What did you do to your ghia this week?
Page: Previous  1, 2, 3 ... 111, 112, 113 ... 164, 165, 166  Next
63 vwnotch
63 vwnotch is offline
PostPosted: Sat Nov 19, 2016 6:45 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
congrats... I was actually tempted to send you a pm about selling your Ghia, this was of course before I bought mine... love your style, very tasteful mods that simply make the car pop..
BUS WANTED: 13 window BUS any year considered..
Karly
Karly is offline
PostPosted: Mon Nov 21, 2016 3:44 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Sat in it for the first time now its all together again!
Really pleased with how its all turned out! Still at the shop for some final adjustments (including a more realistic regular use altitude).
1960 Beetle ''Heidi" daily driver
1964 Karmann Ghia project
c21darrel
c21darrel is offline
PostPosted: Mon Nov 21, 2016 10:50 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
It looks so good that low...the driving part, not so good. Crying or Very sad
GhiaBuild
1967 DC build
chipster
chipster is offline
PostPosted: Sat Nov 26, 2016 9:29 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Got engine installed, new shift rod bushings and the IRS a friend and I rebuilt actually shifts! Reassembly progress on the car is slow, got the sound-deadening in the interior, can't find the new TMI headliner I know I bought, it's around here somewhere. Meantime, I fixed my son's 1/24 ghia.
xzener
xzener is offline
PostPosted: Sun Nov 27, 2016 11:07 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Almost finished filling, sanding, priming the engine compartment. Those sharp prongs for the tar padding are brutal. Stabbed under two fingernails and sliced one of my fingers open. That's what I get for not wearing gloves... I still think I won.
Still debating on removing the cleaner stand... I will be going with dual carbs when its all said and done.
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
c21darrel
PostPosted: Mon Nov 28, 2016 12:14 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Dual carbs = remove stand. Smile
Gonna put the firewall tarboards back?
GhiaBuild
1967 DC build
xzener
xzener is offline
PostPosted: Mon Nov 28, 2016 4:11 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Figured that. Ok, it's being removed. Yes, I plan on putting tar boards back in... Unless there is a better substitute??
c21darrel
PostPosted: Mon Nov 28, 2016 6:32 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Drill the spot welds to remove stand.
If you are going to paint and recover firewall with tarboards....dont spend a boatload of time making it perfect. I lost weeks of my life making everything perfect only to cover it with sound deadening, carpet..... Confused
GhiaBuild
1967 DC build
xzener
xzener is offline
PostPosted: Mon Nov 28, 2016 6:54 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
I know... I see people with beautifully painted interior, only to be covered with carpet, panels, etc. The engine compartment is prepped IMO. Sanded the glue to a smooth paintable surface. The horizontal surfaces will get the most attention. I will be grinding the spot welds off the stand, with minimal damage to the engine compartment. Thanks for the reply.
xzener
xzener is offline
PostPosted: Mon Nov 28, 2016 7:06 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Was thinking about drilling them out, through the compartment. Painting the holes, and plugging them with a rubber plug. Have the stand painted, that way I can bolt the stand back on if I ever want to go back to stock. I'm sure it's been done before.
swavananda
swavananda is offline
PostPosted: Tue Nov 29, 2016 10:26 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
If you are going for stock look than tar boards it is ........ But IMO , engine bays look way nicer with paint showing . Closed cell mat -sound proofing under the carpet works way better any way.
c21darrel
PostPosted: Tue Nov 29, 2016 10:59 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
^^^Agree. I went the painting route. I added several layers of Rattletrap, 1/2 inch, foil lined heat and noise reducer plus carpet. My car is still loud Confused
I will have to find some closed cell mats and see if that sucks it up.
GhiaBuild
1967 DC build
xzener
xzener is offline
PostPosted: Sun Dec 04, 2016 3:31 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Done... Removed air cleaner stand. Among other things, but this is the topping on the cake.
BEFORE
AFTER
Volfandt
Volfandt is offline
PostPosted: Sun Dec 04, 2016 5:10 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
xzener, it wasn't too long ago that I reinstalled the AC stand in my single carbed Ghia. It took awhile to find a good serviceable one. Don't chuck it.
Had an intermittent starter issue that got worse to the point the starter wouldn't spin. Finally jacked it up and tried my remote starter switch and the starter spun just like the engr's designed. So I figured either the wiring or starter switch were bad. Before I crawled out from under I loosed all connections, cleaned and re tightened them down.
Went to the key switch and it cranked every time.
I guess it could have been a corroded connection at the starter solenoid but I dunno. The starter switch that connects to the key switch is $19 and is plastic. I believe I'm going to pick one up for just in case.
1972 Karmann Ghia, the Dragon slayer....
c21darrel
PostPosted: Mon Dec 05, 2016 11:44 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Don't chuck it.
Dont chuck anything, there is always someone who will need it. I think my old stand ended up in the UK.
GhiaBuild
1967 DC build
KGCoupe
KGCoupe is offline
PostPosted: Mon Dec 05, 2016 8:58 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
c21darrel wrote:
Don't chuck it.
Dont chuck anything, ...
Words to hoard by - Believe it.
Ask me how I know. Embarassed
xzener
xzener is offline
PostPosted: Mon Dec 05, 2016 9:26 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
My garage is already full... It's all stuff bagged and tagged from the restore. Haven't hoarded anything yet, this will be the first item. I plan on repairing the damage and painting it the same color as the car. You know, just in case I go back stock.
lasslo
lasslo is offline
PostPosted: Wed Dec 07, 2016 4:07 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Bought some metal to get the 57 back to lowlight aigain Smile
65 DD klenbus
57 Karmann Ghia
DomG
DomG is offline
PostPosted: Fri Dec 09, 2016 4:26 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Installed Christmas lights on my roof rack. Started evaluating why my gas gauge stopped working, added flared tips to my exhaust pea shooters from Aircooled Accessories. Bought a drill tip to tap into my front bumper blade covers to install my amber lens fog lights.
sputnick60
sputnick60 is offline
PostPosted: Sun Dec 11, 2016 3:03 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
I took it to the beach
Perfect day too
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Page 112 of 166
