MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sat Oct 20, 2012 7:35 pm Post subject: |
This is all Home Depot stuff. A drill pump with a common dishwasher braided line connection. Run a couple quarts through the inlet at the case and you are good to go. Easy.
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Ryan Babcock Samba Member
Joined: February 29, 2012 Posts: 15 Location: LOS ANGELES
Posted: Fri Jul 04, 2014 12:25 pm Post subject: one piece window |
Does anyone have a video or can someone walk me through installing these pain in the ass one piece Windows on a 62 vw bug sedan. I have the regulators in just the felt channel,scrapers and glass I need help with..thanks |
Posted: Fri Jul 04, 2014 12:26 pm Post subject: one piece window |
Das Dragon Samba Member
Posted: Fri Jul 04, 2014 12:35 pm Post subject: |
Ryan, you're asking in the wrong forum...ask here--> http://www.thesamba.com/vw/forum/viewforum.php?f=2 _________________ Rest In Peace HamburgerBrad, we will never forget you!
_________________________________________________________
DB3 said:
"Awesome!!!
*********'s constant over-estimation of his own importance never ceases to amaze me."
With *****, "Bullshit Happens"! |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Jul 05, 2014 8:08 am Post subject: Re: one piece window |
Ryan Babcock wrote: |
Did you prime your oil pump? _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
mark tucker Samba Member
Posted: Sat Jul 05, 2014 8:20 am Post subject: |
I fill the sump with fresh clean oil and the level of the pump lets it prime it's self.or you can jack up the front of the car/bus. but dont try it with the rear higher than the front. |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Sat Jul 05, 2014 8:22 am Post subject: |
I fill the oil line coming from the pump with oil and rotate the engine backward. I'll run a half quart or so through this way. Then I pull the plugs and crank the engine over until the oil light goes out. Put plugs back in and fire it up. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sat Jul 05, 2014 8:56 am Post subject: |
$10 worth of junk from home depot, a spare an fitting and a wheel stem. I saw 30 psi at the supply to the case, and then swapped hoses and used it to fill the pump and pick up tube.
longboard511 Samba Member
Posted: Sat Jul 05, 2014 9:40 am Post subject: |
pull plugs slightly grease oil pump gears and crank with outletof filter off till you get oil button that back on then crank till oil light goes out or gauge reads then plugs back in and fire her up
no plugs helps take the load of the rod bearing when they dont have proper lube
also allows the motor to turn over fast |
Posted: Sat Jul 05, 2014 9:49 am Post subject: |
a many of motors have been toasted by not removing the sparkingbolts.hmm a pvc accusump!!!what a concept!!! |
KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
Posted: Sun Jul 06, 2014 9:19 am Post subject: |
MURZI wrote: |
I like this, It looks cleaner to use than my current priming method, How fast does that pump move the oil? And does the pump stall once the oil galleys are full? Or will it keep pressuring the oil through?
Thanks! |
rustybusjef Samba Member
Joined: December 19, 2011 Posts: 329 Location: EVERETT WASHINGTON
Posted: Sun Jul 06, 2014 4:57 pm Post subject: |
Cant remember who I stole the idea from or I would send you a link ,but I have an oil pump just for priming . Prior to any sheet metal install said pump with a cover that has a hole for the inverted drive gear. Spin it backwards till oil circulates .You can also use a cover that has an outlet for a full flow filter. Really works well , very easy . |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Mon Dec 21, 2015 2:39 pm Post subject: Re: Oil Pump priming |
More complicated & expensive than the drill pump... but... I kinda just wanted to tinker around.
I picked up some 2" PVC & other bits at the hardware store.
The gate valve let me control pressure increase rate... since I had it hooked up to the compressed air line.
I wanted to be able to see oil level drop in the PVC part... so added oil, cracked the gate valve open a fuzz & stuck my finger in the hole in the top to increase & relieve pressure.
15-20 psi was a nice & easy oil add rate... not too quick... not too slow. I didn't want to blow air in & clear the passages. I didn't really need the gauge on the PVC unit, since I have a gauge at my sender... but I never know who'll I'll loan it to, so I thought I might as well throw it on.
(... and yes, those are cast iron lawn jockey matched dies in the first pic, if you know anybody that might be intere$ted & has a foundry)
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
cliveawn Samba Member
Joined: December 07, 2010 Posts: 481 Location: Southern Sweden
Posted: Mon Dec 21, 2015 4:05 pm Post subject: Re: JPM primer |
I used the JPM primer and it worked well,removed rocker covers and spun the oil pump shaft with a battery drill anticlockwise till i saw oil running into the heads.
Removed oil pump cover,reversed shaft so it runs off the cam again and fitted cap and the fanshroud.
Good system and could save your newly overhauled motor from getting damaged. _________________ ---------------------------------------------------------
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Python CSP 42mm exhaust.
115 HP
Daily driver 2017 Volvo V60 D5 hybrid
Rica stage 2 tune 345hp.
''Funny thing about common sense is that its not very common''
Seismic gun mechanic |
