mactraveler Samba Member
Posted: Tue Dec 02, 2008 10:15 am Post subject: |
My exhaust had a small hole in it
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Tue Dec 02, 2008 10:24 am Post subject: |
Let me guess: EMPI
Here's my holey muffler:
_________________ Some people are so busy being clever they don't have time enough to be wise. |
kingodirtp3 Samba Member
Joined: December 07, 2007 Posts: 1062 Location: Monterey CA
Posted: Tue Dec 02, 2008 10:30 am Post subject: |
i bought the bugpack header with single quietpac. will i have to modify the quietpac to clear the bumper and apron? the bus will be low also, but not scrapping low. |
Posted: Tue Dec 02, 2008 12:20 pm Post subject: |
pyrOman wrote: |
Let me guess: EMPI
Yup its EMPI junk! |
der58SC Samba Member
Joined: September 15, 2006 Posts: 1359 Location: Oceanside, CA
Posted: Tue Dec 02, 2008 1:45 pm Post subject: |
kingodirtp3 wrote: |
I had to bend mine down since I did not want to cut my apron. Depending on how low you are depends on if it will scrape or not. I am pretty low and only have about an inch or two clearance. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Strictly Vintage 2s |
Posted: Tue Dec 02, 2008 2:02 pm Post subject: |
my apron has a rust hole anyway so i'm ok bending it a little. |
Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Tue Dec 02, 2008 4:10 pm Post subject: |
Haha... Ive gone through three quietpacks in my bus now. I always bust the bottoms out in no time.
I built a new stainless Borla muffler at work, but I just did it all guesswork, AT work without any measurements..... It fits on my bus fairly nice, but the small turnout I put from the muffler can is lower than my quietpack was.
Needless to say, I plan to do some measuring this time and make another.... _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
Posted: Tue Dec 02, 2008 4:12 pm Post subject: |
Andrew wrote: |
WhitewallsJohnson wrote: |
Go with the stock bus muffler and dampner tube. |
If you've got a stock engine, then I'll agree with this, hands down. You can't really put a stock exhaust on a performance engine, though. |
X2. Stock is DEF. the way to go for clearance in a bus OR beetle, but like Andrew said, big motors are another issue. _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
Posted: Tue Dec 02, 2008 4:34 pm Post subject: |
i'm about to add dual ICTs, 1.4 ratio rockers, header with single quietpac exhaust, SVDA, petronix to my stock 1600 singleport. it already has external oil cooler and fiflter along with stock doghouse setup. i'll take out the stock screen since the filter works much better. i'll check today to make sure it has all the tin and when i take off the fanshroud i'll check for the stock thermostat setup as well. there's no way i'll ever put a stock exhaust on. way too restrive. i like being low but never slow. if it scapes then i'll raise it up a little, same for the steering box. |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2830 Location: West Palm Beach, FL
Posted: Mon Jul 05, 2010 11:11 am Post subject: |
Got a hole in my Thunderbird muffler from dragging it while backing out of a driveway. (I lowered the bus some more since my first post)
Chrome damper pipe support did not allow exhaust pipe to fit too well
Tilted too much, and tip sticks too far out past the bumper
I left it off, and bolted these two tabs together. This allowed me to bend and set the exhaust tip where I wanted it. Level, and not sticking too far out.
What matters most!!!!
I was surprised that is sounded the same as the single quietpack when driving inside the bus. _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
phatbus Samba Member
Posted: Mon Jul 05, 2010 2:19 pm Post subject: |
Shweeeeeeeeeet. |
Posted: Mon Jul 05, 2010 6:07 pm Post subject: |
i got this from autozone, cherry bomb chamber muffler.
http://www.autozone.com/autozone/parts/Cherrybomb-...9292_1719_
$20 is a great price, about the same size as a hideaway muffler. i'll get it
mounted like a hideaway but with enough room to adjust my valves and
exiting in front of the passenger rear wheel. once its done i'll post pics. it
says its aluminized, but i still sprayed it with 2000deg exhaust paint. |
Posted: Sun Aug 08, 2010 8:46 pm Post subject: |
heres some pics of my new muffler setup. the engine runs soo much
better now, feels much more responsive. seems like i gained 10hp!
the muffler is from autozone, cherrybomb turbo for $20.
the local muffler shop installed it and replaced my fuel line from the tank
to the engine for $150 total.
the pipes to and from the muffler are 1 3/4in, muffler has 2in in/outlets.
its no louder than the single quietpac, until you step on the gas, but then it only gets slightly louder with a nice rumble.
i still have to take it off and paint it with some 2000deg exhaust paint.
the muffler guy made it so i can take it off easily to adjust my valves. he
made hangers for it too.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Sun Aug 08, 2010 10:53 pm Post subject: |
^^^ Two things come to mind when I look at your setup. If you use your heat, you have a great potential of sucking exhaust gases into your bus by having the tip in front of the wheel like that. They will be drawn into the engine louvers and into the heating system. Not good.
The other thing is that having the muffler alongside the engine like that makes the passenger compartment of the bus more noisy. I have used a similar hide away exhaust system on several buses, and after running it I switched to either a single quite pack or a stock exhaust and the interior of the bus was much quieter. It's has to do with the sound resonating from the muffler can right under the rear interior compartment. I suppose with good sound deadening it would diminish, but I had a near identical setup in my 65 Riviera packed with camping gear and switching the muffler to a single quiet pack made all the difference in interior noise.
I recently sold my custom hide away exhaust for this reason. Plus I got tired of having to pull it to adjust valves. _________________ nothing |
Posted: Sun Aug 08, 2010 10:57 pm Post subject: |
i have neither of those problems, the guy that installed it also made it so i
could remove just the muffler instaed of the whole setup to adjust the valves.
i already think i'm getting exhaust into the heating system anyway, that was before this muffler though. i'm thinkign of removing the heater boxes
or just let them dump out to the atmosphere.
it runs so much better now though, sounds great too. |
Posted: Mon Aug 09, 2010 9:47 am Post subject: |
If you don't use the heat, then just unhook the tubes that connect the heater boxes to the body. If you need heat occasionally, you may want to do something different with the exhaust routing, and whatever was leaking exhaust into your heat system. You don't want to breathe that stuff for any length of time.
Removing the muffler to adjust valves was not all that difficult for me either, just a minor annoyance. _________________ nothing |
eric m Samba Member
Posted: Fri Apr 17, 2015 7:29 pm Post subject: |
I used this thread as inspiration for my setup .Heres my lowmaster 1 chamber. I ordered 2 aluminized mandrel bends from summit racing , a couple of reducers and came up with this. It tucks up nice and tight and cant be seen from behind.
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Thu Apr 23, 2015 8:08 pm Post subject: |
eric m wrote: |
Nice. I would like to see the parts you ordered from Summit. How much did it cost in parts? _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
Posted: Wed May 06, 2015 6:53 am Post subject: Interesting article |
I my search for a quiet exhaust that flows well, I stumbled upon this article. It was a good education for me, so I thought I would share:
http://www.mikekemper.com/elantra/diyexhaust/ _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
eric m Samba Member
Posted: Wed May 06, 2015 7:38 pm Post subject: |
KevinAlbrecht wrote: |
eric m wrote: |
Nice. I would like to see the parts you ordered from Summit. How much did it cost in parts? |
i used summit part# sum-621003 1 -3/4" j- bend and sum 622001 2' u bend. i used every bit of the pipe and didnt have any extra . the reductions came from advance auto parts. im not sure about there price but the summit stuff was $30 plus shipping. |
