shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Sun Aug 02, 2015 3:08 pm Post subject: |
Was going to post that I took it out for a nice drive this weekend but...driving home from where I keep it stored, this happened..
E-brake lever must have let go. At first I thought I was dragging something, not the case. I finally got home, 40 miles, pulled the drum and thats what fell out. On a lighter note, I recieved my longer safari sliders. Just have to paint em.
_________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
Thor_orr Samba Member
Joined: July 20, 2013 Posts: 85 Location: Day creek, WA
Posted: Sun Aug 02, 2015 6:14 pm Post subject: |
That is fawkin dope as hell! |
TheDon Samba Member
Joined: July 14, 2005 Posts: 498 Location: Windermere
Posted: Tue Aug 04, 2015 8:56 am Post subject: |
I put my seatbelts in last night, the night before a WW shifter lock, and todays plan is to redo the fuel lines and relocate the fuel filter. _________________
lawn ninja wrote: |
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone. |
MomoMoto Samba Member
Joined: March 02, 2015 Posts: 84 Location: Greenville, SC
Posted: Tue Aug 04, 2015 7:34 pm Post subject: |
Took a quick 'before' shot - and drove it to the body shop - hood forward will be the work this round - front end is damaged pretty badly, looking forward to this step. Will post an 'after' when 'Chuck' returns. p.s. traded the 2010 TDI in for the new MK7 GTI...holy crap it is RAD.
_________________ ------------------
'61 Beetle Ragtop
'15 Golf GTI |
Posted: Tue Aug 04, 2015 8:17 pm Post subject: |
Thor_orr wrote: |
Thanks! _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
knightsafe Samba Member
Joined: December 03, 2009 Posts: 123 Location: Murda Beach SC
Posted: Sun Aug 09, 2015 10:02 pm Post subject: |
Got my tag light fixed (bad ground). Then adjusted the valves and put some fresh oil in. Took a lil cruise in the 61 downtown afterwards
_________________ 1967 Type 1 Zenith Blue
1974 Type 181 Patina White |
Ghosttowncs Samba Member
Posted: Wed Aug 12, 2015 8:48 am Post subject: |
Figured out the PO installed switch under the dash ran to the alternator to switch on and off the ability to charge the car
Not sure why they didn't just hook that wire up to the light?
I did get my trans mount tightened, fixed the right brake light, and checked out the ignition system too.
It's almost running too well now..... hmm....
[/img] |
Dirteater74 Samba Member
Joined: June 20, 2015 Posts: 3 Location: Camarillo, CA
Posted: Wed Aug 12, 2015 8:36 pm Post subject: Whitewalls |
Installed Coker 165's out back and Diamond Back 135's up front!! Turned out better than I thought it was going to!
Sonny |
joeyk803c Samba Member
Joined: January 19, 2014 Posts: 102 Location: United States
Posted: Wed Aug 12, 2015 10:08 pm Post subject: |
Installed Ghia drop spindles, rotors and caliper. My bug stops too damn well now. Bought a center basket cuz I need a cup holder for my morning coffees, a new glove box and some new window crank handles. Also put on some new mag wheels. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Fri Aug 14, 2015 12:27 pm Post subject: |
Installed new tie rods and set toe in.
Had 2 good used tires mounted & balanced for rear. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
grandpa pete Samba Member
baborz67 Samba Member
Joined: June 09, 2010 Posts: 84 Location: park hills mo.
Posted: Sat Aug 15, 2015 12:10 pm Post subject: What did you do to your bug this week |
Drove that baby! |
Underdog65 Samba Member
Joined: October 07, 2007 Posts: 143 Location: Lake City, PA
Posted: Thu Aug 20, 2015 6:13 pm Post subject: |
Installed rear trans mount while I had motor out think they where bad. Also painted mount and clearance trans for 200mm fully wheel.
_________________ Look off in the distance it's a bird it's a plane no it's a frog no it's just little old me Underdog65 and my Sweetpolly passing your way. |
Posted: Mon Aug 24, 2015 4:30 pm Post subject: |
Put in some sound deadening behind the rear seat I got from work. On my drive to the mall, I noticed quite a difference in the amount of noise I got from the engine in the cab. A lot less. I can get 6 sheets of 12 "X 12" for $30 so I'll be putting it throughout the interior of the bug. |
TheDon Samba Member
Posted: Mon Aug 24, 2015 8:25 pm Post subject: |
Bought some $5 ikea sisal doormats and made floor mats for the front. Will get more for the back seats. I vacuumed out all of the carpet and crud from the parcel tray and assessed the rust hole. Can't wait to fix that. I think one of my trans mounts is bad. _________________
lawn ninja wrote: |
Posted: Thu Aug 27, 2015 7:17 am Post subject: |
joeyk803c wrote: |
that's 12 running feet for $30....The roof repair product gives you 16 feet for $19 _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Thu Aug 27, 2015 7:24 pm Post subject: |
grandpa pete wrote: |
joeyk803c wrote: |
that's 12 running feet for $30....The roof repair product gives you 16 feet for $19 |
Yeah I know, but the extra $11 would have been gas to be able to buy the quick roof stuff...
Finally bit the bullet and ordered a repop Empi 34 pict 3 carb. Two different solex carbs and they wouldn't run right. Had to run a high idle to keep the bug going, and not stall or stumble. Put the Empi on, adjusted per manual and it idles correctly ~8-900 rpms, and no stumbling or dying. Just a quick trip up to about 45ish and it was great. Going for a spin, so I'll see how it does for a longer period of time. |
CdF'66 Samba Member
Joined: February 10, 2015 Posts: 5 Location: Portugal
Posted: Fri Aug 28, 2015 5:03 pm Post subject: |
Instaled a sway a way kit and finally lowered the front 😃 |
