Exploded view of handbrake adjustment mechanism -pre 55 Oval
Page: Previous  1, 2
Bendik
Bendik is offline
PostPosted: Mon Feb 23, 2015 1:43 am    Post subject: Reply with quote
Yes, I did as Steven G said above. Worked for me.
54ovsemi
54ovsemi is offline
PostPosted: Mon Feb 23, 2015 6:23 am    Post subject: Reply with quote
Would it be possible to post some pics of how all the parts go back together?
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
Bendik
Bendik is offline
PostPosted: Mon Feb 23, 2015 6:30 am    Post subject: Reply with quote
Wont have time the next 2 weeks, sorry. Remind me after that.
laneven28
laneven28 is offline
PostPosted: Mon Feb 23, 2015 8:51 pm    Post subject: Reply with quote
Here's a few pictures of the handbrake assembly. I put the parts in order of how they should be reassembled and proper orientation. The only parts I don't have shown here are the cotter pin that goes through the end of the rod holding the spring plate and entire assembly in place, and the brake cables.
1950 Pearl Grey Hoffman Standard Split Window
1954 Iceland Green Euro 3-Fold Oval
1955 Strato Silver Transitional 3-Fold Oval
1956 Iris Blue Convertible
1958 Pearl White Lowlight KG Convertible
1961 Turkis Ragtop
54ovsemi
54ovsemi is offline
PostPosted: Tue Feb 24, 2015 11:05 am    Post subject: Reply with quote
Applause THANK YOU!!! perfect Cool
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
54ovsemi
54ovsemi is offline
PostPosted: Tue Feb 24, 2015 8:01 pm    Post subject: Reply with quote
Trying to reassemble hand brake cables but ran into a problem. The cable on right side of cotter pin (see pic) has retracted back in the tube? I tried using a needle nose to release cable but it seems to be locked in place. Any tips on releasing cable tension? The main cable (with spring) has moved forward and not allowing parts to bolt back onto frame head? tips on this welcome as well!
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
rogeliocv
rogeliocv is offline
PostPosted: Wed Aug 22, 2018 4:58 pm    Post subject: Reply with quote
Bendik wrote:
Here is a pick of the two plates I am talking about. I have the plate that screws in to the framehead and these two in addition.
Do you still have the top plate?
PostPosted: Wed Aug 22, 2018 7:34 pm    Post subject: Re: Exploded view of handbrake adjustment mechanism -pre 55 Oval Reply with quote
Bendik hasn't visited the site in almost 2 years, they probably won't see your post.
If you are looking for that part, search the classifieds or post a wanted ad in the classifieds
Page: Previous  1, 2
Page 2 of 2
