6mm vs. 8mm
kafer53
kafer53 is offline
PostPosted: Tue May 06, 2008 5:08 pm    Post subject: 6mm vs. 8mm Reply with quote
Here is a question that I have always been confused about. I get a lot of mixed info on this one:
What is the correct fuel pump and carb set up for my early 53 25hp engine rebuild? I'm really looking for info on the size of the fuel line. I've heard 6mm vs. 8mm although I thought 8 mm ones were for the earlier 25hp engines. My engine is correct for 53 zwitter production dates. I have a solex 28 PIC carb. Would this work for my engine? Any ideas? Thanks in advance
Paul
1953 Zwitter 11C (Chestnut Brown)
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Tue May 06, 2008 5:41 pm    Post subject: Reply with quote
It started with the Zwitter. October 1st, '52. Both the 6mm line and the 28 PCI carb. Not sure about the pump.
CH3NO2.
Der Blitzkrieg Kafers
billmetric
billmetric is offline
PostPosted: Tue May 06, 2008 9:28 pm    Post subject: Reply with quote
28 PCI carb for a zwitter doesnt have the vacuum line port, the fuel pump looks like a flat top 8mm but its 6mm, they are both uncommon, rare? depends on who you ask, only hard to find if you really need one
There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there...
lzamora
lzamora is offline
PostPosted: Thu Feb 03, 2011 7:55 pm    Post subject: Reply with quote
What would be correct for a zwitter? 8mm or 6mm fuel pump? While tearing down the engine on an January 53 zwitter the fuel pump removed was 8mm. I was told 8mm was incorrect and thought of selling the pump and buy a 6mm but want to make sure before i do knowing how hard it is to find them.
1956 Oval Window Rag
1953 Zwitter Rag
ProjectX
Accessory Nut
ProjectX is offline
PostPosted: Thu Feb 03, 2011 8:28 pm    Post subject: Reply with quote
6mm is correct for a Zwitter.... Zwitters had 28PCI carbs with no vacuum lines and only took 6mm fuel line.
Even my nuts are plated.....
195? Project "X"
1958 Euro Ragtop
lzamora
lzamora is offline
PostPosted: Thu Feb 03, 2011 9:08 pm    Post subject: Reply with quote
Thanks 56ovalRhd, I guess now i have an "8mm" fuel pump for sale...........
1953 Zwitter Rag
lzamora
lzamora is offline
PostPosted: Thu Feb 03, 2011 9:57 pm    Post subject: Reply with quote
This is the pump i have, early?
1953 Zwitter Rag
splitjunkie
splitjunkie is offline
PostPosted: Fri Feb 04, 2011 5:34 am    Post subject: Reply with quote
Yes. If it's 8mm it's split, if it 6mm it's zwitter -'53.
Chris
