weinerbug Samba Member
Joined: January 08, 2008 Posts: 226 Location: Brighton, MI
Posted: Mon Jun 02, 2008 7:02 am Post subject: Beetle AC unit replica |
Here are some photos of the Ice Cooled AC unit for the beetle sedan. It is based loosely on the original optional units from the early 60's.
I made mine a little more trim but went with the curves from the dash contours and the chrome trim and ivory knob to match other dash components.
It is ice cooled. Inside the under dash insulated fiberglass unit is a copper chill coil and a three speed fan. It can work with 6 volt or 12v.
Under the bonnet is an insulated PVC unit that keeps the ice. There is a washer pump connected to circulate the ice water through the coil. Inside the 4" PVC is a stainless screen to keep the ice from clogging the inlet.
The washer pump only comes on when the fan switch is turned to low medium or high.
Drops 80 degree inside temp to about 50 degrees at the bezels. Haven't tested in real life yet, but so far so good. Runs for about 4 hours with full 4 pints of ice blocks. |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
warduke75 Samba Member
Joined: July 16, 2007 Posts: 218 Location: Elmira Heights, NY
Posted: Mon Jun 02, 2008 9:26 am Post subject: |
Did you make or buy? How or where?
and hey '67 Florida Deluxe ', if you wanna sell yer swamp cooler, let me know! Keep getting outbid on ebay! |
Posted: Mon Jun 02, 2008 9:31 am Post subject: |
warduke75 wrote: |
Sorry, your luck just got worse. As I was perusing the classifieds recently, I saw a WTB for a very good condition swamp cooler. Since I sold my '56, the swamp cooler was just collecting dust, so I sold it to him - shipped it out two days ago.
I might suggest you put a "WTB" (want to buy) ad in the classifieds. They work ! _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
Posted: Mon Jun 02, 2008 9:46 am Post subject: |
I made it of course. By now you guys should be figuring out what an engineering geek I am. Of course you can buy a nice one from Gilmore Enterprises, but what's fun about that?
You really want to know how I made it? How much time do you have?
I started with a foam mold, cut and sanded to shape, sealed with plaster and sanded again, sealed with a mold release and covered with two layers of fiberglass and sanded again, primed and painted.
The chill coil is just 1/4" copper spiral coiled 6.5" diameter twice. Couldn't find a reasonably priced oil cooler or heater core the right size.
The fan is a pet cage fan cut a bit.
The switch is from radio shack with some resistors and made to thread on the VW knob.
The under bonnet unit is made from 4" pvc, end cap, straight section 14" long, a 90 degree elbow with a screw on cleanout. The stainless screen is jammed between the straight and end cap. This component could be made smaller or bigger.
The fittings are 1/4" NPT to barb fittings.
The washer pump from auto supply.
The bezels are from Summit Racing Supply.
To refill the ice, you drain the ice melt water and add like four or five frozen plastic cups of water. The plastic cups are tapered, party cups.
Total cost was - $136
PVC $20
SS Screen $4
Fittings & hose $10
Fan $11
Bezels $45
Switch and resistors $5
Knob $4
Fiberglass $21
Washer pump $16 |
Posted: Mon Jun 02, 2008 9:52 am Post subject: |
Not dogging your work, but my only concern would be the life span of the washer pump. They are not engineered to run constantly, so I would wonder how long they would run before they failed. Did you consider any other types of electric pumps that may be heavier duty (like a small fuel pump, perhaps)? _________________ -Kent (BaT "daleallen")
Posted: Mon Jun 02, 2008 11:26 am Post subject: |
Well, you are right. That washer pump may not be good. It will probably run a little longer on 6 volts. I had it laying around. I have tried fuel pumps with water and they don't do well. The fuel lubricates them. Water quickly rusts them shut tight.
I just wanted small. What else? Hmmm...
I had thought originally to use a bilge pump inside the ice reservoir. That may work. Hard to service the way I put things together. Maybe the end could screw on too and then you could get at the pump.
Thanks for the dogging, Howoooo! |
onebad65 Samba Member
Posted: Mon Jun 02, 2008 12:24 pm Post subject: |
your project looks bitchin, let us know how it works on a hot day, what would happen if you put dry ice in it? im thinking about making a similar unit but i want to be shure it will work good enough to spend the time on it. |
Posted: Mon Jun 02, 2008 12:46 pm Post subject: |
Well, dry ice? Water can't get colder than 32 F without freezing, so dry ice wouldn't drop the temp in the circulating water, but might freeze up the reservoir solid. Add salt and you can get colder, but salt is corrosive to lots of parts. But, you are thinking and that's a good thing.
Dry ice gives off a lot of CO2 when it evaporates, so it would have to go somewhere.
This unit is designed to get me to work and back with a degree of comfort. It blows out really cool air and feels good. Oh, the fan is no louder than a normal car's AC unit.
Also, there is a minimum of hacking a nice old car in case I want it out.
Luckily Michigan is only hot for three months.
I'll give a good report in a couple of days. |
hemifalcon Samba Member
Joined: June 15, 2005 Posts: 1481 Location: Union Grove, WI
Posted: Mon Jun 02, 2008 1:42 pm Post subject: |
The only other idea I could think of for a 'water' pump would be those small pumps you get at gardening outlets for fountains. they can run for hours, and they run on 120, but I'm sure you'll have no problem if you just run a small inverter in your car to operate that thing. That's a very cool setup though! Just like your ragtop creation, great work! _________________ '62 VW Bug Sedan (Ruby Red)
Resto pics> http://smg.photobucket.com/albums/v697/hemifalcon/Bug%20resto/?start=all&paginator=top |
Posted: Mon Jun 02, 2008 2:13 pm Post subject: |
i was thinking about using the dry ice to make the regular ice last longer, maybe insulate the dry ice alittle to keep the water from freezing solid and then vent the co2 to a location out side the car, |
metalchomper Samba Member
Joined: June 27, 2005 Posts: 703 Location: Statesville, NC
Posted: Tue Jun 03, 2008 9:01 am Post subject: |
I would suggest one of these: http://www.hargravesfluidics.com/liquid_pumps.php
These are good pumps. I designed the initial series of pumps before leaving the company to design bigger pumps. Someone tried to make a production motorcycle seat cooler with one these, butt the market wasn't there. (pun intended) _________________ Brett
Devil Dog Dubs
I live vicariously through me
'62 Beetle, "Zombie Mojo"
'68 Manx II "Conundrum"
'72 SB "Luftwaffle", 2270 T4
'75 SB Wizard Rodster "Olympias" (Mrs. Metalchomper's car) |
Posted: Mon Jun 09, 2008 10:52 am Post subject: |
Well. I went to the VW show in Ypsilanti MI yesterday. Great show and wonderful people. The weather had been wet and rainy until 7:30am, cleared up and was sunny for the show. Later at about 6pm it poured and blew and power went out.
Anyway, I filled the unit with ice at 8am. The ride to the show took 30 minutes. The unit on low is pretty meager so that could probably be elliminated. I just set it at high the whole way.
The outside temp was 79, and with windows closed the inside temp dropped to 73. It was sunny. The feeling to the skin was pleasant. Anyplace the blower hits you it feels cold. A very pleasant ride with windows closed. Quiet too.
On the way home at 3pm it was about 90 and really muggy. There was still some ice left. For about ten minutes the cooler was still putting out cool air. The inside temp of the car closed up only got down to 85. Again where the blower was hitting me it felt like a cool forest at the state park.
Had I fully loaded the ice before the afternoon trip it might have been a better test.
Ten minutes into the trip home I had to open the windows but the blower still felt good.
I'll do a more scientific test soon. |
jmsmilin Samba's Most Posted
Joined: November 10, 2005 Posts: 3302 Location: Out on Pa-troll.
Posted: Mon Jun 09, 2008 8:07 pm Post subject: |
very cool _________________ Der Schmutzige Süden.
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] \m/ |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Mar 16, 2010 12:29 pm Post subject: |
weinerbug wrote: |
Labor is always free when its your own.
Very nice work, you should start a line of "Chilled Air Cooled Coolers" for VW's. Great idea for road trips, I dont see the practicality for every day driver cars.
Here in the humid/hot south that ice would last about 60 minutes in June. But I like your idea.
Where do you drain the warm water when your done?
On a side note, some cars have an electric aux coolant pump that is designed to pump coolant to remote heater cores. Ive also seen these on motor homes. Small, quiet, and designed for water/coolant. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
andy_t Samba Member
atye Samba Member
Joined: September 02, 2004 Posts: 580 Location: Peachtree City, GA
Posted: Wed Mar 17, 2010 10:18 am Post subject: |
For those of us in the South, what about a larger box for the ice...
Say, a Coleman cooler hidden behind the backseat? I know that there are coolers that advertise that they can hold ice frozen for a couple of days. The pump and everything could be mounted inside, the coils could be a good bit larger, etc.
Hmmmmm... _________________ Alex
1990 Audi 90q 20v sedan
1998 Suzuki Sport Sidekick
2002 Suzuki Grand Vitara
2005 Subaru Legacy GT wagon 5spd Turbo AWD |
ecvwfan Samba Member
Joined: September 15, 2006 Posts: 113 Location: West Valley, AZ
Posted: Wed Mar 17, 2010 8:16 pm Post subject: |
Any word on this? Was it a success? |
SKIN Samba Member
Joined: February 26, 2009 Posts: 60 Location: Michigan
Posted: Thu Mar 18, 2010 7:02 pm Post subject: |
I am digging this man. |
seanboy69 Samba Member
Joined: October 22, 2008 Posts: 1107 Location: Templeton PA
Posted: Tue Apr 06, 2010 7:35 am Post subject: Beetle AC unit replica |
Any more info on this??? Somebody should build these for us engineering challenged _________________ In a sea of american muscle there is alittle bug hiding in the corner...
Oh, and I am 39 years old.....I am supposed to know better......ha!!!
1956 oval ragtop
1962 baha
2276 in progress |
