DogGeorge Samba Member
Joined: June 25, 2012 Posts: 16 Location: Central Virginia
Posted: Thu Aug 06, 2015 9:24 am Post subject: |
Thanks Brassneck - it's a free speedometer app that reads in mph, kph or knots. I haven't bothered to buy the ad-free version because the ads are small and run across the bottom of the screen.
I hooked it in the speaker hole with a short bungie cord. Before the speedo cable snapped I was using the phone app to verify the analog speedometer and they agreed pretty closely up to 60 mph. |
Kharon8 Samba Member
Joined: March 05, 2011 Posts: 375 Location: Espoo, Finland
Duck58 Samba Member
Joined: October 10, 2010 Posts: 43 Location: North East England
Posted: Sun Aug 09, 2015 9:55 am Post subject: |
Some height correction on my 71 this week. |
clarkare Samba Member
Joined: May 25, 2011 Posts: 53 Location: Windsor, Berkshire,UK
Posted: Mon Aug 10, 2015 11:15 am Post subject: |
Broken valve spring fixed, alternator conversion complete so first drive out this year in the glorious French countryside, 100 k covered with no issues so now hoping to make the most of the good weather and use the car as it deserves to be used.... _________________ 1960 RHD Karmann Ghia |
O2COOLED Samba Member
Posted: Tue Aug 11, 2015 9:30 pm Post subject: |
Finally got around to installing the Hurst shifter I got from one of the swaps.... replacing the EMPI trigger shifter. Got the "sweet spot" location after several trial and error adjustments. Nice! I've forgotten how smooth this shifter is. I'm thoroughly enjoying it. _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
"At my age time is too short to respond to people with short minds"
Current: '69 Ghia Coupe
VW History:'63 Bug;'70 Bug;'73 412;'83 Rabbit;'86 Golf;'76 Fat Chick; 67 Ghia Coupe; '70 Bug |
aero3113 Samba Member
Joined: March 03, 2013 Posts: 196 Location: Setauket, NY (Long Island)
Posted: Wed Aug 12, 2015 4:48 am Post subject: |
Finally had time to do an oil change and drain/clean the air filter. I was amazed at the little dirt particles the oil bath filter catches. |
CK3 Samba Member
Posted: Wed Aug 12, 2015 9:09 pm Post subject: Oil plate stud |
Just before I left on my roadtrip to WY, I noticed some oil dripping from the oil plate nuts, so I started to snug them up. One twisted clean off. I think the problem was that I had put on a replacement plate, from Brazil, I think, that was thinner than the original. Anyway, a didn't have time to fix it then, so I drive 1,000 miles with a missing nut on the oil plate, and a slight drip. Last weekend I tackled it with some reverse drill bits and Easy-Outs. First, I tried vise grips on the stub of the stud. It just turned to mush and refused to turn. Then I took an angle grinder to the stud to make a flat surface, center punched it, and started drilling, one size at a time, four sizes, smallest to largest. Finally I put in an Easy-Out and it started to turn! Home free! Not so fast, it just kept turning forever. So, I got the next larger drill bit. Once I got it in there pretty good I cocked it sideways to bind in the hole and was able to pull out the stud. It had no signs of thread left on it. I tried tapping the hole with an M6 like original, but a replacement stud was a really loose fit. Ended up drilling and tapping for M8 and putting in a nice repair stud that is M8 on one end and M6 on the other. Worked great, and I think it is stronger than before. No change at all to the externals. |
JayFab Samba Member
Joined: April 29, 2012 Posts: 31 Location: Franklin, TN
Posted: Thu Aug 13, 2015 9:32 am Post subject: |
Towed my Ghia to my painter!!! |
lasslo Samba Member
Joined: September 01, 2004 Posts: 206 Location: sweden
Posted: Thu Aug 13, 2015 1:24 pm Post subject: |
Got my redone seats in
Now I have to get the engine in before the season is over here in Sweden....
And a before&after picture
_________________ 65 DD klenbus
57 Karmann Ghia |
Volfandt Samba Member
Joined: March 15, 2012 Posts: 500 Location: Knox County, East TN
Posted: Sat Aug 15, 2015 4:36 pm Post subject: |
Hadn't taken the Ghia out for a couple weeks and finally decided to run some errands and take a little cruise in it.
1st problem I run into was the battery wouldn't crank it over. A quick charge took care of that but even though it would crank and crank it wouldn't start.
Subsequent troubleshooting lead me to a bad fuel sender connection on the tank. After cleaning it up and getting a good connection my half tank turned into an empty one. Looks like my last cruise drained all the gas but it got me home.... The only gas left was what was in the fuel bowl and over those couple of idle weeks sitting idle it must have evaporated out.
Put a gallon in and got the gauge to register, and it started right up. It made it to the gas station and after filling it up I finally got some cruising in.
Moral to the story, don't let your Ghia sit too long and keep track of your miles as these aftermarket senders can't be trusted .....
Dave
P.S. the tripmeter indicated I got 250 miles out of that last tank.... _________________ 1972 Karmann Ghia, the Dragon slayer.... |
Posted: Mon Sep 07, 2015 10:29 pm Post subject: 69 Chrome Bleu |
No trips for the long weekend so had lots of time to work on the Ghia!
Finished installing trunk cover and liner I fabricated.
Also concerned about not being visible enough so installed LED DRLs. Now I don't have to drive around with my headlights on during the day.
akear Samba Member
Joined: August 18, 2013 Posts: 359 Location: Los Angeles
Posted: Tue Sep 08, 2015 6:17 am Post subject: |
I drove it! Took the Ghia and my bike to the local mountains. I forgot how nice these cars handle on the twisties.
Brassneck Samba Member
Joined: November 17, 2012 Posts: 420 Location: Seattle
Posted: Tue Sep 08, 2015 11:40 am Post subject: Re: 69 Chrome Bleu |
O2COOLED wrote: |
Looking good Ernie!
What do the running lights look like when not on? |
Posted: Tue Sep 08, 2015 1:34 pm Post subject: Re: 69 Chrome Bleu |
Brassneck wrote: |
Looking good Ernie!
Thanks Tico! Actually you have to really be close to notice. I made sure to keep them inside the grille so as not to mess up the front. Same reason I installed the 3rd brake light inside the rear glass. _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
Don Radomski Samba Member
Joined: May 12, 2015 Posts: 55 Location: Edmonton, Canada
Posted: Sun Sep 13, 2015 12:12 pm Post subject: |
The LED's look great, do you have any photo's of the rear LED lights? |
squonk Samba Member
Joined: August 13, 2011 Posts: 257 Location: Upstate New York
Posted: Sun Sep 13, 2015 2:32 pm Post subject: Re: 69 Chrome Bleu |
O2COOLED wrote: |
Finished installing trunk cover and liner I fabricated. |
Looks great! Would you be willing to share any templates you might have created? There was a thread some time ago about making a template available as a pdf file, but it sputtered out. _________________ '71 Ghia cabriolet |
lasslo Samba Member
Posted: Sun Sep 13, 2015 7:01 pm Post subject: |
Drove it, for the first time this year... Just as the summer is over
57 Karmann Ghia |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Sun Sep 13, 2015 8:25 pm Post subject: |
Looks ready for next year -- One suggestion MOVE SOUTH --
mine is still setting on jack stands since January -- might finish doing that oil change by October LOL _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
Posted: Sun Sep 13, 2015 10:49 pm Post subject: |
Don Radomski wrote: |
Thanks! The rear is a 5 inch LED that I wired and installed inside the rear glass. I just made sure to place it as close as I can to the glass to minimize any interior reflection.
Posted: Sun Sep 13, 2015 11:26 pm Post subject: Re: 69 Chrome Bleu |
squonk wrote: |
O2COOLED wrote: |
Looks great! Would you be willing to share any templates you might have created? There was a thread some time ago about making a template available as a pdf file, but it sputtered out. |
Thanks! I did make a template out of cardboard which I now regret throwing out in the recycling bin. It's quite easy to make though. I used fairly thin packing cardboard which made it easy to work around the area I want to cover. A wide one would be ideal otherwise you'll have to tape two together so it will cover not only the width of the trunk but also the sides. The template of the cover for the back of the dash I also made out of cardboard then transferred on to fibreboard then covered with the same material I used to cover the "false" speaker panel I made for the rear speakers. I am currently in the finishing stage of making up the barrier right behind the spare tire (to prevent stuff in the trunk from rolling into the spare tire well) and if you still need it I can lay the whole thing out and either PM you or post the measurements here. _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
