Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Fri Sep 23, 2011 6:34 am Post subject: |
Well that shows just about everything from how it is nutted to the lower head stud, to where each end goes through the tin pieces. Just slide under your bus and take a gander at the same area. _________________ In Stereo, Where Available! |
Split Decision Samba Member
Joined: August 25, 2003 Posts: 675 Location: Katy, Texas
Posted: Fri Sep 23, 2011 7:52 am Post subject: |
I didn't have mine hooked up when I bought the bus and I must be missing parts. I have the correct oil bath air cleaner and the front tin with the pass-through hole, but I don't have the tube that the hose connects to. I wanted to put it back correctly when I put the new engine in and was wondering what/where the missing part(s) go. I also noticed that the small deflector tin has a hole in it where mine does not. _________________ In 1966 Volkswagen pinched my loaf.
67 Deluxe
On year seven of the "I'll get it done next week" engine rebuild.
74superTN wrote: |
Just seems these days that unless you are dragging your engine on the ground and have crazy negative camber, people seem like you're doing it all wrong. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri Sep 23, 2011 8:06 am Post subject: |
Split Decision wrote: |
I didn't have mine hooked up when I bought the bus and I must be missing parts. I have the correct oil bath air cleaner and the front tin with the pass-through hole, but I don't have the tube that the hose connects to. I wanted to put it back correctly when I put the new engine in and was wondering what/where the missing part(s) go. I also noticed that the small deflector tin has a hole in it where mine does not. |
If yours is a '67 then what you have is correct: front tin with preheat hole, rear tin with no hole, lower cylinder tins with no holes. What you're missing is the heater box with the little pipe sticking up on the passenger side. Do you have a picture of your front tin with the hole? Have you looked up at the top of your heater box for the pipe? |
Posted: Fri Sep 23, 2011 8:34 am Post subject: |
I don't remember my heater box having the little pipe, but I'll double-check once I get back home (out of town). _________________ In 1966 Volkswagen pinched my loaf.
67 Deluxe
74superTN wrote: |
Posted: Wed Oct 05, 2011 7:47 am Post subject: |
I think I get it now. Since these things aren't all that easy to come by I may try to fab one up and drill the plate myself. _________________ In 1966 Volkswagen pinched my loaf.
67 Deluxe
74superTN wrote: |
locke999 Samba Member
Posted: Wed Oct 05, 2011 12:50 pm Post subject: air cleaner |
is that cleaner same size as thing?
if it is i will use on 63 engine
al |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
avery's air cooled Samba Member
Joined: December 17, 2007 Posts: 29 Location: Kelso, WA
Posted: Tue Nov 22, 2011 12:40 pm Post subject: |
Any idea if this oil bath pipe with the extra little tube on it is stock or someone's modification? This is the second pipe I've found just like it. |
Posted: Wed Nov 23, 2011 8:15 am Post subject: |
Thanks. I figured they were hacks as well, but happened to find two that looked the same and wanted to check. |
vwed Samba Member
Joined: August 07, 2004 Posts: 127 Location: United Kingdom
Posted: Tue Dec 18, 2012 5:48 am Post subject: |
This recently sold on German eBay for 156 euros.
NOS.
Part number given by the seller: 211 129 612 E.
BarryL Samba Member
Posted: Tue Dec 18, 2012 7:18 pm Post subject: |
I've wanted one of those ^^^^^ since I was knee-high to a grasshopper. There it is in all its glory. Sheesh, a thing of beauty. |
Daddybus Samba Member
Posted: Tue Dec 18, 2012 8:43 pm Post subject: |
BarryL wrote: |
156 Euros/$206 dollars is a good deal if it came with the bracket.
I have a 211 129 611B with bracket. Well used. Not NOS |
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1788 Location: Winter Park, FL
Posted: Wed Feb 06, 2013 5:24 pm Post subject: |
What's the deal with the 261 129 613B air cleaner? It looks similar to a bastard air cleaner but with a breather tube. It's also listed as a type 1 part. Did Beetles have suspended air cleaners?
Posted: Thu Feb 07, 2013 7:53 am Post subject: |
The 1968 bulletin lists using the type 2 611 & 612. If the 613 is a later one it would be for later type 1. _________________ In Stereo, Where Available! |
Posted: Thu Feb 07, 2013 8:10 am Post subject: |
Eric&Barb wrote: |
The 1968 bulletin lists using the type 2 611 & 612. If the 613 is a later one it would be for later type 1. |
That bulletin lists 211 part numbers, not 261. |
