gmadamo Samba Member
Posted: Tue Apr 08, 2014 7:30 pm Post subject: Alternator for Generator |
I installed an Alternator, replacing a perfectly functional generator. Why? I wanted to do things like power seat heaters and electric heater/defrosters. About half way through I seriously questioned the project as the generator works Ok after all. There is always the question of originality but lots of other things are no longer original so why not one more. Now that the pain of the process is complete I think I am OK with it. |
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Wed Apr 09, 2014 9:25 am Post subject: Re: Alternator for Generator |
gmadamo wrote: |
You made the right call. A standard generator will not keep up with resistive loads like you have. I still have my generator and it's fine until I turn on my heating system blower and stop at an intersection with my lights and turn signal on!
Blink..................... blink.................... blink................. |
Altema Samba Member
Posted: Wed Apr 09, 2014 9:39 am Post subject: |
Oh, and speaking of electrical, I was driving the Ghia yesterday and noticed my fuel gauge level had dropped substationally, and my tachometer was reading low as well. I reached under the dash and rotated the fuse, and they went back to normal. Soooo, when I arrived home I pulled out the Dremel and a tiny brass wire wheel, then pulled each fuse and cleaned the ends as well as the terminals that they clip into. All was good after that.
I also decided to swap my winter quietpack muffler out for the straight through muffler, and found that the support bracket and come off of the quietpack. Thank goodness these things only take a few minutes to change, and now I've got my wondows-open music!
Paul |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Wed Apr 09, 2014 12:32 pm Post subject: |
Why two types of mufflers? And why one for winter? |
Altema Samba Member
Posted: Thu Apr 10, 2014 11:18 am Post subject: |
Woreign wrote: |
The Bugpack straight-through muffler sounds great and lets me rev freely to 6,000 RPM, but is too loud with the windows rolled up. For winter, I install a Bugpack single quietpack to make it quiet when it's 15 degrees F below zero. I'm kind of used to the quietpack sound now and am thinking of getting it repaired or replaced. The tone is nice and deep, and although it does not send chills down your spine when you wind it out, it's nice to cruise on the freeway and not even hear the engine.
I also have an extractor that I would only use this for track use, as it's crazy loud and would surely have me arrested in short order. It does have the optional silencer, but that defeats the advantages of an extractor. |
Posted: Thu Apr 10, 2014 12:57 pm Post subject: |
Is your muffler the same as mine?
How does it compare to the stock muffler? Substantially louder or about the same? I ask because this is the loudest VW I've ever owned. My previous cars, Notchback, Beetle, and Thing, all had stock exhausts and were some what quieter. But my Ghia also gets the best fuel mileage than any of the others (30+ mpg) and I wonder if it's due to this muffler/exhaust setup... |
Altema Samba Member
Posted: Thu Apr 10, 2014 6:55 pm Post subject: |
Woreign wrote: |
Is your muffler the same as mine? |
Yes, except I have the uncoated version that needed to be painted. Compared to the stock muffler, it is quieter than stock at idle or when cruising, a little bit quieter than stock during light acceleration, and louder than stock under heavy acceleration. By louder, I mean it will set off car alarms in a parking garage if I jump on the throttle. However, if I'm cruising on the freeway with the windows open, I cannot hear the engine... just wind and tires on the pavement.
I get good gas mileage with this setup too, usually in the 30's like you.
Regarding the noise, do you have the sound panel on the firewall? That makes a big difference, because without it, the noise is transmitted by the firewall to the body structure.
Posted: Thu Apr 10, 2014 8:49 pm Post subject: |
I do have the tar board in the engine compartment, and a layer of peel-n-seal on the inside. It still seems louder than my other cars, but it is also the smallest. That might have something to do with it... |
ScottDoonan Samba Member
Joined: August 04, 2005 Posts: 546 Location: Northern California
Posted: Thu Apr 10, 2014 10:00 pm Post subject: |
More panel mock up.
_________________ If you take time to do it, do it right and don't be so damn cheap.....🤙🏻
1959 Karmann Ghia Cabriolet (current restoration)
1965 Porsche 356 SC coupe
1967 Volkswagen Convertible Beetle
1969 Porsche 911E Targa 3.2 twin plug
2006 Porsche 987 Rüf 3400K Prototype #2 of 2 |
Altema Samba Member
Posted: Fri Apr 11, 2014 9:26 am Post subject: |
Woreign wrote: |
You would think it would be about the same as a Beetle, but the passenger compartment is shorter. Also, the engine compartment is bigger which supports low frequency resonance, so you wind up with a boomier sound. I would expect the Ghia to be louder than your Notch, but not the Thing. Of course, a higher performance engine will be louder through the exhaust than a stock one, and that may be the case. |
Altema Samba Member
Posted: Fri Apr 11, 2014 9:27 am Post subject: |
Scott, I think you could build a Ghia from scratch...
Awesome work.
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Fri Apr 11, 2014 11:54 am Post subject: |
Altema wrote: |
Awesome work... |
Please don't say that because mine is in more pieces than his and I don't have any metalworking skills.
I am on the steepest learning curve of my life of my life (and I've had the privilege of studying in Hamburg, Leiden, Amsterdam, Rotterdam, and elsewhere.) This makes reading old books written in Latin, German and Dutch look easy.
Now please tell me there's a manual for Dummies like me.
Please post lots of photos Scott. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
FRNKNSTNGHIA Samba Member
Joined: March 05, 2010 Posts: 411 Location: Kissimmee, FL
Posted: Fri Apr 11, 2014 5:36 pm Post subject: |
Scott wheres the rest of the car, just noticed its only the front. |
Posted: Fri Apr 11, 2014 5:43 pm Post subject: |
Working on that in my garage. The rest of the car is at my friends garage. So I split time between the two. Keeps it interesting. _________________ If you take time to do it, do it right and don't be so damn cheap.....🤙🏻
dingo0_13 Samba Member
Joined: February 18, 2014 Posts: 16 Location: southern ind
Posted: Mon Apr 14, 2014 4:08 pm Post subject: oil change |
changed the motor oil in my ghia today.that wasn't too bad.then I decided to change the tranny oil and things went south.nipple came off twice and of course I was laying directly under neath drain plug.checked on here and saw how much easier it is to take off left rear wheel and use a soft hose to pour it in SLOWLY but got it done just before it stsrted raining.YEAH++++ |
kelsyryann Samba Member
Posted: Mon Apr 14, 2014 9:04 pm Post subject: |
Took it out for a nice cruise in the sun |
Brassneck Samba Member
Joined: November 17, 2012 Posts: 420 Location: Seattle
Posted: Mon Apr 14, 2014 9:19 pm Post subject: |
kelsyryann wrote: |
me too. You dont happen to have a red ghia do you? I passed one today in shoreline! |
Posted: Mon Apr 14, 2014 9:23 pm Post subject: |
Brassneck wrote: |
kelsyryann wrote: |
Nope! I have a green one! There's a picture in my gallery of it! |
Posted: Tue Apr 15, 2014 12:29 pm Post subject: |
Looks great and Very clean. I like it. |
Posted: Thu Apr 17, 2014 10:52 pm Post subject: |
Continued restoration, moving to the rear slowly
