Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Mon Oct 12, 2015 8:44 pm Post subject: |
Installed new king pins and link pins. Good thing I had a hydraulic press to use on the kingpin. stupid fiber washer in kingpin kit is too thick to use, had to reuse old parts.
Much better driving tho - no shimmy, no clanking at potholes etc. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Tue Oct 13, 2015 6:48 pm Post subject: It was a good day |
Dropped my painted seat frames off at the upholstery shop today to have the euro cloth covers installed. I am excited to see them after so much waiting. I then went to visit my car at the body shop and it is near primer now. I have never even seen the body with fenders and doors so that will be awesome.
Also picked up my wheels for my Capri Blue car and I have to say they look great. Tomorrow I will get the Coker white walls installed. So excited to see my project moving ahead.
Bruce
grandpa pete Samba Member
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Mon Oct 19, 2015 6:05 pm Post subject: |
grandpa pete wrote: |
Thread title is ;
What did YOU do !!!! |
He said, he ran around dropping parts off, and visited his car at the body shop, that's what he did _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
cricketseed Samba Member
Joined: August 10, 2015 Posts: 115 Location: North Carolina
Posted: Tue Oct 20, 2015 7:33 am Post subject: |
Cheating a little: This is what I've done in the two weeks that I've owned my '66 Beetle.
Got tags and title and insurance squared away. Cleaned and detailed the interior. Took out the paperboard glove box and shored up the duct-tape repair that the previous owner had performed. Waited for parts to come in the mail. Put in a new defrost vent trim piece. Tried and failed to figure out why the key won't unlock the doors. Cleaned out and detailed the trunk (I'm fine with some dirt being in there, but I want it to be MY dirt.) Replaced gas cap gasket and gas tank vent hose. Waited for parts to come in the mail. Removed the front bumper, treated some pitting, and repainted the bumper supports and the back surfaces of the blade and bumper guards. Failed to completely get the round bumper support grommets to reseat when reinstalling. Took apart and cleaned housings and lenses of the turn signals, tail lights, and license plate light. Waited for parts to come in the mail. Added grease to the front beam. Thought I had broken my brand new floor jack but realized I'm just an idiot. Replaced the wiper blades. Repainted the original jacking bar(?) and lug nut socket(?). Replaced the brake and clutch pedal pads. Cleaned one wheel well and fender and gave it two coats of rubberized undercoat. Waited for parts to come in the mail. Stocked up on fuses and gas filters and oil and such. Washed the car.
Up next: Undercoating the other wheel wells. Replacing swing axle boots and topping up gear oil. Waiting for parts to come in the mail. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Tue Oct 20, 2015 8:53 am Post subject: |
cricketseed
Does your door handle have the pin in place that aligns the outer door button with the handle body? See the attached image.
https://www.thesamba.com/vw/gallery/pix/742146.jpg
If it's not there search "67 door handle rebuild." There is a very easy $3 fix that I did last week on my 67 that would not unlock with the key.
Yes, I know that mine is a 67. I checked the galleries and found that the internal mechanism is similar.
Welcome and good luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Oct 20, 2015 9:08 am Post subject: |
Hi, 67rustavenger.
That's a good question. I don't know the answer because I couldn't get the rubber door seal pulled out of the way in order to remove the door handle. It's wedged in there something fierce (and maybe glued?). I gave up when I tore a small piece of it by pulling it too hard. It looks pretty new, and I didn't want to do any more damage. Any suggestions? |
Posted: Tue Oct 20, 2015 9:41 am Post subject: |
Sounds like the door seal is indeed glued into the channel.
I just looked at my door and can see the door handle screw heads by pushing the seal deep into the door channel toward the outside of the door. You can probably get them out with the seal in place. But it's gonna be a fight.
I can't help with getting the glue to release "sorry"
I bet grampa pete will have a suggestion though. _________________ I have learned over the years.
Buy Once, Cry Once!
trektider60 Samba Member
Joined: October 30, 2012 Posts: 73 Location: SE Indiana
Posted: Tue Oct 20, 2015 1:16 pm Post subject: Radio |
I finally got my radio installed today.
_________________ 1960 Indiana Red T1 |
clyde68 Samba Member
Joined: August 09, 2005 Posts: 62 Location: EXETER,DEVON,ENGLAND
Posted: Wed Oct 21, 2015 5:23 am Post subject: |
Picked up my new 62 Ragtop 2332 motor and drove it full chat for 360 odd miles home. _________________ Exeter Aircooled Founder Member
69 California Westy
88 Yamaha Chappy Monkey Bike. |
TheDon Samba Member
Joined: July 14, 2005 Posts: 498 Location: Windermere
Posted: Wed Oct 21, 2015 8:16 pm Post subject: |
Removed the engine, replaced the plugs, wires, and the rear transmission mounts. _________________
lawn ninja wrote: |
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone. |
Nevada Notch Samba Member
Joined: May 02, 2005 Posts: 540 Location: Carson City Nevada
Posted: Thu Oct 22, 2015 7:27 pm Post subject: |
Installed a roller throttle cable tube for my binding issues with my ICT's. Man what a difference. Those of you with cross bar linkage need one of these.
I had to learn how to use the gas pedal all over this morning. _________________ 1966 Euro
1600DP
Dual 34mm ICT's
99% Resto-Custom Daily Driver |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Thu Oct 22, 2015 7:44 pm Post subject: |
A shot from last Thursdays flash floods.
You know what i've been doing...
_________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Thu Oct 22, 2015 10:10 pm Post subject: |
So ...beetles DON'T float? Or did you leave the sunroof open? What a mess. Sorry. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Fri Oct 23, 2015 6:29 am Post subject: |
Took my back seat to this place to have the piping restitched. They did a great job and had it ready two days later. Great place if you are nearby.
http://www.everlastinteriors.com/ _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
Posted: Fri Oct 23, 2015 3:47 pm Post subject: |
67rustavenger wrote: |
I bet grampa pete will have a suggestion though. |
Get a plastic knife and make a mini scraper ; use the scraper to get the rubber loose enough to get at the screws without scraping the paint . |
Thanks, grandpa pete. I'll give it a shot. _________________ '66 Beetle |
Posted: Sun Oct 25, 2015 7:45 am Post subject: |
Pulled the engine to replace the 3-yr old, cracked oil hoses connecting my oil cooler, oil filter, and Empi oil adapter on the block. Changed oil & filter too...put it all back together and tested it. Now to drive 62 mile round trip to san Diego and then 80 miles back to san Bernardino....200-250 miles every weekend with my Baja daily driver. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Zuesticle Samba Member
Joined: May 29, 2012 Posts: 15 Location: Okinawa, Japan
Posted: Sun Nov 01, 2015 10:58 pm Post subject: |
Saw some "bubbling" from this area and decided to take the plunge last night with my orbital sander and some 380 grit. this is one gnarly area that may just get covered right back up for awhile... _________________ 1966 T-1 1300cc "Minnie"
1960 T-1 2332cc "Mickey" |
