will type 1 thermostat work on type 4
Goto page 1, 2  Next
bajorek
bajorek is offline
PostPosted: Wed Jun 25, 2003 6:38 pm    Post subject: will type 1 thermostat work on type 4 Reply with quote
I've read you can use a type 1 thermostat in a type 4 engine. How do you modify it? Do you have to modify it?
What does a good thermostat cable look like? Could I use a bicycle brake cable with the ball on the end?
westy78
westy78 is offline
PostPosted: Wed Jun 25, 2003 7:21 pm    Post subject: will type 1 thermostat work on type 4 Reply with quote
Yep you can use a type1 t-stat on the type4. If you go here to aircooled.net http://tinyurl.com/fagm they explain how to modify it. Its nothing major, just unscrewing a couple of parts. MAKE SURE you get the 80-85 degree model and NOT the 65-70 degree one. You can find the cable at most online sites. Here is one from BusDepot http://tinyurl.com/fah9 . They also still have some type4 t-stats in stock but they are about twice as much as the type1.
westy78
westy78 is offline
PostPosted: Wed Jun 25, 2003 7:31 pm    Post subject: will type 1 thermostat work on type 4 Reply with quote
Wow Im not having good luck today with links. Try these
http://www.aircooled.net./new-bin/viewproductdetail.php?keyword2=ESM0002&cartid=0625200356292014
http://busdepot.webappcabaret.net/catalog.jsp?model=57&category=11&group=15
bajorek
bajorek is offline
PostPosted: Thu Jun 26, 2003 2:51 pm    Post subject: will type 1 thermostat work on type 4 Reply with quote
Ok, most everyone seems to be out of them and they are on back order. Go Westy has them for the type 4 for $51.25 (type 1s are listed $19-24). The guy also said he'd go with the original part over the type 1.
My question is, is there a big difference AND does anyone have one they want to get rid of?
[email protected]
aerculd@hotmail.com is offline
PostPosted: Fri Jun 27, 2003 4:41 am    Post subject: will type 1 thermostat work on type 4 Reply with quote
Don't buy a used t-stat. The cost alone is reason enough to wait until aircooled .net gets restocked, go w/ a type1 t-stat and modify the cable. Barry
benw82
benw82 is offline
PostPosted: Sun Dec 05, 2010 1:50 pm    Post subject: Reply with quote
that link isn't working on how to modify the type 1 thermostat. here is the link for the modification:
http://www.germansupply.com/xcart/customer/home.ph..._in_t4.tpl
there are 3 pages so you have to keep clicking next to see the complete mod.
anyone now the size of the 2 nuts that hold on the thermostat bracket to the studs on the engine?
76' Westy
hazetguy
hazetguy is offline
PostPosted: Sun Dec 05, 2010 3:30 pm    Post subject: Reply with quote
do you think that might be because this thread is 7.5 years old? Rolling Eyes
6x1.0
benw82
benw82 is offline
PostPosted: Sun Dec 05, 2010 7:00 pm    Post subject: Reply with quote
6x1.0
thanks for the thread size. i was trying to use the search instead of starting a new thread. since i never could find what i was looking for i searched using google and then added the link here so the next person trying to modify a thermostat would know how.
76' Westy
SGKent
SGKent is offline
PostPosted: Sun Dec 05, 2010 8:20 pm    Post subject: Reply with quote
Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote
"When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. "
benw82
benw82 is offline
PostPosted: Mon Dec 06, 2010 10:18 am    Post subject: Reply with quote
what kind of rubber seal goes on the tin where the thermostat wire comes through? mine is missing. anyone make a new one out of a hose or ?
76' Westy
SGKent
SGKent is offline
PostPosted: Mon Dec 06, 2010 10:26 am    Post subject: Reply with quote
it is a flat piece of rubber about the size of dime.
You can buy one here. There are posts on it so I am surprised it didn't come up in a search. Did you do one?
http://www.germansupply.com/home/customer/product.php?productid=17676&cat=297&page=2
rustbus
rustbus is offline
PostPosted: Mon Dec 06, 2010 1:21 pm    Post subject: Reply with quote
You sure can use a standard bicycle brake,/shift cable with the nub on the end, works good, thicker than stock, longer than stock (and I kept it extra long enough so i could hold on to it)
cheap! free for me, I was lucky and a friend was working at the bike shop that day
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
benw82
benw82 is offline
PostPosted: Mon Dec 06, 2010 10:50 pm    Post subject: Reply with quote
well i finally got my thermostat all hooked up. its lower 20's in nashville tonight so i took i for a test run. it seemed to fully open in about 15 minutes of normal city driving. that seemed a little quick to me considering how cold it was. i have the 65-70 degree thermostat because i didn't realize there where different temperature thermostats when i ordered mine from bus depot. can u even buy the 80-85 degree thermostat somewhere?
76' Westy
Busdepot
Busdepot is offline
PostPosted: Tue Dec 07, 2010 6:41 am    Post subject: Reply with quote
Here is the current link for the thermostat:
http://busdepot.com/details.jsp?partnumber=111119159A
This is genuine Volkswagen/Germany. It is discontinued but we still have inventory. Word has it that the tooling was destroyed in a fire, so future availability does not look good.
- Ron Salmon
The Bus Depot
www.busdepot.com
benw82
benw82 is offline
PostPosted: Tue Dec 07, 2010 11:42 am    Post subject: Reply with quote
yep thats the one i'm currently using. its a 65-70 degree thermostat. i'm wondering if you can buy the 021-119-159A Type 4 72.5-79 (85-90C) or the 043-119-159 Type 1 FI 75-up (80-85C)
ratwell's page is awesome for thermostat info: http://www.ratwell.com/technical/Thermostats.html
76' Westy
Busdepot
Busdepot is offline
PostPosted: Tue Dec 07, 2010 11:51 am    Post subject: Reply with quote
No, they're all gone. The 111 is all that's left.
- Ron Salmon
The Bus Depot
www.busdepot.com
airkooledchris
airkooledchris is offline
PostPosted: Tue Dec 07, 2010 12:06 pm    Post subject: Reply with quote
buy a rebuilt one:
http://www.thesamba.com/vw/classifieds/detail.php?id=1036746
Join the IAC Facebook group here!
nathansnathan
nathansnathan is offline
PostPosted: Tue Dec 07, 2010 2:57 pm    Post subject: Reply with quote
I got a type 1 thermostat off thesamba classifieds. It was unfortunately the pre-75 65-70 degree one, but better than nothing.
I couldn't figure out if the cylindrical threaded brass piece was designed to come off. I gripped it in the vice but it slipped with the pressure I was comfortable putting on it to hold, and so I figured it wasn't coming off.
I was able to make my own step stud by sawing off the head of a long tin screw and running a die over it, 1 end is now the 6mm x 1.0 thread, the other is a 4mm x .70 going into the thermostat. It's a little long but it clears the part where the block sticks out when it's hot so all good.
Double checking the germansupply how to, I see that the cylindrical part does actually come off. Oh well. Smile
504
504 is offline
PostPosted: Tue Dec 07, 2010 4:04 pm    Post subject: Reply with quote
what's the deal with these:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-043-119-159
busdaddy
busdaddy is offline
PostPosted: Tue Dec 07, 2010 4:41 pm    Post subject: Reply with quote
A waste of money, they fail in the closed position, usually in a couple of years or less.
Wanted, 68-73 westy OG plaid curtains, singles OK.
Goto page 1, 2  Next
