steven wood Samba Member
Joined: March 14, 2004 Posts: 1647 Location: Virginia, NOT West Virginia!
Posted: Wed Apr 02, 2008 1:13 pm Post subject: Exhaust for a lowered bus |
I just bought this bus yesterday and I want to replace the exhaust on it. I really dislike whats on it right now. I don't have the bus yet but want to get started on getting some stuff together. I would like to find something that would bolt up to the 3 bolt flange for right now and maybe later go to a side winder exhaust. I've gone through the forum and can't find a easy solution. I really like the phat boy stainess steel exhaust but I'm worried about it being to low and hitting the bumper or bumper brackets. I'm not sure what size header it has. It only has a 1600 in it. Any suggestions?
nuckled Samba Member
Posted: Wed Apr 02, 2008 1:19 pm Post subject: |
I am familiar with that bus. I cant remember if the extension to the exhaust was made on the header side or muffler side of the flange. I have found with my bus that is at the same height that I have the most clearance from a stock bus exhaust. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Wed Apr 02, 2008 1:23 pm Post subject: |
I thought the exhaust had been lenghtened. I never seen an exhaust like that sit so far out. At first I thought it had a merged exhaust and that was why it stuck so far out. I might just have to wait for it to get here before doing something. |
Posted: Wed Apr 02, 2008 1:30 pm Post subject: |
With the motor that is in it I would suggest the stock exhaust. Did they fix the tranny or are you going to do that? |
Posted: Wed Apr 02, 2008 1:34 pm Post subject: |
cruze wrote: |
I'm going to order a Rancho transaxle tomorrow. I'll have to see what a stock exhaust looks like, I'm not a bus guy. |
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Wed Apr 02, 2008 1:37 pm Post subject: |
YOU ARE NOW? NICE BUS. _________________ once you realize im not impressed we will get along just fine |
Stock
Posted: Wed Apr 02, 2008 1:41 pm Post subject: |
420GOAT wrote: |
YOU ARE NOW? NICE BUS. |
Thanks, I've been into beetles for 20 years and now finally making the switch over. |
sled Samba Member
Posted: Wed Apr 02, 2008 3:11 pm Post subject: |
real men make the switch to buses
run stock exhaust...it looks coolest, sounds coolest, and give the best clearance. _________________ drive your split. |
Michael11 Samba Member
Joined: April 13, 2001 Posts: 265 Location: Ontario, Canada
Posted: Wed Apr 02, 2008 3:57 pm Post subject: |
Here is the set-up on the 55 I just bought:
Posted: Wed Apr 02, 2008 4:26 pm Post subject: |
Michael11 wrote: |
That is exactly what I want but not sure if it will work. Can you post some pics of the side view so we can see if mine is lower? I don't mind dragging a little but I don't want to be ripping the exhaust of the bus. |
Posted: Wed Apr 02, 2008 4:41 pm Post subject: |
steven wood wrote: |
Michael11 wrote: |
Actually my bus was raised back up to stock height. I believe this was the exhaust on it the whole time....but can't say for sure.
At some point this 1835 will come out and a 36hp will sit in its place
As far as stock exhaust goes.. The stock exhaust for your bus is a 25/36hp single tip muffler. Same as an early oval. So the abouve picture of the stock exhaust wouldn't be correct, but may fit. I'm not sure.. |
KombiMonster Samba Member
Joined: April 17, 2001 Posts: 2751 Location: Central Cal.
Michael11 wrote: |
That's a nice set-up but it will drag big time!....Your better off with a stock muffler on that 1600....(their about $40 for the muffler and about $20 for the pipe in the classifieds).....kewl bus!... _________________ FOOK CANCER
*WANTED* |
Posted: Wed Apr 02, 2008 4:50 pm Post subject: |
I might have to go back stock, I just wanted something a little different than stock. I was looking at this Empi exhaust on Ebay,
Yustrn JHC Controla
Joined: August 01, 2000 Posts: 5478 Location: Ovaland, CA
Posted: Wed Apr 02, 2008 4:55 pm Post subject: |
I have a merged tuck away that shit still drags, Sidewinder is the way to go if your gonna step up your game, if it's just a 1600 and your keeping it that low go stock. _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
Posted: Wed Apr 02, 2008 5:02 pm Post subject: |
I plan on taking off the 17" wheels and going with some Fuchs so I'm not sure how the bus will sit. The engine is only a 1600 with dual carbs and a few more hp things done to it, if I remember correctly. |
lowsplitjim Samba Member
Joined: October 27, 2003 Posts: 40 Location: Right Front Seat
Posted: Wed Apr 02, 2008 5:12 pm Post subject: |
IMO: This is the best exhaust for a lowered bus with a 1600.
With a big motor, How I built my last one. Used a YZF R1 stock exhaust can. It was so quiet, Which is nice while driving a big motor bus a long distance.
This one I built for a friend used a Stainless Yoshimura street bike can.
You could see straight through the thing, It was quite a bit louder than the last one.
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Wed Apr 02, 2008 5:52 pm Post subject: |
I also designed a "wrap around" one like those over 15 years ago. Not because of "lowering" but I just wanted it like that. The first one used a low profile muffler and just went around. Eventually I added a monza twin tip which gave it a pretty kool tune. This latest one uses a "cherry bomb" glass pack and a 22" tail pipe I stumbled into at VeeParts.
I still have it and may be using it soon on the stroker! _________________ Some people are so busy being clever they don't have time enough to be wise. |
NAES Samba Member
Joined: September 10, 2003 Posts: 2121 Location: AREA-52 Southern Killafornia
Posted: Wed Apr 02, 2008 6:39 pm Post subject: |
Fabbed up an exhaust. Not to difficult to do ifyou have a welder. I cut up a collector header and got a few pieces of straight and bent tubing from a muffler shop. Can't hardly see it at all.
_________________ Barndoor Mafia
Box On Wheels
SBS #00 |
