mfitzsimor Samba Member
Joined: May 09, 2004 Posts: 171 Location: Portland, OR
Posted: Sat Aug 17, 2013 3:28 pm Post subject: Wiper/washer switch upgrade - will it fit? |
Does anyone know if this aftermarket replacement wiper/washer switch will fit in the stock switch location on a 69 ghia and NOT interfere with the stock Sapphire radio?
http://www.rallylights.com/hl87200-intermittent-wiper-control-switch.html
I'm concerned because I read on a beetle forum that this switch housing is larger than the stock switch.
thanks!
Mark _________________ portland, or
69 cypress green ghia coupe
82 vanagon TD
86 quantum syncro |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Sat Aug 17, 2013 6:20 pm Post subject: |
you should read this thread :
http://www.thesamba.com/vw/forum/viewtopic.php?t=395957&start=0
the jist is that hella switch is not a stand alone unit, it runs in conjunction with the stock switch. the cole hersee switch is a stand alone. i put CH switch in a couple years ago and it is a great improvement for a daily driver. and yes,there is plenty of room behind the dash for it. |
Posted: Sun Aug 18, 2013 8:08 am Post subject: |
Thanks Swavananda!
I just installed my refurbished Sapphire VI radio (by Nick Stokes) and though it looks like there is plenty of room next to it.......I was hoping for some confirmation before making the purchase.
What kind of washer pump did you choose and where did your place it? I have a scavenged U-pull-it pump that looks like it might zip tie nicely somewhere near the horns on a support bracket.
mark _________________ portland, or
82 vanagon TD
86 quantum syncro |
Posted: Mon Aug 19, 2013 4:04 pm Post subject: |
i just used a small generic pump. i tapped into the bottom of a stock bottle with a hose barb and pc11 epoxy, and looped the hose up and around to th pump.
Loren Samba Member
Posted: Tue Aug 20, 2013 9:45 am Post subject: |
Thanks for the pump and switch information. My washer tank hangs from the plate that supports the hood latch, so I think I will velcro the pump under the bottle and run the wires alongside the washer fluid tubing to the switch.
I love the conversion of the stock switch, but I also want intermittent wipers to better cope with the climate here so I ordered the CH switch. Hopefully wiring it in will be straightforward.
82 vanagon TD
86 quantum syncro |
Posted: Thu Aug 22, 2013 4:38 pm Post subject: |
a tip on the new switch install.
the CH switch shaft is a smaller diameter than the Escutcheon on the stock switch, to compensate for this i put a rubber grommet in the hole then sandwiched it with appropriate sized washers and tightened the jam nut snug.
works well and looks clean .
you can send me a PM if you need any help on the wiring, but i think that linked thread lays it out o.k. |
