shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
Chalklinedetail Samba Member
Joined: April 25, 2010 Posts: 311 Location: San Mateo, CA
Posted: Sun Feb 02, 2014 9:45 pm Post subject: Re: New engine for 1967 convertible. |
Jon65 wrote: |
Brian Anthony wrote: |
Just finished up a new engine for the wife's '67 convertible. 1967cc, 74 x 92TW.
Beautiful. |
I don't use this word loosely, because I know it's power...but this engine is Ridiculous!
Nice job Brian _________________ My 63 build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=520975&highlight= |
Posted: Sun Feb 02, 2014 9:53 pm Post subject: |
Replaced the (3) fuel lines. Moved the fuel filter to the front (under the tank), figured it would be a good location so I could replace the fuel filter and check the brake fluid at the same time. Also added a shut-off valve.
Brezelfahrer Samba Member
Joined: March 26, 2010 Posts: 65 Location: Vlaanderen
Posted: Thu Feb 06, 2014 1:31 pm Post subject: |
I finally got my 1959 european standard to the Belgian MOT this morning.
The staff looked very surprised as I explained the car was equiped with cable brakes! Must be a new generation of technicians not in the know of the automobile ancestors!
After hearing that information, they didn't mention a minor difference in brake capacity between the left and right front brakes...
And I got all the documents to order my oldtimer licenseplates "American Style" (small square licenseplate also called Motorcycle licenceplate)
_________________ 1952 typ 1 european standard
1959 typ 1 european standard sunroof |
brash Samba Member
Posted: Fri Feb 07, 2014 7:48 pm Post subject: |
daughter working on her 67 on a friday night, yes i did yell at her for not wearing her face shield. gonna show her how to blast the rest of it clean tomorrow and hope to spray some primer
_________________ go fast or go home |
EA812 Samba Member
Joined: December 07, 2008 Posts: 1223 Location: North central, CT
Posted: Sat Feb 08, 2014 3:33 pm Post subject: |
brash wrote: |
way to go! |
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Sat Feb 08, 2014 7:51 pm Post subject: |
TAGS!!!!!! its now my daily driver
fabricator john |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Sun Feb 16, 2014 9:38 pm Post subject: |
Replaced 4 shock absorbers (dampers) and installed caster shims....huge difference in freeway and local street ride qualities. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Tue Feb 18, 2014 1:57 am Post subject: |
had some quality time on my '59 european standard today!!
instead of adjusting the cable brakes, I decided to take the drums of, so I discovered this:
also wanted to clean this mess:
the result, with new glued linings:
this will definitely improve the brake performance _________________ 1952 typ 1 european standard
Posted: Tue Feb 18, 2014 1:36 pm Post subject: |
spent 15 minutes to add 2 washers to my bowdin (?) tube - 100 percent solved my awful shudder / chatter problem....what a xc#4/& that condition was...
Reinforced the old lesson: fix the easy stuff first... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Jon65 Samba Member
Posted: Sun Feb 23, 2014 8:21 pm Post subject: |
Replaced all of the heater components and converted my single circuit brake system to a dual circuit. |
vamram Samba Member
Posted: Mon Feb 24, 2014 6:12 pm Post subject: |
Replaced the sealed beam headlights on my '64 sedan w/H4 compatible assemblies using H2 bulbs. Reassembled the bucket w/the correct rubber seals for the lens and the chrome ring-to-body seal. Also installed amber parking bulbs. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Mon Feb 24, 2014 10:22 pm Post subject: |
I added an important safety warning sticker to my glovebox door:
"CAUTION: Do not lower windows at speeds in excess of 200 m.p.h." _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Vettelover84 Samba Member
Joined: September 25, 2013 Posts: 1 Location: SomeWhereBetweenHereandThere
Posted: Sat Mar 01, 2014 1:42 pm Post subject: 1967 Beetle |
Trying to get her back together.. Still learning a lot and fumbling through the work.
The Rear Disks need to be torqued... A new Pitman arm is on order because the inner tie rod is seized into it... I will work on getting it out later...
In the mean time... I have A LOT to do!!!
Buscowboy Samba Member
Joined: October 29, 2004 Posts: 402 Location: South Coast, England
arkansas warrior Samba Member
Joined: December 20, 2013 Posts: 15 Location: Arkansas
Posted: Sun Mar 02, 2014 4:43 pm Post subject: |
Finished up the left side upper and lower ball joint replacment and now starting the right side |
itskyle Samba Member
Joined: October 04, 2013 Posts: 634 Location: Plainfield, IN
Posted: Mon Mar 03, 2014 4:04 pm Post subject: Monkeyed with the replacement starter. |
And ended up having to push start it last night and again today.
I'm the wrong side of forty to be push starting my vehicle _________________ --
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.) |
