Ran When Parked Samba Member
Joined: September 26, 2013 Posts: 781 Location: Birmingham, AL
Posted: Wed Nov 26, 2014 12:31 pm Post subject: Spare Tire / Rim |
I found this rim on a tire in the spare tire storage area in a 59 panel van.
It does not look to be a VW rim. Anyone know if that is correct? Do you know the manufacturer?
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Wed Nov 26, 2014 8:07 pm Post subject: Thanks |
Thank you. I wonder how it ended up as my spare? Crazy how you would know that. I have never heard of a Wartburg. Guess I will put it back in there as a surprise for the next guy....
Thanks again. |
Posted: Fri Nov 28, 2014 1:43 pm Post subject: Re: Thanks |
Sh*tBird wrote: |
Thanks again. |
not so crazy, i am german after all, and after 30 years in the hobby... _________________ regards
Uli
BarryL Samba Member
Joined: November 01, 2004 Posts: 14255 Location: Casa de Oro, California
Posted: Fri Nov 28, 2014 4:43 pm Post subject: |
Those look to have a huge negative offset. Could be just the ticket for curing some rad drop or mod that needed that inwardness. I like where the weights are, too. |
BerylGreen63 Samba Member
Posted: Mon Dec 22, 2014 5:47 pm Post subject: |
Can the wheel experts shed a little light on this rim. It came with my 64, I know its an early 15 inch wheel.
GTV Samba Member
Posted: Mon Dec 22, 2014 6:49 pm Post subject: |
October 56 crows foot wheel. _________________ EMPI Power Rules! |
bustedtype2 Samba Member
Joined: May 07, 2005 Posts: 417 Location: The arm pit of california
Posted: Fri Jan 16, 2015 3:00 am Post subject: Bus wheels 1965 vs 1970 ? Advice |
Is a 1965 14inch bus wheel the same as a 1970 14inch bus wheel? _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20264 Location: Sandpoint, ID
Posted: Fri Jan 16, 2015 9:38 am Post subject: Re: Bus wheels 1965 vs 1970 ? Advice |
bustedtype2 wrote: |
Is a 1965 14inch bus wheel the same as a 1970 14inch bus wheel? |
As far as I know, other than the date, yes they are the same. _________________ nothing |
Voodoo Child Samba Member
Posted: Tue Feb 03, 2015 10:22 am Post subject: Thing wheels on a Split? |
Pretty sure I've got a set of 14" Thing wheels. Any problem with running them on a Split till I get something else? |
Posted: Tue Feb 03, 2015 8:16 pm Post subject: Re: Thing wheels on a Split? |
Voodoo Child wrote: |
no problem at all if they fit _________________ regards
Uli
Posted: Tue Feb 03, 2015 9:15 pm Post subject: |
That's what I mean, is the backspacing close enough to work? I don't have any bus wheels to compare to. Just wondering if anybody has done it. |
Posted: Tue Feb 03, 2015 9:25 pm Post subject: |
Do you have a bus to try them on? _________________ nothing |
GTV Samba Member
Posted: Tue Feb 03, 2015 9:45 pm Post subject: |
Thing wheels have slightly more positive offset. As long as the tires aren't too wide you *shouldn't* have a problem. _________________ EMPI Power Rules! |
Posted: Wed Feb 04, 2015 7:18 am Post subject: |
cdennisg wrote: |
Do you have a bus to try them on? |
Yeah, I just didn't want to go get new tires mounted just to find out my wheels won't work. I've got 2 14" bus wheels now, so if anybody has 2 extras I could just run the bus wheels |
Posted: Wed Feb 04, 2015 7:20 am Post subject: |
GTV wrote: |
Thing wheels have slightly more positive offset. As long as the tires aren't too wide you *shouldn't* have a problem. |
I can compare the 2 now, I'll post what I find out. I'm probably gonna run a stock size tire for now so I'd assume it would be fine. |
Posted: Wed Feb 04, 2015 8:47 am Post subject: |
cdennisg wrote: |
If you bolt up a bare wheel you will be able to make sure of clearance to ball joints and such. Then measuring the difference between the wheel offsets should tell you whether you will have tire clearance. _________________ nothing |
Posted: Wed Feb 04, 2015 8:50 am Post subject: |
cdennisg wrote: |
cdennisg wrote: |
If you bolt up a bare wheel you will be able to make sure of clearance to ball joints and such. Then measuring the difference between the wheel offsets should tell you whether you will have tire clearance. |
Gotcha, I'll do that. Ready to get this joker on the road. |
Posted: Wed Feb 04, 2015 10:07 am Post subject: |
cdennisg wrote: |
cdennisg wrote: |
Cool. The more the merrier. Post some pics of it somewhere once it's rollin'. _________________ nothing |
Posted: Wed Feb 04, 2015 10:15 am Post subject: |
cdennisg wrote: |
Cool. The more the merrier. Post some pics of it somewhere once it's rollin'. |
Sure will. I think all it needs now are wheels, tires & a wiring harness. |
