flatfourfan Samba Member
Joined: September 14, 2004 Posts: 187 Location: Pretoria, South Africa
Posted: Mon Nov 17, 2008 12:30 am Post subject: |
Can anyone show me a picture of the actual fuse that needs to be replaced?
Or is it the small resistor looking unit pictured above?
I've done a search and everything leads me back to this thread.
Cheers
- G _________________ 1957 KCC Porsche Speedster
www.vwsport.co.za
www.aircooledvwsa.co.za/forum |
MConverse Samba Member
Joined: November 27, 2006 Posts: 94 Location: San Diego
Posted: Mon Nov 17, 2008 12:17 pm Post subject: |
It's not a "fuse" in the traditional sense, it's a drop of solder between two pieces of metal.
This is a great writeup on repairing the clock: http://www.aircooledtech.com/vdo_repair/
Look at picture #1 That piece of copper with the eyelet at the end he is pointing to, is soldered to the eyelet right above it.
Put a drop of low temp solder right there so it makes a connection, oil it, hit it with some high pressure air to get oil in all the crevices and it should start working again.
I just went thru this procedure this weekend and it worked out great.
Cheers,
Mike |
Posted: Mon Nov 17, 2008 11:11 pm Post subject: |
MConverse wrote: |
Cheers,
Mike |
Awesome thanks Mike, I actually had mine open last night next to a unit that I knew worked and kinda figured the rest out.
Great link by the way.....thanks.
I went through 4 clocks last night and every single one had the thermo fuse that was gone.
www.vwsport.co.za
miomio Samba Member
Joined: November 21, 2007 Posts: 124 Location: SAN JUAN, PR
Posted: Sun Nov 23, 2008 5:25 pm Post subject: |
Wow guys, besides the fact that I'm going blind (can't see where the fuse goes (of course, not the broken one ), what about a fix for a 6 volt clock? I'm about to put mines out and appart but I'm also thinking about buying somebody elses before I ruin mine's |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22407 Location: Kimball, Mi
Posted: Sun Nov 23, 2008 8:15 pm Post subject: |
I guess I need to post some pics of my clock repair. Granted it's not very conventional, but it does work. It's very similar to what was done on page one of this thread, and the clock can be used in either a 12 volt, or a 6 volt car. It's pretty simple, and requires using a clock kit from Walmart, or one of the other like stores. I just happened to get mine from Walmart (the long shaft version) for 4.95, and the only added part was a 3/8-16 nut for a spacer. I did have to trim the minute hand down from the kit, but the hour hand from the original clock was reused. I did have to gut the original clock works, and open the original shaft hole slightly (so the new threaded shaft could pass thru). It keeps very accurate time, and the AA battery lasts quite a while (4 months so far on the one in my 65 Notch, and it's been sitting here next to my computer monitor for the last month). The conversion took me about 45 minutes the first time, but by the time I did a 3rd one, I had that time down to a half hour. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Nov 24, 2008 12:01 am Post subject: |
miomio wrote: |
It's not an actual fuse, there is supposed to be a small wire attached between the two sections shown. You can just about see the small piece that's left on the upper one.
I just wired in a small piece of wire and after a good clean, it's working 100%.
www.vwsport.co.za
miomio Samba Member
Posted: Tue Nov 25, 2008 6:40 pm Post subject: |
Thanks for the light flatfourfan. It's just that it looked like part of the welding as you pull away from it. That IS a great take with the hightlighted drawing. I'll cancel my eye doctor's appointmement |
TommyBoyGomes Samba Member
Joined: May 28, 2005 Posts: 1531 Location: L.A./Dublin, Irl
Posted: Sat Dec 27, 2008 5:27 pm Post subject: |
Well, I've been at this repair for 3 hours now and have followed all of the direction to a T (even the ones in the other link) and have had no luck. I've re-soldered that gap 3 times, twice with a strand of copper wire inbetween the gap and every time I get no movement out of the point (or anything) when I apply power.
It doesn't even look like the point has anything to hit if it were to move in either direction. This is very frustrating, can anyone offer any help? Thank you. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21510 Location: Oklahoma City
Posted: Sat Dec 27, 2008 8:47 pm Post subject: |
If you have repaired the link and get no point movement...file teh points. They get carbonized. If no luck...then the solenoid is burned out.
If you have clocks from the last two years of type 3...they are superb. Some are tuning fork clocks...not mehcanical. They never fail. You have to do a little modifying to get them fit into the slightly earlier instruments.
Oh also...when you apply + to the terminal on the back of teh clock...you must have the chassis of the clock grounded to negative in order to get a circuit. Ray |
Posted: Sat Dec 27, 2008 11:15 pm Post subject: |
Thank you for the response Ray. The chassis of the clock was indeed grounded at the time of testing (I tested using two different grounds and two different +'s, both of which registered 12V on the voltmeter).
What I am a little concerned about is that the point arm on my clock doesn't look similar to the one in the previous photos in this thread. My clock (69) seems to only have the point arm, but I don't see a second fixed point for it to contact... is a 69 clock different from the ones in the pictures? Thanks! |
Posted: Fri Jan 23, 2009 6:30 pm Post subject: |
*UPDATE*
So in the end I decided that it would be best for me to leave this to a professional. After taking it to a few watch/clock repair shops around LA and being denied, I finally found one who fixed it.
His name is Max Keller and works at a jeweler shop in El Segundo, California (I forget the name of his shop right now, but I'll get it when I pick it up).
He said that he was able to fix it so that it still ran electromagnetically (not a quartz conversion) and so far it looks to keep time well. He said that either the low-temp solder didn't do the job or I had fried some other components when I tried to solder a piece between those two points, so be careful and use an appropriately-sized soldering iron if you're going to do this yourself.
The price was a little expensive ($95!) but was far cheaper than a quartz conversion would have cost from another watch maker ($200+). I know $95 is alot to fix a stupid clock, but for those that want the original clock to work as it was originally intended, at least I found someone who could do it.
I'll give you guys another update when I go to pick it up to verify that it keeps time, etc. Just thought I'd share! |
Posted: Sun Jan 25, 2009 4:22 pm Post subject: |
correction, his name is Walter Keller and the name of the jeweler that he works at is "blue diamond jewelers" www.bluediamond4.com although the link didn't work when I just tried it. |
68notch Samba Member
Joined: August 16, 2007 Posts: 544 Location: Perth, Western Australia.
Posted: Tue Apr 19, 2011 7:17 am Post subject: |
So I have made this fix with soldering the link, filed the electrical terminal with emery paper, checked the power supply with a meter (12.4v), checked the fuse under the dash and wriggled the gauge in place to try and get good ground in the hope it would come to life but nothing seems to be working for me. No clack, click or tick!
Any more tips or something I have missed?
Only plus is that the back light works. _________________ John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227
Posted: Tue Apr 19, 2011 10:24 am Post subject: |
sorry to dissapoint you notch, but the backlight actually has nothing to do with the clock mechanisms . I got to the point where you did and decided that it would be best for my sanity to let a clock-maker handle it... If you figure it out, fair play to ya! _________________ 1969 Squareback, 1776cc
1990 Vanagon Multivan |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Apr 19, 2011 1:18 pm Post subject: |
68notch wrote: |
So I have made this fix with soldering the link, filed the electrical terninal with emery paper, checked the power supply with a meter (12.4v), checked the fuse under the dash and wriggled the gauge it in place to try and get good ground in the hope it would come to life but nothing seems to be working for me. No clack, click or tick!
Only plus is that the back light works. |
Check for continuity between the + post and the metal clock body.
No continuity= open loop.
Continuity but no run= clean the hell out of the mechanism with electrical cleaner. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
supaninja Samba Member
slammed 68 Samba Member
Joined: October 14, 2009 Posts: 58 Location: south bend IN
Posted: Wed Apr 27, 2011 10:50 pm Post subject: |
not sure whats up with mine maybe just needs clean. i checked it has power to the solenoid, it clicks when i touch it with test light, points have power i can get them to fire like a machine gun if touched just right. but the clock wont run on its own. if i play with the gears a little when i have power and ground it will run the rewind points will make contact then wheel will move and they open up. but thats only if i apply a little pressure to the gears. any help or suggestions on what i should do next would be greatly appreciated. i would like to have it working |
Yeti69 Samba Member
mmilliganclark2 Samba Member
Joined: April 25, 2005 Posts: 199 Location: Cedar City, Ut
Posted: Sun May 01, 2011 10:43 am Post subject: |
My clock came out of a 67 fasty. I removed the back cover and the workings look different than the ones in the pics. Can anyone explain to me where the thermo fuse would be on my model? _________________ 1967 Fasty |
