kgj Samba Member
Joined: February 25, 2013 Posts: 418 Location: Uk, Cornwall
Posted: Fri May 29, 2015 2:40 am Post subject: Getting motivated |
I'm posting this to record the date of my last drive out before the MOT runs out tomorrow. I need to get the heater channel replaced on the left hand side before I take it in for test. I've read the threads and how to guides, bought the parts, and now feel ready to tackle the job. Will it be back on the road this summer? Let's see.....
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Posted: Fri May 29, 2015 2:50 am Post subject: Re: Getting motivated |
kgj wrote: |
That's a busy little backwater...where is it...Devon?
Despite the need for new heater channels, black Ghias always photograph well. Post up your heater channel replacement process in a new topic if you have time...it draws in a lot of useful advice if you need it.
Good luck. _________________ John.
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Fri May 29, 2015 4:34 am Post subject: Re: Getting motivated |
kgj wrote: |
Let's see some pictures of that interior when you get a chance, please.
I love the color and contrasting piping on the seats, and I'd like to see more of them. |
kgj Samba Member
Posted: Fri May 29, 2015 6:18 am Post subject: |
Thanks for the comments.
Question 1. Mylor Harbour. Cornwall. I keep a boat here, it's fabulous.
Question 2. Photos of the interior. See attached.
You can see I'm serious about the heater channel repair. I've got as far as taking out a seat and removing the sill plate.
bozworth1026 Samba Member
Joined: June 23, 2013 Posts: 42 Location: United Kingdom
Posted: Sun May 31, 2015 10:13 pm Post subject: New Interior |
Added new carpet to interior, its a newton, getting to fit was a] tricky
Have to look at smartening up the pedals
Also added some shiny bits window handle and door lock
Sudar Samba Member
Joined: May 18, 2015 Posts: 33 Location: Stewartstown, PA
Posted: Wed Jun 03, 2015 12:57 pm Post subject: |
I just installed the new Preheat cable my son and I made, took the Ghia for a spin around the block, opened the hood and everything appears to be working as it should.
Just waiting to see if it returns to the Preheat position when is cools off!
Achilles3588 Samba Member
Joined: February 11, 2005 Posts: 633 Location: Bradenton, Florida, USA
Posted: Thu Jun 04, 2015 8:02 am Post subject: Nice work |
a Auto-stick Ghia....what a concept
Seriously though - looks to be the same vintage Ghia as mine. Any reason you went with what appears to be an electronic fuel pump? _________________ Larry V.~
'91 Syncro Doka 1.9L TDI 'AFN' |
Sudar Samba Member
Posted: Thu Jun 04, 2015 4:04 pm Post subject: |
Larry, it is a '68 Ghia coupe. My wife has wanted one her entire life. She took me to by my Harley 13 years ago. Just before mother's day this year she came home and said she found a Ghia. I drove the bike up the next day and traded for the Ghia plus cash, my favor. I figured I didn't ride much anymore so she deserved to have fun with her ride. We are the third or forth owner. Looks like it was partially restored at one point. Unfortunately I am finding more and more rust, driver's side pans are shot. I've been changing fluids and got the fuel gauge and horns working again. I don't know where to go from here?!?!?! I'm thinking to just patch the floor pans as best I can and let her drive it for a few years. Funds aren't plentiful at this time so a complete restore will be down the road.
It isn't the original fuel pump, it was put in place by PO
Darrin |
Brassneck Samba Member
Joined: November 17, 2012 Posts: 420 Location: Seattle
Posted: Fri Jun 05, 2015 1:14 pm Post subject: |
Wow...majestic! Ghia looks dwarfed by the sky. |
Paul70Ghia Samba Member
Posted: Sat Jun 06, 2015 9:35 am Post subject: Underside tidy up |
Spent most of today grovelling around on the floor looking for any loose underseal patches or rust under arches and floor pan.
Generally in good condition but back side of sill where it meets the floor pan has (had) a bit of surface rust - also hadn't realised quite how effectively the small gap to the floorpan edge seems to hold mud and stones - took ages to poke it all out .
Cleaned it all up as best as possible, followed by rust converter and a good thick coat of two pack epoxy mastic. Second coat to follow after which I'll spray cavity wax into all the gaps which are too inaccessible to paint. Probably another day in total - and then another two days for the other side.
akear Samba Member
Joined: August 18, 2013 Posts: 359 Location: Los Angeles
Posted: Sat Jun 06, 2015 8:01 pm Post subject: |
Sudar wrote: |
I just installed the new Preheat cable my son and I made, took the Ghia for a spin around the block, opened the hood and everything appears to be working as it should. |
Wow, very nice job! How did you make the spring? Or, could you just make one for me? |
Sudar Samba Member
Posted: Sun Jun 07, 2015 6:56 am Post subject: |
akear wrote: |
PM sent _________________ 1968 Ghia Coupe AKA "Harley"
1969 Beetle Standard AKA "Angus" |
squonk Samba Member
Joined: August 13, 2011 Posts: 257 Location: Upstate New York
Posted: Sun Jun 07, 2015 12:40 pm Post subject: |
Added to the list of "Ghia jobs I'd rather not do again anytime soon" replacing the bushing and coupler on my shift rod.
To the excellent tutorials posted by others, I would add only one small detail from my experience. When reinserting the shift rod, make sure the "cup" in which the shift handle fits is turned 90 degrees from facing directly up (its final, installed, position) or it will hang up on an indentation at the top of the tunnel about 4" in from the inspection hole.
I'll also say that, if you've been thinking about doing this, it's ultimately worthwhile. I expected a bit of an improvement, but wasn't prepared for how much better things are now. The car shifts like a new vehicle. I can get it into first gear when stopped without having to first put it in second, and the incredibly annoying shift handle rattle is gone. So, overall, a good project. _________________ '71 Ghia cabriolet |
Kharon8 Samba Member
Joined: March 05, 2011 Posts: 375 Location: Espoo, Finland
Posted: Tue Jun 09, 2015 3:33 am Post subject: Inspection failed but other stuff done |
KG has been sitting almost 5 years so some problems were expected in inspection, like stuck brake piston (only one this time) or non-working licence plate lights.
Piston was tight but turning with large pliers helped and lights had just rust, couple of days in acid (for bulb holder) and zinc spray to it helped.
But worn out king pins will be more work and I had to order those as no-one here had those in shelf, a week delay.
Meanwhile we (with a more skilled friend) adjusted the carburetors (double DellOrtos) and noticed that I've a intake leak on other side, needs to be fixed at some point.
Anyway, it runs much, much better now and, as a 1915cc engine, it has nice amount of torque.
Inspector was whining about the modified engine too, as I didn't have any papers of it with me, they refused to change the engine data in registry until I provide some papers. (And it has so much more torque now no inspector will believe it's a stock engine.)
Ahh, the bureucrats: It's an engine a fellow hobbyist built for me from mostly random parts in his shop and there's no receipts from any of those ... so now he's just writing me a certificate that this engine (serial so-and-so) has been modified with these and these parts (product ID abc from shop xyz), signed by builder.
I hope that's enough. We'll see. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
FVWA.fi support group. |
mountainkowboy Samba Member
Posted: Wed Jun 10, 2015 2:47 pm Post subject: |
Took her on her last drive for me. Pulled the engine and started getting my parts together for her new owner _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Thu Jun 11, 2015 1:36 pm Post subject: |
My '74 with a Solex 34 is having a series of fuel related issues. First, the gas tank and lines were barely flowing gas, like 10 drips an hour... Took everything apart from tank out to the line hooked to pump, found that the rubber portions of the line were all turned to gum. Also, somehow, the intake inside the tank was completely rusted closed. had to create myself a rooter using my drill and a Bass guitar string. took about 10 minutes to clean it all out. Now, I get gas, but the engine won't idle. I mean NOT AT ALL. I can keep tapping the throttle, and keep it alive, but it simply will not idle. Tonight Im going to see if there is something clogged inside the carb. I also got a fresh throttle cable, as the one that has been in there for the last 25 years I have owned it is the same hack it got when I bought it.. a piece of clothes hanger wire coupled to the broken end of the original cable... it worked, but looked like garbage. |
ScottDoonan Samba Member
Joined: August 04, 2005 Posts: 546 Location: Northern California
Posted: Sun Jun 14, 2015 11:20 pm Post subject: 59 Cabriolet |
_________________ If you take time to do it, do it right and don't be so damn cheap.....🤙🏻
1959 Karmann Ghia Cabriolet (current restoration)
1965 Porsche 356 SC coupe
1967 Volkswagen Convertible Beetle
1969 Porsche 911E Targa 3.2 twin plug
2006 Porsche 987 Rüf 3400K Prototype #2 of 2 |
Posted: Mon Jun 15, 2015 8:38 am Post subject: |
Took the Volume screw out to take a look, and spray out the port with carb cleaner. It was interesting in that when I got it all the way out, I noticed there was no O ring on it, as seen in any of the rebuild kits out there that include a new volume screw. Also, along the threads, about half way, there was this black gum, which I assume was once the O ring. Im not sure where to get just the O ring, but I blasted out the port with cleaner until it ran clear. Replaced Volume screw without O ring for time being. Will have to wait for pay day to get the rebuild kit. |
