clearsky Samba Member
Posted: Sat Apr 19, 2008 2:06 pm Post subject: wandering steering at highway speeds. |
| My 73 has a nasty tendency to wander at highway speeds. The allignment is ok as is the steering box and all the ball joints are tight . The only thing that I think it could be is the steering dampener. I took it off and it seems ok in that it takes effort to push it in and pull it out. Is this a valid test or should I just replace it? As far as I know there is only a stock replacement for it. Is there another dampener that would give me more dampening? Any advice is appreciated, thanks. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 8122 Location: Black Forest, CO
Posted: Sat Apr 19, 2008 2:14 pm Post subject: |
What tire pressures are you using? Is the car lowered?
Max _________________ The only thing more expensive than cheap parts is mixing cheap parts with stupidity. |
Posted: Sat Apr 19, 2008 7:29 pm Post subject: |
Hi Max, the tire pressure is 32 psi and the car has not been lowered.
Bill.. |
Fibersport Samba Member
Joined: September 23, 2005 Posts: 1157 Location: Lansing, IL
Posted: Sat Apr 19, 2008 7:33 pm Post subject: |
Lower your tire pressure, stock were around 17 psi. Higher pressures make steering easier but it rides harsher and tends to make it wiggly at higher speeds. I run about 22 psi in the front and drive on the highway most of the time, I used to keep mine at 30 for mileage but dropped it to 22, mileage hasn't suffered and it rides better. _________________ 1973 Standard Beetle |
Posted: Sat Apr 19, 2008 8:26 pm Post subject: |
Yeah, 32 is much to high for the front of a bug. Try 20.
blarneyman Samba Member
Joined: February 06, 2005 Posts: 1659 Location: Everson/Bellingham, WA
Posted: Sat Apr 19, 2008 11:00 pm Post subject: |
I keep my front at 18 and the rear at 24. Rides beautiful even with 3" of drop in the front. _________________ 69 Beetle
70 Ghia(resto)
66 Kombi/Riviera(resto) |
Posted: Sun Apr 20, 2008 6:13 am Post subject: |
| OK, thanks to all for their input. This forum really works! I never would have thought of too much air pressure. Thanks again. |
Randy in Maine Samba Member
Joined: August 03, 2003 Posts: 29761 Location: The Beach
Posted: Sun Apr 20, 2008 6:19 am Post subject: |
| A cheap fix is always the best fix. |
Beaboy Samba Member
Joined: April 16, 2007 Posts: 307 Location: Jacksonville, Florida
Posted: Sun Apr 20, 2008 7:36 am Post subject: |
Sorry to break in, but why such low tire pressures on Bug tires? Wouldn't you always want to inflate to the tire manufacturer's specs? With most newer tires rated around 35 or so, seems that 22-25 psi would be asking for trouble. _________________ '69 Standard Beetle |
Posted: Sun Apr 20, 2008 7:48 am Post subject: |
Reda this article, it explains it pretty good.
http://www.geocities.com/eaallred/tirepressure.html
It also makes sense, I've always ran higher than stock pressures and have noticed the wear pattern on the tires show overinflation. _________________ 1973 Standard Beetle |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8888 Location: sound it out.
Posted: Sun Apr 20, 2008 10:00 am Post subject: |
| Beaboy wrote: | | Sorry to break in, but why such low tire pressures on Bug tires? Wouldn't you always want to inflate to the tire manufacturer's specs? With most newer tires rated around 35 or so, seems that 22-25 psi would be asking for trouble. |
absolutely.... but you are thinking wrong manufacturer... go with the manufacturer of the car you are running the tires on, not the MAXIMUM inflation pressures listed on the tire... Maximun psi is also for maximum load which is also listed on the tire sidewall.... that maximum load(for one tire) can be nearly what our cars weigh. _________________
| EverettB wrote: | | I prefer to refer to everyone as my "bitch". |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25689 Location: Central Iowa
Posted: Sun Apr 20, 2008 10:22 am Post subject: |
The pressure marked on the side of tires, is the MAXIMUM inflation pressure.
You inflate tires to the recommendations of the car manufacturer.
An over inflated tire has little contact patch with the road. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Apr 20, 2008 11:16 am Post subject: |
Does no one read previous posts? _________________ 1973 Standard Beetle |
Beaboy Samba Member
Posted: Sun Apr 20, 2008 6:51 pm Post subject: |
Amazing information. Thanks for the education. I'm a convert. _________________ '69 Standard Beetle |
rayzor30 Samba Member
Joined: February 04, 2005 Posts: 177 Location: Western NY
Posted: Sun Apr 20, 2008 7:00 pm Post subject: |
x2
thanks
rayzor30 |
ed stanley Samba Member
Posted: Mon Apr 21, 2008 7:03 am Post subject: |
| Classic symptoms of improper toe in. I know you said you checked alignment - but check again for proper toe in. Should be 1/32" to 1/8" I think - but check your Bentley. If you have "toe out", you will be sawing on the steering wheel all the time. |
fmartin_gila Samba Member
Joined: January 25, 2008 Posts: 379 Location: Globe, Az.
Posted: Tue Apr 22, 2008 6:19 am Post subject: |
A steering box that is adjusted a dab too tight will also cause the vehicle to 'wander'.
Fred |
Posted: Tue Apr 22, 2008 12:22 pm Post subject: |
| Fibersport wrote: | | Does no one read previous posts? |
When we have time. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
texas_vee_dub Samba Member
Posted: Thu Apr 24, 2008 5:13 pm Post subject: |
i am a believer too. I dropped my front to 22 and the rear to 28 and I could tell a world of difference. I am thinking about dropping them to 18/24. I didn't to begin with because I was skeptical. Now I believe. _________________ 69 beetle
My bug cost more than your Civic! Biatch! |
