Scott Novak Samba Member
Joined: October 12, 2004 Posts: 1586 Location: Minneapolis, Minnesota
Posted: Thu Mar 12, 2009 10:49 pm Post subject: |
bowtie56jw wrote: |
nope no crossfire and gap is .35 |
I think you're missing a zero. 0.035" spark plug gaps perhaps?
bowtie56jw wrote: |
60130 High Vibration Epoxy Filled Black turn ratio 85:1 primary resistance 3.0 Ohms secondary resistance22.8k Ohms primary inductance 9.0mH max voltage 60,000 |
I'm not suggesting that it's a bad ignition coil, but I sincerely doubt that you could ever get that ignition coil to deliver 60,000 Volts to a real spark plug in use. It's misleading advertising. It's just more of the advertising hype that everyone does. I haven't seen any of these companies give any useful information about their ignition coils. You basically have to do the testing on your own.
Getting down from the soapbox now.
Scott Novak |
wardvwracer Samba Member
Joined: July 19, 2002 Posts: 489 Location: De Pere, WI
Posted: Fri Mar 13, 2009 5:56 pm Post subject: |
Thanks Scott for your detailed comments and explanation. Good stuff! _________________ David Ward
ACME Berrien Buggy Street/Strip racer build
1963 Single Cab
1969 Beetle Convertible
63 11-Window Kombi Bus
Cornpanzers |
bluebug79 Samba Member
Joined: November 12, 2008 Posts: 63 Location: PHILIPPINES
Posted: Sat Nov 28, 2009 8:35 am Post subject: bosch blue coil with w8ac plugs |
whats the best gap with this setup? blue coil+ngk ignition leads+w8ac.. |
Kelley Samba Member
Joined: April 03, 2003 Posts: 1432 Location: "Die Sonneküste" Crystal Beach, FL
Posted: Sat Nov 28, 2009 9:28 am Post subject: Re: bosch blue coil with w8ac plugs |
bluebug79 wrote: |
Basic stock ignition uses basic stock plug gap specs, .028 . Usually, plugs come pre-gapped, BUT,,, it's always good to check.
Get a service manual for your year model, and let it be your guide. _________________ 74 rusto-custom type 1 Sedan - SOLD
ZRX1100c3, Mean Green - SOLD
Growler wrote: |
I hate people. Are you people? I hate you. |
Just trying to remember classic Samba quotes from the 'Days of Yore' |
