xzener Samba Member
Posted: Sat Nov 12, 2016 7:21 am Post subject: Re: What did you do to your ghia this week? |
Removed the doors yesterday... Anyone have any tricks for getting the last stubborn screw off the door hinge??
Will post some pictures of the hinge rebuild today. If I can get that darn screw off.
_________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
xzener Samba Member
Posted: Sat Nov 12, 2016 7:46 am Post subject: Re: What did you do to your ghia this week? |
Yep... Beat the crap out that screw yesterday. It won. Any other suggestions please?? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sat Nov 12, 2016 7:57 am Post subject: Re: What did you do to your ghia this week? |
If a standard propane torch, or even a torch using map gas capable of higher temperatures, is not helping you free two components joined by corrosion then chances are you need to have one of these ...
... Bernzomatic WK5500 Brazing Torch Kits in your toolbox of tricks and techniques.
When everything else I have tried has failed, that torch combined with PB Blaster has never failed to do the trick for me.
However, seeing as the hinge is made of aluminum IIRC, just be careful not to heat it up enough to melt the metal. |
xzener Samba Member
Posted: Sat Nov 12, 2016 8:03 am Post subject: Re: What did you do to your ghia this week? |
Thanks KGCoupe... Gonna torch the hell out of that thing. I feel a victory coming my way. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sat Nov 12, 2016 12:13 pm Post subject: Re: What did you do to your ghia this week? |
I believe it's a #4 screw driver/bit. Hard to find. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 383 Location: Minnesota
Posted: Sat Nov 12, 2016 3:46 pm Post subject: Re: What did you do to your ghia this week? |
I just drilled one out of my '73. I used a 1/2" drill bit to take the head of it off. The rest of it screwed out of the door by hand... go figure.
d |
desmato Samba Member
Joined: January 03, 2016 Posts: 56 Location: Michigan, USA, Earth, Milkyway, Universe,... Bottom of some being's shoe !
Posted: Sat Nov 12, 2016 5:08 pm Post subject: Re: What did you do to your ghia this week? |
finished assembly of the entire chassis/pan. all suspension is rebuilt and powdercoated, New beam, new balljoints, new urethane everything.
Finally starting to use some of the $3500 in parts. Now gotta decide if I tackle the body this winter, or wait until next and drive the hell outta it first.
Before:
After:
xzener Samba Member
Posted: Sat Nov 12, 2016 8:04 pm Post subject: Re: What did you do to your ghia this week? |
Redlabel6 wrote: |
d |
Did the exact same thing. It loosened up after driving a pilot hole for an easy out... Go figure. Turned out great, no more extremely loose door hinges. Thanks for all the great suggestions guys!
xzener Samba Member
Posted: Sun Nov 13, 2016 2:36 pm Post subject: Re: What did you do to your ghia this week? |
Finished sealing my pans today.
Posted: Mon Nov 14, 2016 6:23 am Post subject: Re: What did you do to your ghia this week? |
What did you use as a sealer? |
xzener Samba Member
Posted: Mon Nov 14, 2016 9:12 am Post subject: Re: What did you do to your ghia this week? |
It's a DuPont product, mainly used for frames and undercoating. Got it at O'Rileys. Says it can be applied directly to rust to stop corrosion... But I sanded rust to bare metal where needed. It was mainly just surface rust, lucked out with the pans on this KG. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Mon Nov 14, 2016 6:09 pm Post subject: Re: What did you do to your ghia this week? |
Oops, sorry. It's not a DuPont product, it's Dupli-color. It's about $44 a can, brushes on, and seems to be very durable after it dries.
Posted: Mon Nov 14, 2016 6:17 pm Post subject: Re: What did you do to your ghia this week? |
Thanks! |
c21darrel Samba Member
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Thu Nov 17, 2016 6:07 am Post subject: Re: What did you do to your ghia this week? |
RK doesn't go anywhere without his camera ---- I haven't seen him since he did the shoot for Schweers and Gregory's ProMod Notchs... Hope everything went well... Congratulations!!!!!!! _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
