YouBugMe58 Samba Member
Posted: Fri Apr 20, 2012 7:48 pm Post subject: |
Put my 59 in the storage unit, sniffed a little and said good bye until next fall. _________________ 59 Euro Ragtop Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553
Working on the boring stuff is still better than a good day at work!
Only 3 things matter in life, Those you Love, Those whom Love you and Your final Destination! Enjoy Them.
Trophys are just a reminder of your past and to look at. Enjoy things and use them. |
northernbugs Samba Member
Joined: December 28, 2011 Posts: 6 Location: Grande Prairie, AB, Canada
Posted: Sat Apr 21, 2012 9:08 pm Post subject: |
| Took all the brake drums and associated stuff up to and including the backing plates off my daughters '61. Ran the stuff through the parts washer so I can sandblast soon. Daughters grad is in 5 weeks and I want to surprise her by driving "Betty" her bug out of the garage under its' own power and be able to stop it as well. |
wolfywho Samba Member
Posted: Sun Apr 22, 2012 8:22 am Post subject: |
| YouBugMe58 wrote: | | Put my 59 in the storage unit, sniffed a little and said good bye until next fall. |
Shouldn't it be the other way around? Putting it away in the fall for next spring? Sorry man. I think I just shed a tear myself.  _________________ '66 Beetle Project
http://beingwolfy.wordpress.com/
YouTube Channel
http://www.youtube.com/user/wolfywho |
b4thea4 Samba Member
Joined: March 24, 2011 Posts: 32 Location: Sammamish, WA
Posted: Sun Apr 22, 2012 12:42 pm Post subject: |
I cleaned the heat risers on my 1200. They were really clogged!!! Put it all back together last night. Drove it to work today and it made a huge difference! Little to no hesitation after changing gears, able to maintain speed better on the freeway, too!
Now I just need to adjust my decklid so it doesn't rub. _________________ It's always Quattro season!
'65 Beetle, '13 Audi A3 TDI |
clarson3676 Samba Member
Posted: Sun Apr 22, 2012 3:47 pm Post subject: |
| pretty productive day today. got all the parts painted from the blaster. pulled the front beam and disassembled so i can clean and paint before re-assembly. so close to finally get the front end back together. enjoy the rest of your weekend. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55685 Location: Long Island, New York, USA
Snydr Samba Member
Joined: July 07, 2011 Posts: 384 Location: Gig Harbor, WA
Posted: Sun Apr 22, 2012 9:15 pm Post subject: |
Realized what all the whining was about: put new outer seals on my '63 pop out windows. Check that, one window. I stopped after the first because my fingers are killing me. I'll revist the second one next week.  _________________ - e
'63 Beetle Ragtop - (Build in progress)
'00 Jetta Sedan |
laynlow65 Samba Member
Joined: October 11, 2011 Posts: 1 Location: springfield, mo
Posted: Mon Apr 23, 2012 3:26 pm Post subject: Spitting Oil |
| Helped my buddy take care of the oil that was spitting all over his motor. Pressure relief valve stuck no biggie. Saw a sick 65 at the skate shop http://www.ddpskate.com |
solomon Samba Member
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1081 Location: United States
6Kabrio7 Samba Member
Joined: July 22, 2006 Posts: 2002 Location: California
Posted: Thu Apr 26, 2012 6:59 pm Post subject: |
Installed a tunnel basket from Wolfsburg West.
 _________________ 67 Convertible July 67 Yukon Yellow
67 Sedan May 67 Zenith blue
VVWCA member since 2007 |
Dubbydubdub Samba Member
Posted: Fri Apr 27, 2012 8:27 am Post subject: |
| question: has anyone removed/installed axle tube assembly WITHOUT removing engine/transaxle? |
YOUBUGME2 Samba Member
Joined: March 23, 2005 Posts: 2755 Location: Dothan Alabama
Posted: Fri Apr 27, 2012 10:32 am Post subject: |
| YOUBUGME2 wrote: | | Dubbydubdub wrote: | | question: has anyone removed/installed axle tube assembly WITHOUT removing engine/transaxle? |
I have on a bus, its not fun but not that bad of a job. The worse thing is if you have to remove the axle itself, the snap ring can be a real pain. |
what year bus? Swing axle or cv? My pain is trying to get at the last nut of the hexagonal retainer that holds the axle tube to the transaxle. it's hidden behind the chasis tube and there's barely any wiggle room. Thanks for your reply. |
Posted: Fri Apr 27, 2012 3:05 pm Post subject: |
| YOUBUGME2 wrote: | | 63 bus, it was swing axle. That one nut about drove me batty as well. it might be easier if you unbolted shifter tube and 2 u mounts jack it up some. |
awesome, i was thinking that as well but was unsure as how to tranny mounts to the chasis. i.e. jacking it up with tweak the mounting bolts. good to know i have a couple options to try before inevitably pulling motor/tranny. |
79SuperVert  Samba Member
Joined: May 31, 2002 Posts: 8260 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Fri Apr 27, 2012 7:39 pm Post subject: |
I did once, finding that I could move the transmission up enough for the transmission side covers to come off and clear the frame horns...but the reason was that the rear transmission mounts were shot!  _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
Posted: Fri Apr 27, 2012 7:50 pm Post subject: |
| 79SuperVert wrote: | | Dubbydubdub wrote: | | question: has anyone removed/installed axle tube assembly WITHOUT removing engine/transaxle? |
I did once, finding that I could move the transmission up enough for the transmission side covers to come off and clear the frame horns...but the reason was that the rear transmission mounts were shot!  |
Dang! Mr. lucky with your shot mounts. I'm able to fit a tiny box wrench on that last nut, we'll see if it will crank (was too excited that it fit in there so i gave myself a sandwhich break). |
JimJ Samba Member
Joined: August 03, 2004 Posts: 69 Location: Phoenix, Arizona
Posted: Sat Apr 28, 2012 1:36 pm Post subject: Blast the tins |
I media blasted most of the tins for my new engine. Repaired holes in breast plate tin from PO on current 1200. Helped a friend with his muffler. _________________ Tool junkie
62 Ruby Red type 1385 |
