shano63  Samba Member
Joined: October 06, 2006 Posts: 3088 Location: Poughkeepsie NY
Posted: Sat Apr 28, 2012 2:40 pm Post subject: |
Got the bug out of storage today, and put the bus in..  _________________ 63 T1 Ragtop Gulf Blue, Certified abortion
04 Wrangler Rubicon
66 F250 4X4
Chris
Take it as it comes-- Morrison |
79SuperVert  Samba Member
Joined: May 31, 2002 Posts: 8252 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Sun Apr 29, 2012 1:48 pm Post subject: |
Changed the oil and lubed the front torsion bars and king pins. Jeez, grease is gross stuff. Smells bad, gets on everything, hard to get rid of, but I guess that's what it's supposed to do.  _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
Chris659 Samba Member
Joined: June 14, 2011 Posts: 638 Location: Central Florida
Posted: Sun Apr 29, 2012 2:23 pm Post subject: |
^ I wear vinyl gloves! Makes an easy clean up!
So this weekend I managed to change the steering coupler, install the new steering damper, complete the rewire from the rear fire wall to tail light, wired up new wiper switch ( repro for 61 from airhead parts ), and finished my second "cleanair box."
What I'm calling clean air boxes incorporate a k&n air filter on each side of the engine bay. The PO cut a jagged 4x6 hole on each side I'm assuming to gain easy access to spark plugs.
So since I'm in the midst of installing a new engine, I decided to even out the holes and make a box out of steel that will be on a hinge. It will use two bolts to hold it down and to allow easy access. Once opened the air cleaner element will be removable to clean. This will also allow easy access to the dual carbs or spark plugs.
I'm going to put a piece of medium hole grill mesh in front of the filter to avoid it from catching bugs or rocks. The whole thing will be powder coated black to make it low key.
The hole on the inside will of course be through the tar board and will be finished off with pinch welt more commonly used for pop out quarter windows.
Ill post pictures once completed. I'm taking pictures each step of the way. |
craigman Samba Member
Posted: Sun Apr 29, 2012 4:32 pm Post subject: |
This weekend did more block sanding.
Now it's time for it's final coat of primer!  |
Posted: Sun Apr 29, 2012 5:07 pm Post subject: |
Changed oil, checked valves, replaced fuel line and made a new catch thingy for my deck lid. _________________ 63 T1 Ragtop Gulf Blue, Certified abortion
04 Wrangler Rubicon
66 F250 4X4
Chris
eurotrashin Samba Member
Joined: February 16, 2012 Posts: 27 Location: Tigard, OR
Posted: Mon Apr 30, 2012 8:43 am Post subject: |
Finally got around to take pictures before washing it for the first time since I've owned it.
cox4ragtop Samba Member
Joined: August 17, 2007 Posts: 3 Location: duncan south carolina
Posted: Thu May 03, 2012 6:02 am Post subject: ready for tenn. show |
| i was getting my 62' ragtop ready for the circle ye wagens show. adjusted brakes, put in new headlights, and drive my 70 hoodride to work three days this week.[img][/img] |
MarcusAK Samba Member
Joined: August 20, 2010 Posts: 98 Location: I can see Russia from my house!
Posted: Thu May 03, 2012 6:42 pm Post subject: |
This week I got my 60 Bug running and running well. Although not quite street legal, we took her for a quick drive to the local general store and she drove great! Now for a few new lights and some paint...
 _________________ One thing they don't tell you in any of the manuals is about the blood sacrifice required to keep them alive.
Engines run on fuel. Motors run on electricity or springs. But I know what you mean.
Type 1's- 1960 Bug, 65 Bugbus
Type 2's- 1954 single cab, 72 Westy, 72 European import Arcomobile aka "The Swiss Miss," 76 Custom camper aka "Big Blue"
Type 3- black 64 Squareback |
JimJ Samba Member
Joined: August 03, 2004 Posts: 68 Location: Phoenix, Arizona
Posted: Thu May 03, 2012 8:53 pm Post subject: |
Cleaned out my 28 pic and put a new kit in it. Also installed an new fuel filter to replace the one that failed to stop the junk that clogged my carb. _________________ Tool junkie
62 Ruby Red type 1385 |
RomanBug Samba Member
Joined: October 10, 2009 Posts: 43 Location: Rome, Ga
Posted: Thu May 03, 2012 11:14 pm Post subject: |
| Rebuilt a 30 PICT 1 for my 1300 in my 63 bug. Now to do it again and clean the idle circuit a little better. Can't get a good idle without the choke being on. |
boatswain Samba Member
Joined: September 30, 2009 Posts: 25 Location: Portsmouth, VA
Posted: Mon May 07, 2012 11:56 am Post subject: Engine tin upgrade |
I recently put a 67 only air cleaner on the Beetle so this weekend I put on the correct breast plate, pulley tin, pulley nut cover tin, air cleaner mounting bracket, lower R/L breather tin, correct gen stand w/ oil filler, all associated hoses and pass thru gaskets. Does anyone have the right side air breather J-tube? I have the left one. Now I have to replace the aftermarket crank pulley and gen pulley (found both of them hand tight only ) and chrome head tin (when rebuild) and move gas filter to under car. And after all that, replaced the driver widow rear felt and a 67 window crank by WW. Lastley, I poured a nice cold beer and smiled at all my efforts!  |
Posted: Mon May 07, 2012 5:37 pm Post subject: |
Yesterday I wired up the tach, radio, fog light, and back up light. And reinstalled my newly rebuilt wiper assembly.
I got the new German dual cylinder m/c mounted with the brake light switches but now need to bend the brake lines to fit. |
bakorag Samba Member
Joined: May 04, 2012 Posts: 3 Location: bakersfield ca
Posted: Mon May 07, 2012 10:16 pm Post subject: my 63!!! ragtop |
| Bought it from a friend last Thursday night , Friday a quick trip to AAA and $250 later I was ready blead the breaks quick oil change and off I went,Saturday morning estate sale , sales !!! Picked up a nice Coleman vintage diamond logo water jug to put on the rack I ordered and hope to make springfest this up coming weekend![/img] |
rcs_80 Samba Member
Joined: November 10, 2011 Posts: 57 Location: Oakhurst, CA
Posted: Mon May 07, 2012 10:49 pm Post subject: |
| Very nice boatswain! |
YouBugMe58 Samba Member
Posted: Tue May 08, 2012 12:10 am Post subject: |
Stopped by the storage unit to check on her. Still there waiting on me to dig here out. Going to be a long six months waiting on my house to be built. _________________ 59 Euro Ragtop Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553
Working on the boring stuff is still better than a good day at work!
Only 3 things matter in life, Those you Love, Those whom Love you and Your final Destination! Enjoy Them.
Trophys are just a reminder of your past and to look at. Enjoy things and use them. |
VWBUGGAH Samba Member
Posted: Tue May 08, 2012 6:07 pm Post subject: Installed adjustable spring plates |
Hi,
This week I finally got those adjustable spring plates installed. Those plates are awesome. I adjusted most of the negative camber out and I really like the way it's looking. I will try to post pics if I can figure out how to do that on here. |
whitey67 Samba Member
Joined: May 08, 2012 Posts: 2 Location: Ft. Worth, TX
Posted: Tue May 08, 2012 7:56 pm Post subject: |
started changing out the bad fuel pump. Went well until the pump flange broke off down in the case
It's always something. |
Posted: Tue May 08, 2012 11:04 pm Post subject: good tuesday! |
| Picked up knock-down rack from local dealer (thanks German dreams!) Put the million screws in it , and ready for install before driving to work tomorrow! |
agh19 Samba Member
Joined: June 22, 2010 Posts: 33 Location: Wake County, NC
Posted: Thu May 10, 2012 6:00 pm Post subject: |
| Got the engine in last Thursday and started it on Sunday. First time it's run in well over a decade. Fixed the oil leak from the left side rocker cover, got the window back in the driver's door with new scrapers and channel, greased the front end, disassembled and serviced the turn signal switch, rebuilt the wiper assembly. |
Posted: Mon May 14, 2012 9:51 am Post subject: |
Got new tires and whitewall inserts on.
