79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Mon Nov 02, 2015 7:21 am Post subject: |
Old school semiannual tune up: checked points, timing; cleaned and gapped spark plugs; changed oil; adjusted valve clearance and brakes. All on a beautiful warm fall day with falling leaves. Doesn't get better than that for me. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
trektider60 Samba Member
Joined: October 30, 2012 Posts: 73 Location: SE Indiana
Posted: Tue Nov 03, 2015 5:04 pm Post subject: |
I cleaned up my hubcaps. I used aluminum foil and 100% Real Lemon Juice on two and aluminum foil and Pepsi on the other three. I think the Pepsi worked a little better. There was fizzing, probably the CO2 release, with the Pepsi and I didn't spend as much time on each cap compared to the lemon juice. Then a coat of chrome polish. My caps are not in real good shape being 55 years old, but they do have a good shine at 10 feet. I need to paint the centers yet; I think that will be a winter job. _________________ 1960 Indiana Red T1 |
grandpa pete Samba Member
Posted: Tue Nov 03, 2015 7:13 pm Post subject: |
trektider60 wrote: |
I cleaned up my hubcaps. I used aluminum foil and 100% Real Lemon Juice on two and aluminum foil and Pepsi on the other three. I think the Pepsi worked a little better. There was fizzing, probably the CO2 release, with the Pepsi and I didn't spend as much time on each cap compared to the lemon juice. Then a coat of chrome polish. My caps are not in real good shape being 55 years old, but they do have a good shine at 10 feet. I need to paint the centers yet; I think that will be a winter job. |
There is a guy who sells stickers to fit the hubcap lettering....Do a search _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1493 Location: United States
Zuesticle Samba Member
Joined: May 29, 2012 Posts: 15 Location: Okinawa, Japan
Posted: Sun Nov 08, 2015 9:09 pm Post subject: |
Sanded the top of the body with 380grit, ready to prime and rattle can satin black!(Too broke for a REAL paint job ) _________________ 1966 T-1 1300cc "Minnie"
1960 T-1 2332cc "Mickey" |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Sun Nov 08, 2015 9:16 pm Post subject: |
Re-installed my Pertronix Ignitor ignition that I had removed and replaced with points during troubleshooting for what turned out to be a failed Autozone coil. Also installed new Pertronix 40kv / 3-ohm coil. Car now runs soooo smooth at all RPMs. Been running my Pertronix Ignitor for over 2 years now...
Stinkin' new Bosch points were pitted at less than 2000 miles and car was missing and running fairly poorly (new Bosch condenser too). New points now are crap, even Bosch...I've had better service from Autozone points than Bosch!
BTW this is a daily driver - 10 miles a day to/from work, and 200-250 miles every weekend San Bernardino to Escondido to SB.....except for that failed coil, it has never let me down (that I couldn't fix anyway) in over 35k miles. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Nevada Notch Samba Member
Joined: May 02, 2005 Posts: 540 Location: Carson City Nevada
Posted: Sun Nov 08, 2015 9:39 pm Post subject: |
Can't figure out if this is good luck or bad luck.....
After replacing the O rings on my push rod tubes, I looked over at the tire and found a nail in my tire. Saved me from having to fix it on the road. Removed the nail and put in a plug. _________________ 1966 Euro
1600DP
Dual 34mm ICT's
99% Resto-Custom Daily Driver |
Posted: Wed Nov 11, 2015 5:46 pm Post subject: Re: What did you do to your Beetle this week? |
I got my speakers installed today. Radio was installed 2 weeks ago, but I just finished the wiring today also. I read on a post to put the yellow wire (constant 12V) on the far left and the red wire (switched) on the far right. I found out that info is for an eight fuse block. My '60 has the four fuse block and the red wire needs to be on the second from the left fuse. The old picnic basket just fits behind the rear seat with a speaker on each end; no holes cut in anything.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Wed Nov 11, 2015 6:20 pm Post subject: Re: What did you do to your Beetle this week? |
trekrider,
I love that picnic basket idea.
I at one time was going to do a vintage suit case with speakers installed. The picnic basket is a way better idea.
Changed my mind and now run a Bose sound box lll and Bluetooth from my windshield mounted phone. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Nov 15, 2015 9:41 pm Post subject: Re: What did you do to your Beetle this week? |
Adjusted my valves and installed my new polished stainless steel valve covers.
A nice feature is these come with s strip welded in to prevent the lower section of the gasket from getting sucked in...
[oh yeah - these are EMPI !] _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
MomoMoto Samba Member
Joined: March 02, 2015 Posts: 84 Location: Greenville, SC
Posted: Mon Nov 16, 2015 1:27 pm Post subject: Re: What did you do to your Beetle this week? |
Installed a new stereo, and speaker. I can barely hear it though, my bug is loud (no rubber motor/trans mounts; no interior/headliner at the moment). While trouble shooting a broken connection on an old wire - replaced the voltage regulator, generator brushes, and cleaned up a bunch of other wires in the process. Sorry for the crappy cell phone picture, the sun is coming in the window at the camera...and p.s. the hole in the dash was already there, this plugs that hole so the cold air doesn't keep pelting me...
_________________ ------------------
'61 Beetle Ragtop
'15 Golf GTI |
Posted: Mon Nov 16, 2015 9:18 pm Post subject: Re: What did you do to your Beetle this week? |
MomoMoto wrote: |
Question on that, are there any performance benefits to be had from "solid" engine mounts? I was thinking of building/welding some up for my car(It's NOT a daily driver). _________________ 1966 T-1 1300cc "Minnie"
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Tue Nov 17, 2015 11:27 am Post subject: Re: What did you do to your Beetle this week? |
Oil cooler seals , yay big fun, loose the lid n hinges n old school from the top. Fabricator john |
Posted: Wed Nov 18, 2015 1:19 pm Post subject: Re: What did you do to your Beetle this week? |
Quote: |
Question on that, are there any performance benefits to be had from "solid" engine mounts? I was thinking of building/welding some up for my car(It's NOT a daily driver). |
Not that I am aware of, the set up is not the original 40 horse stale air - an early 70's 1600 and trans from a ghia it looks liked based on my research of some number codes on it. A previous owner was a drag racer, and it raced...just not sure what his set up was - because I heard he dropped the 1600 DP in to it to sell it...took his race motor out.. _________________ ------------------
'61 Beetle Ragtop
'15 Golf GTI |
joeyk803c Samba Member
Joined: January 19, 2014 Posts: 102 Location: United States
Posted: Wed Nov 18, 2015 11:06 pm Post subject: Re: What did you do to your Beetle this week? |
Put the deck lid back on an drove it! Then I realized how badly I need ball joints, and an alignment. Bought some lower ball joints today, going to try and get them in on friday. We'll see. |
Posted: Fri Nov 20, 2015 10:08 am Post subject: Re: What did you do to your Beetle this week? |
Had four rainy days here this week. I put the 67 up on jack stands and scrubbed the underside of my fenders. Ospho on the light surface rust. Then undercoating.
Also rerouted the speedo cable from over the top of the tie rod to under.
Shortened the back up light wires that were 6-8" too long.
Took it out for a drive late yesterday. I noticed that the left headlight was dim. And the speedo is screaming. This will be the second time I have to fix this issue. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Nov 21, 2015 8:55 am Post subject: Re: What did you do to your Beetle this week? |
Installing my new stainless steel j-pipes riiiiiight now. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Stock Steve Samba Member
Joined: April 10, 2005 Posts: 1963 Location: My Left Nutmeg State
iamthewalrus30 Samba Member
Posted: Mon Nov 23, 2015 4:46 pm Post subject: Re: What did you do to your Beetle this week? |
I mounted and wired my bosch fog light recently purchased. But before that I had to change out a cracked fuel hose under the gas tank. My roommate came home late Saturday night and said my car smelled like gas. I agreed with the smell and found the leak. I did everything on Sunday. Sundayfunday
matching Bosch headlight lenses
Hose was leaking from both ends
