injac3p Samba Member
Joined: June 20, 2007 Posts: 257 Location: boulder, co
Posted: Tue Nov 24, 2009 9:14 pm Post subject: Turbo Gaskets |
I am installing the feed/return oil lines to my turbo and need to know if the paper gaskets should go on dry or should i use a thin layer of silicone gasket sealer?
thanks |
fastinradford Samba Member
Joined: June 08, 2008 Posts: 2895 Location: Athens Ohio
Posted: Tue Nov 24, 2009 9:44 pm Post subject: |
This layer of sealant usually does the trick, but if everything is super clean and straight, you could probably only use the paper. _________________ 95 jetta 5spd, (first waterpumper vw)
the nice 74 Ghia, (of course the fiance drives that one).
My mk1 jetta 1.6d
"It'd still be like my grandads old broom though, original, only 3 new heads and two new handles" -Marv [UK] |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Nov 25, 2009 5:19 am Post subject: |
I don't use a flange type connection on the feed, I use a screw in (I think it's pipe thread) connection. For return you usually have to use the flange, but I've always been paranoid about leaks on the feed so I use a solid metal line there. Carquest made the lines I have right now, but sooner or later I'll get back to Hotrodvw about making a nice set of braided stuff. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
CLKWRK Samba Member
Joined: October 02, 2001 Posts: 566 Location: Toronto
Posted: Wed Nov 25, 2009 10:27 am Post subject: |
Vw uses the flange connections on the 1.8T models and I hardly ever see them leak, you can usually even reuse the old gaskets, there is nothing wrong with this setup. _________________ 95 jetta 5spd, (first waterpumper vw)
My mk1 jetta 1.6d
Posted: Wed Nov 25, 2009 7:42 pm Post subject: |
Didn't say there was, just said I'm paranoid. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Hotrodvw Samba Member
Posted: Sat Nov 28, 2009 9:12 am Post subject: |
miniman82 wrote: |
Carquest made the lines I have right now, but sooner or later I'll get back to Hotrodvw about making a nice set of braided stuff. |
Cheesy!!!!!!!
Still waiting! _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
