DBK UK Samba Member
Posted: Sun Aug 24, 2014 11:34 am Post subject: |
everything was replaced,all new parts and drums skimmed
_________________ DBKUK |
DBK UK Samba Member
Posted: Sun Aug 24, 2014 11:38 am Post subject: |
under of body was cleaned couple bits of small welding and then waxoiled.
headlamp bowls needed alot of modding
inside had no carpets so got a new carpet set and stamped a few dirty marks on them to blend them in lol,fitted dash trim that was missing and drivers seat is getting repadded as it was horrible to sit on
DBK UK Samba Member
Posted: Sun Aug 24, 2014 11:47 am Post subject: |
motors out and stripped being detailed properly (for a rat car!) not show quality but you get the idea.not standard 30hp colours but wanted to do something diffrent as the cars not stock anyways
engine was stripped,detailed,detailed carb etc
DBK UK Samba Member
Posted: Sun Aug 24, 2014 11:48 am Post subject: |
under all the arches were cleaned and wax oiled
DBK UK Samba Member
Posted: Sun Aug 24, 2014 11:49 am Post subject: |
underside cleaned and detailed
DBK UK Samba Member
Posted: Sun Aug 24, 2014 11:51 am Post subject: |
inside even under carpets was cleaned/painted and detailed
DBK UK Samba Member
Posted: Sun Aug 24, 2014 11:53 am Post subject: |
all window rubbers have been replaced inc the 1/4 window rubbers and outer door scraper trims/rubbers,they have been aged to match the car.
the door panels have been of,new door cards made with the old material fitted,doors waxoiled inside and rebuild making sure windows are greased and working and doors open shut as they should.
both door bottom door pins have been changed for correct NOS pins as they were noisey and a bit stiff.
front end has steering stops fitted so the wheels dont rub the inner arches even on full drop.
the air ride has been set up with a fail safe,if the air fails the car can still drive and turn without rubbing/catching anywhere.the car sits higher than before slightly BUT the fail safe is a must,saftey first and foremost.
its not about the outside look its more important about the bits you DONT see.
new tyre well panel welded in and detailed to match in
fuel tank been repainted and detailed to look old
everything removed,cleaned and detailed but not going to far with the detail!
DBK UK Samba Member
Posted: Sun Aug 24, 2014 12:02 pm Post subject: |
volksworld show rat display
also was going to be in a 3rd big vw magazine and a vw book but I pulled the plug on it. _________________ DBKUK |
alan n Samba Member
Joined: August 08, 2009 Posts: 153 Location: Penzance, UK
DBK UK Samba Member
Posted: Sun Aug 24, 2014 12:48 pm Post subject: |
thanks Al,
was good to meet up with you all at vw jamboree weekend _________________ DBKUK |
DBK UK Samba Member
Posted: Mon Aug 25, 2014 1:28 pm Post subject: |
my latest project "CONTENDER"....opposite to the rusty cars, this will be a full nut/bolt painted show car.... since this picture was taken there has been well over 2yrs of solid welding....fully detailed build thread coming in the near future
DBK UK Samba Member
Posted: Mon Aug 25, 2014 2:01 pm Post subject: |
my 356A brakes that i restored drilled for Porsche pattern....for daily driver
faces machined to remove marks ready for polishing...
DBK UK Samba Member
Posted: Wed Aug 27, 2014 2:21 am Post subject: |
F-22A Samba Member
Posted: Wed Aug 27, 2014 2:29 pm Post subject: |
Nice rear bumper on the "Outback" |
aka pip Samba Member
Joined: September 15, 2004 Posts: 2034 Location: LongBeach Fool
Posted: Wed Aug 27, 2014 4:24 pm Post subject: |
It's good to see all the things u learned from this thread over the yrs,your putting to uses...
Nice stuff Andy... _________________ http://www.dbkvw.com/ |
themacnut Samba Member
Joined: February 20, 2009 Posts: 400 Location: Morgan Hill, CA
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4124 Location: Planet VW
Posted: Wed Aug 27, 2014 8:36 pm Post subject: |
Congrats, guys! _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
DBK UK Samba Member
Posted: Thu Aug 28, 2014 12:07 am Post subject: |
F-22A wrote: |
worst part of the car that bumper,let the whole car down _________________ DBKUK |
Blinker Samba Member
Joined: January 24, 2005 Posts: 1187 Location: LONG BEACH
Posted: Thu Aug 28, 2014 10:18 am Post subject: |
themacnut wrote: |
DBK Double Down. Congrats on the cover UK Pip!
Congratz to both of you..! _________________ D.B.K.
WWW.DBKVW.COM |
pip hancox Samba Member
Joined: February 01, 2005 Posts: 362 Location: Temecula,CA
Posted: Fri Aug 29, 2014 10:32 am Post subject: |
Thanks guys! _________________ DBK!
'49 Standard.
'51 Crotch Cooler.
'58 Kombi.
'65 Notchback.
'64 Ghia.
2 Things.
wifes 2332 '59 lowlight ghia. |
