kingkarmann Samba Member
Posted: Thu Jul 03, 2014 10:15 am Post subject: |
The chassis work looks very sharp. Can't wait to see the finished product!
That Honda Trail 70 sure takes me back _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
FRNKNSTNGHIA Samba Member
Joined: March 05, 2010 Posts: 411 Location: Kissimmee, FL
Posted: Thu Jul 03, 2014 11:14 am Post subject: |
One Year Wonder wrote: |
Been busy putting the pan back into a roller on my '67 Coupe...
digging the chassis, but also the mini-bike... may I ask what tires are those... I like the tread pattern... |
xsnowpig Samba Member
Joined: March 19, 2012 Posts: 25 Location: glenwood springs, co
Posted: Sun Jul 06, 2014 1:10 pm Post subject: color change |
first attempt at full paint job. decided to do the color change i'd been pondering during the rust bucket restoration that is my 71 coupe.
not too bad for about about $150 in materials, including sprayer. now to knock down the fat lady cellulite with some wet sanding because i've found out that i'd rather have a 5 footer paint job instead of the 20 footer it is after not thinning the urethane enough. ugh. |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Mon Jul 07, 2014 7:35 am Post subject: Re: color change |
xsnowpig wrote: |
Hey, at least your orange peel is actually orange - I say just roll with it. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Mon Jul 07, 2014 8:27 am Post subject: |
An Orange Peel finish is the new primer suede fad...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Fri Jul 11, 2014 3:13 pm Post subject: |
Replaced the engine mounts! I WAS going to drop the engine, but the headers hit the valance before I could get past the transmission input shaft. Sooo, since there was enough room to get my hand between the engine and transmission, I went for it. There was not quite enough room for the transmission to move up to remove the old squishy mounts, so I pried the engine up and towards the opposite side and was finally able to get the first mount out. With one mount out, it was easier to extract and install the other one. I had started on it last night, but got asked to go on a picnic by my wife's friend. She drove, so I was kinda hostage for a few hours (in a good way). The downside was that it took up the time I was supposed to be spending on the Ghia, and I had to finish up in the morning which made me late for a very very important appointment to meet up with a fellow Samba member.
The car started instantly and feels more responsive without the mush mounts. I used rubber ones instead of poly, but made sure they were German. Then it was time to hit the road for a 45 minute drive and everything went well... until I was almost at my destination and heard a rubbing or chuffing sound. I thought it was the pulley tin, but it also sounded like a severe cyinder head lear or a blow out plug. Turns out it was a tin screw and washer I had not tightened down that feel underneat the pulley (phew!). |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Mon Jul 14, 2014 11:18 am Post subject: |
Good choice on using the rubber mounts. Here's what the poly ones looked like when I removed them:
And I was able to install the replacement mounts without removing the transmission as well. It was a very tight squeeze and I had to grind about 2mm off of one of the bolts to get it to fit. |
Posted: Wed Jul 16, 2014 11:34 pm Post subject: Level |
I was re-arranging a very cluttered garage and had to move the Ghia to the driveway. I looked out from the doorway at her backside and noticed the drivers side was about sagging about 2 inches. I guess I may have gained a couple of pounds over the years since the car was finished
I re-indexed the spring plate/torsion bar to bring it back to level. It sure makes it nice to have a spring plate tool which I didn't have when I was restoring her. It's nice and level now! It sure doesn't look level in this picture. I think I had my I -Phone on a slant
Mike Gerson
Nataliexsari Samba Member
Posted: Thu Jul 17, 2014 11:15 am Post subject: 69 Karmann ghia engine problem |
Hi guys, sorry I'm new to this site and I just had a quick question. I have a 1969 and I can't seem to find how to open the engine compartment. I googled how and came up empty. There is no lever by the drivers side. There's a lever where the emergency brake is and that did nothing. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Thu Jul 17, 2014 12:03 pm Post subject: Re: 69 Karmann ghia engine problem |
Nataliexsari wrote: |
Open the driver's door...tilt the seat forward...the panel below the rear seat close to the door pillar you will see a large knob...pull it.
It's spring loaded..if the engine lid doesn't open have someone lift it while you pull the knob.
Good luck. _________________ John.
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Thu Jul 17, 2014 9:56 pm Post subject: |
I took my Bentley Manual to a printing shop and had them scan, enlarge and print the Wiring Diagram for me.
There is something perverse in the way the world works: The older I get, the poorer my eyesight, but at the same time, the print gets smaller everywhere.
Now I can at least start working on my own wiring loom without having to hold some magnifying glass to my nose. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Fri Jul 18, 2014 5:54 am Post subject: Re: 69 Karmann ghia engine problem |
John Moxon wrote: |
Good luck. |
You'll find the early 1969 Karmann Ghia Owner's manual HERE, and the late 1969 Karmann Ghia Owner's manual HERE,
There's plenty of useful information in there, including what that mystery lever by the emergency brake handle does. |
Posted: Fri Jul 18, 2014 8:02 pm Post subject: Re: 69 Karmann ghia engine problem |
i thought it was to pull ebrake to that side specifically.... |
Posted: Sat Jul 19, 2014 11:19 am Post subject: Starter!! |
Well damn!!
Drove over to pittsburgh yesterday for the vintage Grand Prix today and Sunday. It had been raining all morning. It began to clear so I hopped in the Ghia and was greeted by a spinning starter that wouldn't engage. Tried hammering on it to no avail. Luckily we are staying with a friend who has a garage. I have the tools and pulled the starter. Waiting for the wife and her friend to finish their retail therapy session and pick up a starter I found at the FLAPS. The show runs through tomorrow so hopefully we will be up and running soon. Sheesh!! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Sat Jul 19, 2014 2:47 pm Post subject: |
Success!!! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
juki48 Samba Member
Joined: March 07, 2007 Posts: 602 Location: Upstate NY
Posted: Sat Jul 19, 2014 4:05 pm Post subject: |
put a $7 short shift kit in my 74's shifter. I like it, although it's taking a while to get used to. I keep thinking it isn't going into gear because the travel is so much shorter. _________________ Riley
74 Ghia 2276 Turbo MSII Extra
67 Beetle in restoration
Manx style buggy 1600 stock |
Altema Samba Member
Posted: Sun Jul 20, 2014 10:20 am Post subject: |
juki48 wrote: |
put a $7 short shift kit in my 74's shifter. I like it, although it's taking a while to get used to. I keep thinking it isn't going into gear because the travel is so much shorter. |
I had the quick shift kit on mine for about a week, and never got used to it. If I had one that was halfway between the normal shift and the quick shift, I might try it though.
Paul |
Altema Samba Member
Posted: Sun Jul 20, 2014 10:26 am Post subject: |
After the floor damage was professionally repaired by Kman, I cleaned it up, replaced the heater vent that was removed for the repairs, re-torqued the spark plugs, and adjusted the valves. Then the car started cutting out randomly at idle, and I could see on the AFR gauge it was going lean then coming back. This told me what it was, so I went home and found the idle cut off solenoid loose enough to lose ground. I usually just screw it in by hand, which is tight enough for it to work and not leak, but not tight enough to keep from working loose from heat cycling. Used the correct 17mm wrench on it and carefully snugged it with two fingers. All better now!
Paul |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sun Jul 20, 2014 12:47 pm Post subject: |
juki48 wrote: |
I put one on my 63 bug when I was in college, it was wonderful .... Just bought another one off ebay. I understand some are now made of metal. and others are made of plastic. The one I just got is metal. |
Altema Samba Member
Posted: Sat Jul 26, 2014 7:34 am Post subject: |
Just changed the oil/filter and cleaned the carb last night. For the first time the lady at the parts store looked confused and wanted to lookup the "correct" oil filter for a 1970 VW. I had a good laugh... until I got the total bill. Six quarts of oil and a filter was $52 and change. Yikes!
Paul |
