chrome that was
left on the bumper. I removed it with my hands not
needing a srew drive. |
crede999 Samba Member
Posted: Sat Nov 28, 2009 2:00 pm Post subject: |
hi ive been following this thread and think the work your doing is awesome , anyhow i was muchin abot on the net and think i may have found a pic of your van its on the right half way down if not hey its an interesting site
http://www.vwgarden.co.uk/oldphotosbus.html
regards
chris |
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 604 Location: Bowen Island, BC Canada
Posted: Sat Nov 28, 2009 5:34 pm Post subject: |
Look forward to seeing this early bus back on the road. Great work so far!!
Trevor _________________ 1968 porsche |
Posted: Sun Nov 29, 2009 5:30 pm Post subject: |
Something familiar on the background.
PS Check the dashboard in the grey BD |
low54 Samba Member
Posted: Mon Nov 30, 2009 12:29 am Post subject: |
Jorge R wrote: |
I think i have used a few parts from the green and white one on my 54
Posted: Sat Dec 05, 2009 1:57 pm Post subject: |
dennis and i are installing the gearbox at the moment.
freshly redone, thanks tom!
we had some trubble with the mounting plate for the gearbox..
but dennis did some welding to it (not finished )
now the gearbox fits, but it looks like it is more backwards then before..
is that normal??
Rick Samba Member
Joined: December 17, 2003 Posts: 1539 Location: Soquel, California
Posted: Sat Dec 05, 2009 9:17 pm Post subject: |
mine looked like that before I took it all out. I don't think it can be fixed without moving the mounts forward. Everything worked fine, but there were some big gaps where the tin met the engine bay sheet metal. |
mightymouse Samba Member
Posted: Sun Dec 06, 2009 12:47 am Post subject: |
Put the correct trans and mounts in, problem solved _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
Scotty Samba Member
Posted: Sun Dec 06, 2009 9:00 am Post subject: |
Do you have the shift rod in place yet? Does the hockey stick line up with the shift rod ok? I ask because your adapter bracket looks to have different bolt spacing from mine:
Also, how thick is your adapter bracket? It looks like it might be a bit thick. Mine in place:
Do the rear gearbox mounts look like they've 'pulled' when you did the 2 large bolts up in the frame horns? _________________
EverettB wrote: |
Posted: Sun Dec 06, 2009 1:08 pm Post subject: |
Scotty wrote: |
yes, it all matches correct now..
Scotty wrote: |
hmm.. don´t know but i guess it must be the same as yours...
Scotty wrote: |
Do the rear gearbox mounts look like they've 'pulled' when you did the 2 large bolts up in the frame horns? |
yes, we had a little gap between the horns and the mounts about 1cm i guess but as we put the bolts in, the gap was closed.
scotty, does your gearbox sit the same like mine in the rearend? _________________ GermanRestoKommando
RockStock Samba Member
Joined: November 26, 2004 Posts: 3921 Location: England
Posted: Sun Dec 06, 2009 1:49 pm Post subject: |
From a late model
Stock gearbox
_________________ -StockRocks- |
