Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Sat May 02, 2015 4:19 pm Post subject: |
Replaced leaking front gas hose (again?).
Made 4 clamps and clamped down gas tank!! ( Thanks a lot PO) _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Sun May 03, 2015 12:02 pm Post subject: Tired tires retired |
My '67 Beetle had a gash on one tire so one new "KUMHO POWER STAR 758" 165/80R 15 and a good as new spare tire went on the front, best two out of three to the rear and leftover to the spare rim...which does not balance.
DISCOUNT TIRE in Kennesaw, GA lets me assist with jack points and such and I think the young fellas really liked working in an old car.
They have the balancing jigs that fit but, balked at 19psi fronts and 27 psi rears until I showed them the sticker inside the glove box door..I run 20 front and 28 rear and they were happy to oblige.
She's steppin' now!
Buscowboy Samba Member
Joined: October 29, 2004 Posts: 402 Location: South Coast, England
Posted: Mon May 04, 2015 11:34 am Post subject: |
Cut to fit some carpet under lay to go over the sound deadening material on the luggage tray. Ready for the square weave now!
_________________ 1962 Gulf Blue Patina Deluxe Beetle
1963 SubHatch Westfalia MG/PW
1967 Fastback RHD Regatta Blue
1970 FI Auto Squareback
1999 T4 Transporter 2.5 TDI Reimo
http://www.youtube.com/@BuscowboyClassics
https://www.instagram.com/buscowboy/ |
microbus Samba Member
Joined: October 12, 2007 Posts: 527 Location: Alberta, Canada
Posted: Tue May 05, 2015 7:20 pm Post subject: |
After a 2 year hiatus (grafting on a rag because of roof damage) I got to drive it home...
_________________ Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Automotive Service Technician |
adam fisher Samba Member
Posted: Fri May 08, 2015 6:56 am Post subject: |
been working on my 67 bug resto. almost finished. also working on my dads new purchased 70 sunroof bug. wiring issues under hood. "what a mess" |
DrKeck Samba Member
Posted: Fri May 08, 2015 11:49 am Post subject: |
New tachometer from speedhut.com came in today!
_________________ 1966 Beetle
1600cc 50bhp
Daily Driver |
jvan_wert Samba Member
Joined: October 07, 2004 Posts: 42 Location: Washington
Posted: Sat May 09, 2015 3:47 pm Post subject: |
Replaced the points, set timing and dwell, and adjusted the clutch on the 67. yesterday it got some new tires. _________________ '85 Vanagon GL, 2.0 ZETEC
'78 Baywindow
'67 Beetle
'63 Beetle
"It helps to live in a box to think outside of one." Jim Akiba |
Posted: Sat May 09, 2015 4:59 pm Post subject: |
jvan_wert wrote: |
Replaced the points, set timing and dwell, and adjusted the clutch on the 67. yesterday it got some new tires. |
She's steppin' out now!
67 sunroof Beetle
80 Vanagon |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
rcroane Samba Member
Joined: January 03, 2013 Posts: 1996 Location: Springfield, Virginia
Posted: Sun May 10, 2015 7:58 am Post subject: |
Installed old school GPS. Mounted by simply removing ash tray knob and replaced with chrome cap nut. Completely reversible. Not terribly reliable since the metal dash wreaks havoc on the magnet in the compass!
_________________ '65 Sunroof Bug |
Underdog65 Samba Member
Joined: October 07, 2007 Posts: 143 Location: Lake City, PA
Posted: Sun May 10, 2015 3:09 pm Post subject: |
Removed hard start relay that the PO had installed and used 2 size smaller wire then what should have been used .Cleans starter contacts and positive cable now it cranks faster and thing work better.replaced battery and went for a drive. _________________ Look off in the distance it's a bird it's a plane no it's a frog no it's just little old me Underdog65 and my Sweetpolly passing your way. |
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Sun May 10, 2015 5:42 pm Post subject: |
microbus wrote: |
Looks great! _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
Posted: Sun May 10, 2015 6:20 pm Post subject: |
shano63 wrote: |
microbus wrote: |
Looks great! |
As does yours... Gulf Blue is a great color! _________________ Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
vdubadm Samba Member
Posted: Mon May 11, 2015 12:18 pm Post subject: |
Put in the new rear blinds!
bugandxbandme Samba Member
Joined: November 09, 2009 Posts: 162 Location: Richmond, VA
Posted: Mon May 11, 2015 12:28 pm Post subject: |
Started sanding my vert decklid so I can paint it to match my car. I am thrilled I was able to find one in my price range in town! It just needs a tiny bit of work, and is pretty much the most complete vert lid I have ever seen. Inside is original paint, some shade of green. Almost looks like Beryl green, which is funny since that was my car's original color. I will be painting it black.
Posted: Mon May 11, 2015 12:29 pm Post subject: |
@vdubadm I love the blinds!! |
Posted: Tue May 12, 2015 7:37 am Post subject: |
Installed new master cylinder reservoir, blue hose and mc grommet. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
shelbylynn Samba Member
Joined: May 07, 2015 Posts: 9 Location: United States
Posted: Tue May 12, 2015 2:50 pm Post subject: |
Rebuilt the solex 28 carb, just to have the starter finally stop working for me! Luckily I have a few laying around! |
Posted: Tue May 12, 2015 5:50 pm Post subject: |
Spent the day attaching my rear bumper with bolts instead of 1/4 "sheet metal screws both side bumper brackets held in place with screws captured nuts gone in bracket . I used a capture but used to build furniture drill through to inside welded the insert in from the back side then tightend the bolts down everything now solid . _________________ Look off in the distance it's a bird it's a plane no it's a frog no it's just little old me Underdog65 and my Sweetpolly passing your way. |
Posted: Fri May 15, 2015 5:57 am Post subject: |
Made some overmats for the '61 Barnfind to protect the rubber mats. Just used cheap door mats from IKEA that I cut to shape. Did the same to a '66 Beetle I had a while back.
